Question about Baby Gear
Vauxhall Astra LPG, fault
Astra LPG (fitted when made, not a conversion )2004. Cuts out when warmed up. Have to wait 5-10 mins before it will restart. Engine management light is on. It has had all new sensors and been to 3 garages. Reading says code 335. Garage cannot find the problem. Some-one told me that there was a recall due to faulty brain, but I cannot find any info to back this up. So far have spent over £400.00, but car remains off the road. I am a taxi driver and cannot work. Please help. I am in despair.
  • 1 more comment
  • Bubble27 Feb 23, 2008
    Please help
    you are a waste of time
  • Anonymous Mar 25, 2008
    I am having a problem with mine where it is misfiring. it is worse on gas but is happening on petrol... any suggestions?
We have a 2000 lpg factory koltec system and it misfired on gas only, it required a new distributor (osf wing by bulkhead) and cost £425!. Now goes like a dream on lpg and petrol alike.
These astras are common for egr faults also, but that causes irratic / high idle on petrol only normally.
Posted on Jul 28, 2008
I hae got the same problemm has above have ben told that it is a loose wire cos does not isfire all the time just every so often
Posted on Jun 30, 2008
How to fit Vauxhall Astra mud flaps?
maybe this will help good luck
Nov 17, 2014 | Cars & Trucks
Vauxhall astra 1.7 td heater not getting hot
Assuming the fan works ok, it sounds like the cable from hand control to heater valve has come off or needs adjusting or replacing. Or (less likely) there is a problem with the mechanical valve. The valve needs to open to allow hot water to flow through to the mini radiator (heater radiator) and then both coolant pipes and mini radiator get hot with a warm engine. Try moving the valve lever by hand (somewhere above the clutch pedal).and If you start getting heat with the fan on the fault is the cable..
Nov 25, 2013 | Vauxhall Cars & Trucks
Vauxhall astra intermittant fault keeps cutting out?
Be more explicit.
What kind of Astra, what fault, etc...
Oct 09, 2013 | Vehicle Parts & Accessories
LPG car problems
SERVICE your CAR.THE MECHANIC knows hos job!!
Aug 05, 2012 | Vauxhall Vectra Cars & Trucks
Vauxhall astra wont start
This make of car is not sold here inthe USA so we have no tech info on it. Sorry
May 27, 2012 | Vauxhall Astra Cars & Trucks
Is there a recommended type of LPG kit for 2004 BA Futura? What are the potential issues with fitting LPG to this model?
All LPG kits are custom to vehicles they are being installed on. The possible problems are the same with all models. They include Leaks, lose of Mileage and the obvious dangers of filling the tanks when needed. I will tell you this much, it is unlikely you will save any money converting to LPG as most conversions get far less mileage than they do on regular fuel. Also, a Conversion kit is a full conversion. Once installed you are not going to have the option of switching between the two when the LPG system fails. You would think with the faster burn rate you would have better acceleration in LPG vehicle and better Mileage since the Typical LPG fuel is a higher burning and cleaner burning fuel but in reality it it usually just the opposite in conversions and they have a tendency to vapor lock more often.
Sep 20, 2010 | Ford Futura Cars & Trucks
Vauxhall astra 1.6 factory fitted lpg 8v
sounds like they have turned off the gas main valve.location ??
Apr 20, 2010 | 1990 Audi Quattro
Will a 2.5 td fit into my astravan 2004 1.7 tdi
Forget it to costly, a BMW is a in line 6, the Astra has aV 6 engine.
Aug 08, 2009 | 2003 BMW 325
My car wont start, 1997 vauxhall astra 1.7 turbo diesel
This sounds like a problem in the fuel shut off circuit. When you turn the key on, it energizes the fuel shut off solenoid on the injection pump. When you turn off the key, power is removed and the pump is moved by spring to the fuel off position. Check for power at this terminal when you are having a problem, ( with the key on) If no power then I would check the wiring and connectors from this connection to the Ignition key. I believe it is wired direct. That can be checked at http://www.alldata.com/products/index.jsp
subscribe3 and get a wiring schematic for the car and see if it is wired direct to the ign switch of from a relay, I am sure it is a connection problem if you have no power.
A 1.7 diesel even if turboed, is dead slow in any vehicle let alone a van. Enjoy the fuel economy
good luck
Mar 11, 2009 | 1998 Isuzu Amigo
Vauxhall Astra LPG - engine management light comes on in Gas only
The fuse for the LPG has blown, you need to replace this, it's found in the fusebox under the bonnet.
Nov 12, 2008 | Baby Gear
Baby Gear Logo
976 people viewed this question
Top Baby Gear Experts
Jennifer Rock
Jennifer Rock
Marvin
Marvin
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Baby Gear Expert? Answer questions, earn points and help others
