Question about Lexmark X3480 All-In-One Printer
Little thing Thanks! I've found the little plastic bit which has come off, but I don't know where it goes. I'll try myself
    Problem Solver:
  • 4 Answers
In the pictures that I sent you, you can see how it fits. It acts like a lever.
Look at the pictures closely and you'll see it sticking out a bit. Once again in the pictures where I have it circled. Can you see where I'm talking about?? It just clips/snaps on so when the lid closes, it pushes on the switch to close the circuit which then cancels that annoying message........
Let me know......I'm feeling better so if I have to take the printer apart and take one more picture, I can do that for you so you can see exactly where it goes...........
Posted on Mar 02, 2008
Fisher price my little lamb baby swing will not swing
If it makes a sound but doesn't swing then the metal rod inside the motor casing was probably bent. If it makes no sound then it could be several different problems.
If it does make noise (my daughter did the same thing) then you can fix it, though it's not the easiest fix. Unplug it/remove batteries, and you'll need to remove the legs. Start removing screws to get to the motor casing, the first ones you'll need are in the battery compartment. Be careful as you're doing this, once you get the plastic casing off things can move around. Have someone as a second set of eyes if you need it.
Once you can see the guts look for a thin metal stick, no thicker than a telephone cord. Yup, that's what moves the swing. The metal is easily stressed. You can carefully power it up if you want to see how it works or make sure that little thing is moving. There's a small gear underneath all that, but you don't need to get to it.
Instead, you'll need to beef up that little stick. I used a leftover rubber gasket from a ceiling fan first, then I was so amazed it worked I took it back apart and used a longer piece of rubber tubing with a harder plastic tube over it (it's a very tight fit). It will still need to rock back and forth in it's little hole so don't go too crazy.
The one drawback is that I think it has a louder operation now, but the one thing that both my kids adored with the swing was the rhythmic tick-tock. If baby is happy, mama is happy.
Anyway, FP will sell you a whole new motor, or if you an find the exact part number you might be able to get a new pendulum. But I like fixing stuff, and I like free better, so if this is what yours needs I hope it helps. If this is but you don't follow what I've written I'm happy to try and take pictures of mine.
Aug 30, 2012 | Fisher Price My Little Lamb Dreamy Motions...
My Gateway Laptop wont turn on. Before it went out I would have to play with the charger in order for it to work. The charger has power and works, I believe it is the port that the charger goes it. Pe
1 to 1-1/2 hours to tear-down, 2 hours + to put back together....lol
if you've never done this before, I don't recommend it. Laptops have HUNDREDS of parts, and you'll have to strip it down to the motherboard to even begin to repair it. Some just need the connector re-soldered; others need the connector de-soldered, removed and then replaced. You will have to hunt around a bit harder for that part than for a new adapter, but you should be able to find one.
Bottom-line. When you buy a laptop, you need the confidential damage/loss insurance. These things are VERY expensive to repair (as you've discovered,) unless you do the work yourself.
On a positive note, mfr's of newer laptops have designed seperate power-boards for their lappys, others make it easier to get to so you don't have to remove quite so many parts to get to it....
Look for a Service Manual online (if you can get one...) and you will see what you're in for.
Aug 24, 2012 | Gateway NV5214u Notebook
Reset the cmos
This depends on what you're trying to do. If you've changed something in the BIOS itself and it no longer works, but you can't remember the default, enter the BIOS and press <Alt><F>. If you have a password on the BIOS that you can't remember, there is a jumper on the board itself that will clear the password. There is also a jumper to clear the NVRAM, which may help you.
The schematics for the jumpers are here: http://support.dell.com/support/edocs/systems/wsT3500/en/SM/a_sysbd.htm
If you've never used a jumper, you're looking for a little plastic bit on the motherboard. If you pull up on this plastic bit, (fingernails are very helpful here) you'll see two gold pins sticking up off the motherboard. This is a jumper. To deactivate the password or clear the NVRAM, remove the appropriate jumper connector (the plastic part) and power up your system for about 10 seconds. Then turn it off, replace the jumper and cross your fingers.
Hope this helps!
Feb 21, 2012 | Dell XPDFK Precision Workstation T3500...
Both hinges on my PC have popped out and disconnected the screen from the keyboard. I don't know what to do. I've been trying to put them back in myself, but nothing is working. I've resorted...
I hear you... this is like the only thing that breaks on these A45's and its corporate brother - A40's: always starts from the left hinge and if you don't take care of it, the right hinge goes, too. These hinges are the hardest things to find in the world (it's the only part that breaks) I'd try eBay - you can probably get a whole, used machine (either an A40, or A45, and I'd prefer the WiFi ready models) with good hinges for $40 bucks or thereabouts, and put your hard drive, memory into the replacement machine and use it. Hope that makes sense.
Oh, and Toshiba no longer carry these parts so new ones are kinda out of the question.
Aug 31, 2011 | Toshiba Satellite A45-S151 Notebook
How many seconds of grind for standard drip grind
I've long ago lost the manual that came with my grinder (I actually don't remember if it even had one), but I don't think it listed grinding times. You just grind a few seconds and check, then grind a little more if it's still too coarse. Unlike a burr grinder which is adjustable, in a blade grinder the same grind time may result in different consistencies as you change beans. By now I've just learned how long to hold the button for the different beans I buy, and the first few times I try a new blend or varietal I have to adjust the time. I think you'll just need to experiment and then you'll know what works best for your tastes.
Jun 30, 2011 | Braun KSM 2 Electric Blades Grinder
The gas gauge is not registering when gas is put in the van
I don`t know this particular car but I don`t think the dissy has anything to do with the fuel gauge. Did the fuel gauge work perfectly before?? If so, you`ll probably find that you`ve disturbed a connector which goes to the sender unit. It`s very easy to do, I`ve done it myself and it`s VERY annoying to find you`ve sorted one fault only to find that you`ve caused another fault. Just go over everything that you`ve touched and done to the car. Did you short something out when you were replacing the cap, if so, you`ll probably find that a fuse has failed and it`s not just the gauge that doesn`t work. All the best, Ian
Aug 05, 2009 | 1998 Nissan Pathfinder
Altec lansing inmotion IM7 how to fix dock door?
I've found a solution. Most likely you have broken the catch inside this part so it needs replacing but don't worry, it's relatively easy to do. The latch is the black piece of plastic behind the door with a claw sticking out.
1. First, email the manufacturer and and ask for a sample latch to be sent out to you. After a bit of research I finally found them. In the UK they make them in white so I ordered one of those as I think it looks better (part #DL1WH): http://www.richco-inc.com/component/jumi/search-parts.html?searchinit=true&searchtype=rohs&interest=DL-1&Submit3=Submit
2. Get a pair of thin pliers and carefully pull out the old latch. To do this pull on on any part of the outer rim. I used the lower edge. Don't worry of you damage it. You'll be throwing it away anyway. Just don't damage any of your speakers.
3. Slide the new latch into position and push into place.
4. That's it. All fixed!
May 14, 2009 | Altec Lansing inMotion iM7 (021986950806)...
I find the codes of the lyrics of moments of truth by:FM static..
Moment Of Truth - Fm Static
Here we are, in the best years of our lives.
With no way of knowing, when the
whee’ll stop spinning cause we don’t
know where we’re going…
and here we are, on the best day of our lives.
And it’s a go, lets make it last, so cheers you
all to that, ’cause this moment’s never comin’ back
I used to know her brother, but I never
knew I loved her, ’till the day she laid her
eyes on me. Now I’m jumpin’ up and down,
she’s the only one around, and she means
every little thing to me
I’ve got your picture in my wallet, and your
Phone number to call it, and I miss you more,
Whenever I think about you,. I’ve got
your mixed tape in my Walkman, been so
long since we’ve been talkin’ and in a few
more days, we’ll both hook up, forever and ever
And here I am, on the west coast of
American and I’ve been tryin’ to think for weeks of
all the ways to ask you, And now
I’ve brought you to the place, Where I’ve
poured my heart out, a million times, for a million
reasons, To offer it to you
Apr 06, 2009 | Computers & Internet
Warreny over , fix it myself ?
I don't think you'll be completely happy with this, but I'm pretty sure the DC Jack (the power plug you broke) is soldered onto the power control board. This doesn't mean it's not repairable. I've done this with some good success in the past, but you might just want to replace this entire "daughter" board. HERE'S ONE on eBay for about $75, a lot less than the $200 for the mainboard or more for a complete replacement or repair. You could try to repair the DC jack and if that $12 fix fails, replace the entire Power Control Board (PCB). I think you should take it apart and check at least. It isn't that difficult if you have patience and the right tools. You'll need a "computer" or "electronics" screw driver kit and something like a credit card to help pry apart plastic pieces without scratching them. I also found this thread on NotebookReview that talks about doing what you want to. To see what the board looks like check out these pictures: eBay: 3680 mobo1 http://i17.ebayimg.com/04/i/001/0d/e1/7ce9_1.JPG To pick up the DC Jack you'll need, check out eBay, they are around $12 shipped. HERE'S ONE EXAMPLE GOOD LUCK!
Oct 07, 2008 | Acer Aspire 3680 Laptop
Pioneer SD-P55A3-K Proj TV will only stay on if I run a fan behind it...
Thermal issue !
A component inside the set has a thermal issue !
This may require hours of trouble shooting to find the components responsible.
Once the component(s) are found they could be serviced.
azkeyz@fixya.com
Wizard Division
Sep 23, 2008 | Pioneer Televison & Video
Lexmark X3480 All-In-One Printer Logo
21 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
