Scanner When I attempt to use the scanner, it states that the scanner in enabled. What do I do now?
  • shores Feb 23, 2008
    I did not type the question correctly. I states " The scanner could not be enabled"
  • shores Feb 26, 2008
    The information was very useful, but so far has not solved the problem. Have some coming today to look at it.
    Thank you
    TJC
    Sergeant:
  • 226 Answers
Do you have any scanner software installed to use your scanner with? In most cases a scanner comes with CD that installs a software package that will allow immediate use of the scanner after installation. Once that package is installed, you place picture in one of the corners of the scanner underneath the lid of course and press either the manual scan button that is on some scanners or the button on the software package that you installed into the computer when first configuring the scanner during installation. I assume you have acquired the scanner as a twain source else little will happen.
Posted on Feb 23, 2008
  • Ravel Lively
    Ravel Lively Feb 23, 2008
    well now, that makes a heck of a difference. what kind of scanner is it, manufacturer and model # please. I can be reached at ( hantoyo1@yahoo.com ) and/or ( hantoyo1 ) Yahoo Messenger ID
How to enable scan
There should be software that runs the scanner from your computer.
Sep 08, 2014 | HP Officejet 6600 e-All-in-One -...
Tip
Scanner Tips 2 " Don'ts "
<span>Never apply solution directly on the scanner glass. If you find that the glass is dirty or has a slight dust or smoke film underneath and on the inside, do not unscrew the lid and try to clean it from inside. It's always advisable to call an authorized service center. </span><br /> <span>Never use abrasives, isopropyl alcohol, benzene, acetone etc on the scanner glass, as this will streak and cloud the glass, and can Even cause damage. </span><br /> <span>Never place your scanner near heating vents or windows, or other locations where moisture might affect its functioning. Also remember: If you are moving the scanner from one place to another, make sure that the transportation lock is enabled, as this prevents the CCD array mechanism from moving. Push down the lock, which is located at the back of the scanner. Remember to unlock the scanner before you attempt to operate it, or you may end up damaging it. </span>
on Dec 28, 2010 | Hawking Contex HAWK-EYE Cx Scanner
Nimcard express is no longer around, however Plustek 610 card scanner is the same. downladed the drivers for it. When i attempt to open it states "bcr" not found in system, make sure it has been...
Hello Gerald Mayer,
Welcome, and thank you for using FixYa!
To answer your question: You will need to re-install the Nimcard Express software for the scanner to work properly. It is needed as the OCR software for the scanner. If you need a newer version, there are plenty of them to choose from on eBay!
Have a great day!
Dec 01, 2011 | Plustek OptiCard 610
MC70 Barcode Scanner: how do i enable linear scanner on my symbol mc70...
What you need to do is install a scan utility to enable your scanner. The following postings are old anyone is still having issues?
May 14, 2010 | Symbol MC70 Barcode Scanner
DR-9080C Extremely Slow
Change your USB port and Cable and Try. Buy a good quality USB cable, this makes some difference.If even after this the speed is (s)low, check if there is some virus on your Computer or try on a different computer.
S. Mohan, India
Jul 02, 2009 | Canon DR-9080C Path-Through Scanner
Hi, I'm writing a php page to be used on the MC9090 and I want the laser to be activated when focus is on a specific input box. Seeing as I'm new to the MC9090 scanner I don't have a clue where to start....
I'm not sure if you can trigger the scanner based on a web field but you can just enable the Data wedge software which will allow the scan to input anywhere you have the cursor. The scanner will be "active" all the time but won't actually scan until you pull the trigger. You can download the datawedge software from www.symbol.com.
May 19, 2009 | Symbol MC9090 Barcode Scanner
The software cannot communicate with the scanner (Prime Film 3600
I have a PrimeFilm 1800u. When I attempt to scan into a Roxio application, the program does not respond. The hardware and software are both installed. No problems scanning or communicating with this scanner before. Is there somethere there that has a soultionfor this problem ? Thanks
Mar 16, 2009 | Pacific Image PrimeFilm 3600u Film Scanner
How can enable Barcode Scanner ??
You have to use a program which will activate the scanner.
You can use DataWedge, which will send the scanner input to whatever has focus: https://docs.symbol.com/KanisaPlatform/Publishing/968/KB100417_f.html
Sep 30, 2008 | Symbol MC9090 Barcode Scanner
Software and hookup problems with dell vostro 400
Add a pci parallel card such as this to your vostro. www.tigerdirect.com/applications/category/category_slc.asp?CatId=512
This will enable you to connect your scanner. Tiger direct will give you closeups of the connections on the interface card so you can check you have the right one.
Mar 22, 2008 | HP Scanjet 5200c Flatbed Scanner
Computers & Internet Logo
103 people viewed this question
David Payne
David Payne
