Question about Samsung Digimax S800 Digital Camera
Samsung S800 My camera fell yesterday and now it won't turn on.The zoom does not extend.All I hear are three beeps and thats it.The batteries also became very hot after it fell because I forgot to take them out.What to do?
If the camera fell on it's lens it is probably jammed. Try to find something small, strong and thin, possibly a hairpin and slide it into the barrel while gently trying to force it outwards immediately after switching it on. When it does extend, try to clean or blow out any grit that may be inside the mechanism. The batteries are hot as your camera does not switch off and may be remain on for hours
Posted on Mar 02, 2008
My s800 camera wont turn on or it does but the zoom/lens is stuck and wont come out-it then has 3 beeps and turns off
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Feb 20, 2011 | Samsung Digimax S800 Digital Camera
My Samsung Digimax S800 Camera, when push power bottom, the camera green lite near power button and camera bleeps twice. Then turn off. Zoom len is fully extended. Chnage Battery three times.
this problem is a is usual occurrence when the camera is not well powered.
ie. the battery might not have enough charge on it or might have gone bad and require you to replacei it.
please ensure you get the battery with right voltage and wattage, the required is usually written around or in the battery compartment.
Jan 14, 2011 | Samsung Digimax S800 Digital Camera
Samsung digimax s800 not swiching on
The problem is that the lens is jammed. I had to take my camera apart to unjam mine manually, the cogs that move the lens are not lined up with each other, thats why you hear the motor turning and then you get the 3 beeps because the lens hasnt initialised
Dec 20, 2008 | Samsung Digimax S800 Digital Camera
My samsung digimax s800 won't turn on,the batterys are ok
the lens mechanism is not initialising, the cogs that move the lens are out of alignment slightly. you colud try and fix this yourself by taking the camera apart and realigning it manually, or sometimes you can get hold of the prodtruding lens and gently pull, be carefull !! you might hear a grinding noise as you pull this is just the main lens cog turning. once fully out put batterys back in and give it a go
Dec 14, 2008 | Samsung Digimax S800 Digital Camera
It wont turn on, And the zoom is extended.
I had exactly the same problem. Lens stayed open, when powered on you get three beeps and nothing. I found when I pulled the lens out a little harder it gave a little click. When I powered on it worked perfectly.
Nov 25, 2007 | Samsung Digimax S800 Digital Camera
When I try to turn on, or see pictures stored, it beeps three times and shuts off
called samsung s800 have know power problems return for replacement before warranty expires or they will charge you 58 to fix
Oct 28, 2007 | Samsung Digimax S800 Digital Camera
Jammed camera
A temporary fix to power up is to press the menu and power button at the same time. When the lens is extended and it beeps, on my camera , the lens is *stuck* Give it a gentle tug , then try the power button again
Oct 19, 2007 | Samsung Digimax S800 Digital Camera
3 beeps and nothing else
just three months old?- return it to the Vendor for replacement and get onto the Samsung Tech support Team
Jul 10, 2007 | Samsung Digimax S800 Digital Camera
Samsung Digimax S800 Digital Camera Logo
71 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
