Bt 1800hg Hi i have pc downstairs,but want to put another pc upstairs,how do i set it up so the one upstairs can connect to the internet aswell.Thankyou.Jayne
I hove lap top and pc in my home
now i need to connect wierless network
with DSL service
Posted on Dec 12, 2008
  • 37 Answers
You'll need a way for your computer upstairs to connect to the hub/router. You can most likley get away buying a low priced wireless USB adapter like this one. http://www.newegg.com/Product/Product.aspx?Item=N82E16833340004
If your router has wireless security (such as WEP Encryption) you'll have to know the (WEP) key and SSID of the device in order to connect.
Posted on Feb 23, 2008
Hi, I have a digital tv plugged into an extension cable in an upstairs (Toshiba) bedroom; it works perfectly - receiving all channels. I have a digital tv downstairs (Samsung) where it seems the wall...
Hi Fiona
Somewhere along the line from the aerial there must be a signal splitter that feeds the upstair and downstair terminals.
Try to find that splitter and switch the output to see if the problem goes from up to downstair.
If it does switch then you know the problem is with the splitter block, and if it stays the same then the problem is with the cable and/or the connectors that run downstairs.
Also the reason you get a pixellated(snowy) picture is because of signal loss during the length of the cable you ran downstair.
If running a cable downstair becomes the best option to fix your problem , then you could buy a cheap 10db signal booster/r.f amplifier to correct the signal loss and a cable splitter to feed both tv`s
That booster would be installed upstair in your case(near the source of the signal to be amplified).
I could send you a small diagram if need be. Hope this will help and Merry Chrismas
Dec 14, 2009 | Televison & Video
Trying to connect a wired network wirelessly to a router
No. You'll need to run a "cross-over" Ethernet cable from one of the "LAN" ports on the "downstairs" router, connecting to the "WAN" port on another router that you will need to buy, and place "upstairs", and connect the 4 devices to the 4 "LAN" ports.
Or, run a long "straight-through" Ethernet cable from your DSL-modem (or cable-modem) that is "downstairs", and move your wireless router "upstairs", and connect the 4 devices to the router's "LAN" ports.
Your laptop "downstairs" should still be able to connect (wirelessly) to the wireless-router that is "upstairs".
Sep 16, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
2Wire 1800HG network disconnecting.
it may be tha one is acting as a server, When he turns his on or off you are losing the connection, try hooking them up in a different configuration, or leave his on when you are online instead of turning it off and on
Mar 27, 2009 | 2wire 1800HG Router (RG1800HG00)
D-Link DIR-628 router, i've lost internet connection to the PC!
Did you use MAC ardress filtering to grant ps3 access to router?
if so you have to do the same with your cpu's wifi mac adress
Nov 21, 2008 | Computers & Internet
Lost internet connection to my 2nd wireless p.c
Suggestion: Move your router. Your PC 3 appears to be in a 'dead zone' so to speak.
Nov 19, 2008 | Computers & Internet
You would be best to buy a wireless router with a built in modem, this would be much easier for you to setup and manage
Nov 16, 2008 | D-Link AirPlus DI-524 Wireless Router
1800HG ROuter + Home Network
Rather than try and explain how to set things up here (would be a rather long answer!)... follow the links below ;)
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Go here for instructions on setting up printer sharing
http://www.home-network-help.com/share-printer.html
go here to setup file sharing
http://www.practicallynetworked.com/sharing/xp/filesharing.htm
Aug 30, 2008 | 2wire 1800HG Router (RG1800HG00)
Connection keeps going on and off
check the ip addresses with the pc downstairs and see if all the pc's have the same default gateway. If not check your network card or network cable.
May 24, 2008 | Linksys Wireless-G WRT54G Router
Ive got a 40gb ps3 and a bt home hub wireless router how do i connect ps3 to computer ps ps3 is upstairs and pc downstairs
look on the back of your home hub. there should be a Wireless Key in a Grey box. (BT Home Hub wireless settings)
note the wireless key.
go to your ps3. and turn it on log on ect. go to settings and down to network settings (right at bottom).
(Im not sure of the next section because im currently on a network but it should be an option to find network).
anyway you search for networks. should find your home hub.
keep going right untill you have to enter any settings. and write your WEP Key (Not WKA). (wireless key from back of router).
Jan 10, 2008 | Sony Playstation 3 (PS3) Console
Computers & Internet Logo
150 people viewed this question
Alun Cox
David Payne
David Payne
