Testimonial: "Brilliant thanks for the guide!"
SOURCE: nokia 6600 keypad problem
u have to replace the crystals behind these keys. otherwise replace keypad ic near chargung connector...
SOURCE: i need a restriction code of nokia 6600 fold
HI
A restriction code is numeric code (password) that prevents a user from accessing certain technical settings of a phone. It is specifically designed to prevent a phone from being reprogrammed to work with a different carrier (service provider).
This is what is usually meant when a phone is referred to as "locked". There are also "unlocked" phones that can be reprogrammed to work with a different carrier.
The reason for this system is the way phones are often sold. Many phones are sold below cost, (at a loss to the carrier,) with the expectation that the money will be recouped in the cost of the monthly service plan. The up-front loss that is later recouped is called a Subsidy.
For this to work financially for the carrier, the user must not buy the phone and then use it with a different carrier. The MSL makes that nearly impossible.
Unlocked phones are ususally much more expensive than locked phones, because there is no subsidy to offset the cost.
You should ask the operator for the restriction code
ENJO! RATE THIS SOLUTION
RNJ VINOD KUMAR
SOURCE: how do you remove battery from Nokia 6600 fold
At the back panel of the phone you ll find cover and a sign to press and remove.
