Question about Epson Stylus CX3200 All-In-One InkJet Printer
Printer it wont print propley gos over the edge of paper and it makes a lot of noise dont think the settings are right, its two years old the manual is in a diffrent langage
    Scholar:
  • 142 Answers
You need to find the website for your brand of printer -- they will have the manual there or Google the name of your printer to find the manual. Follow the instructions carefully --it sounds like you need to set it up starting with step one and follow it all the way to the finish in order to make sure what the problem is. Take your time and once it is set up it will be worth it.
Posted on Feb 23, 2008
Hp cp3525 printer makes clicking noise when printing and start up
  • Make sure the paper type levers are set right in the tray. When loading paper this can get moved and the printer will think it is picking up bigger paper than is actually loaded and it will click.
  • Locate the fuser, usually just before the paper exits and it should be easily accessable from the back panel. Remove the fuser and inspect the gears, they will get chewed up and may need to be replaced. A good sign will be a lot of white dust which is bits of the gear itself.
Jan 13, 2013 | Vizio Xwr100 Dual-band Hd Wireless...
Tip
How to make duplex copies with a Brother MFC-240C printer
The Brother MFC-240C is a well-performing multifunction color printer. There is a lot that it can do, but one limitation it has is the inability to make double-sided copies. If you need to make a duplex copy of something, you can do it manually by re-feeding the paper once you've copied the first side.
After the first side of the page has been printed, let the paper sit for a minute or so to make sure the ink has dried. Then, put it back into the paper tray on the top of the stack. Make sure the back side of the page (the side that has not been printed on yet) is facing down, and the lead edge of the page (the edge that was fed out of the printer first) is facing toward the inside of the printer, rather than toward you.
Once the paper is set, push the tray back in and print the document or image that you want to appear on the back of the page. If you are printing multiple pages, position the paper so that the page you want printed on first is on the top of the stack.
The MFC-240C was not designed for duplex printing, so you may run into some issues with it, especially when you are using very thick or very thin paper. With very thin paper, the ink may bleed through to the other side of the page. With very thick paper, you may have to let the paper sit for a longer time after the first side is printed, because the ink could take longer to set and dry.
on Jul 06, 2010 | Brother MFC 240C All-In-One InkJet Printer
I bought a new Oki C610 a couple of months ago to start up a custom art business. From the beginning, the DCT 4.5 paper has stuck to the fuser roller. With the first fuser cartridge, it just dog-earred on...
Hi my reply was too long heres the second half..and ill retype the first as a comment
Try printing lighter prints, heavy toner saturation causes paper to stick to fusers and try to keep leading edge of print blank with no big blobs of colour for the same reason, ensure page sizes are set correctly in driver and machine tray settings and dont print outside margins , if you are about to print outside margins your printer driver should warn you, dont click ok if it does
Here is your user manual for your oki. and a link to oki print drivers to suit 610
Here is a link to Magic touch Australia that i thought has some good info re transfer paper use
Ensure your printer works ok with plain paper so we know it aint a printer fault but I'd say it due to how we are feeding the paper and how we have the paper type set and not feeding out the rear as I also think we should be.
Oki does the best colour prints nice and glossy, I dont think many come close to such great colour prints in fact I only like Oki and Kyocera stuff in Colour toner laser machines. Stear clear of cheap non oki toners and supplies because they cause heaps of issues and wreck printers and give many print quality issues, I dont work for OKI directly just telling you how it is in the field ;)
Let me know if you need more help and how you go
Cheers
Steve
Nov 05, 2011 | OKI Office Equipment & Supplies
Problems printing to Brother MFC 8660DN printer
Pull the paper tray, likley a small black lever to the left of the roller called the edge actuator is dislodged and hanging down. When in position the actuator should easily push up and appear flat next to the roller.
Dec 09, 2009 | Brother MFC-8660DN All-In-One Laser...
What are the best settings to use for printing photos? I have tried using the glossy paper but it comes out very dark. I have cleaned the print head, and I ran the test thing and it was fine. My other...
The paper issue is personal but as general glossy paper will damage the head aas it leaves wax on it and you may try jus any paper that you like starting from light weight to 25% as far as the print location it is the setup on the computer not the printer, try to use cheep paper and try few setting tell you getr the correct setting for the printer also make sure that when you put the papers the sides are close to the paper and sopporting them good so they do not move
Nov 08, 2009 | Brother DCP-110C All-In-One InkJet Printer
My HP 2420 is taking so long to print a document. Seems like it pauses between each page rather than printing at it's normal rate. Any suggestion?
This could be a problem with the memory in your computer too many programs running at once. Go to start then click run in the box type msconfig this will open a system configuration box click on startup and uncheck programs you don't need running DON'T STOP the firewall or virus checker. Most programs don't have to run they will start when you click on them. after unchecking the ones you don't need running click apply and press OK your computer will have to be restarted and when it starts back up put a check mark where it says dont show me this message again. You could try more memory and always clean out unwanted trash and old files the link is below.
http://www.ccleaner.com/
Aug 14, 2009 | HP LaserJet 2420 Printer
Right side of text doesnt print
Many of these wont' print edge to edge but there may be a setting for it. start>printers (might be in control panel in yours) slect properties for the printer and advanced proterties then printing preferences (specific to your printer) and see if there are any settings. many of these have a 3/4" blank are down one side where it feeds the paper. try to rotate the print 180 (in your print settings) if possible.
Apr 28, 2009 | HP PSC 2175 All-In-One InkJet Printer
I have a Konica 2223 copier - wont print on edges
check all edge settings .f28 is code for charger corona just clean corona assembly with cerosene oil and change corona wire with new one.
Dec 16, 2008 | Office Equipment & Supplies
Phaser 860 Printer posting a paper jam at start up.
Sounds like printhead needs replacement.
Moving these printers without cool down is known to destroy printheads and of course wax goes everywhere and then everything else fails.Think about replacement
Jul 02, 2008 | Xerox Phaser 8400 Laser Printer
Epson Stylus CX3200 All-In-One InkJet Printer Logo
21 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
