Question about Technics SA-DA10 Receiver
Technics SA DA20
Sorry All, DUH ME! Still having the same problem (overload) BUT the reciever is a SA DA20 NOT SA DA10!!!!! Sorry for the blunder!
  • Sanj02 May 25, 2008
    I also have a Technics SA-DA20 Receiver. I am getting an Overload error. I checked the speaker wires and am now out of bright ideas. Anyone have any?
I have a Technics SA DA20 control receiver. I was given it by an electronics workshop and it has this same error of OVERLOAD coming into the display when switched on. I removed the plates from underneath and re-soldered as far as I could all the points along the stereo amplifier ICs and as far as access would allow. The unit then worked normally for several hours. I was very pleased, and went out shopping!. But on my return after it had been off for about an hour, the same problem has come back. But my boss at the electornics workshop thinks it it just a dry joint, or series of dry joints. The unit is complex to dismantle, so patience and care is required in taking it apart and making a note or diagram of how it comes to pieces and how to re-assemble it after the board has been re-soldered. It does not appear to be a component problem or fault with the SVI power amplifier ICs.
petertaussig33@hotmail.com
Posted on Jul 13, 2009
When I try to hook speakers to my Technics SA-DA20 Amp. it overloads speakers. what can I do to Solve this???
Check speakers impedance and compare it to amp minimum suggested output impedance rating, may be that's your issue.
Oct 03, 2013 | Audio Players & Recorders
My amp says overload whenever i plug speakers in to it. its a Technics SA-DA20
Check your wiring. Make certain there's no breaks and the two parts of the cable do not touch each other.
If it still says the same with good wiring you have probably developed a fault in the main amp. A failed transistor etc, located on the big heat sink.
Oct 03, 2013 | Technics Audio Players & Recorders
Hi, my amp keeps cuttinf off and showing the overload sign with a clicking sound.
The audio amplifier IC´s are in short circuit need to be replaced
Sep 13, 2010 | Technics SA-DA10 Receiver
My Tchnics Sa-Da10 shuts down on what appears to
Ahh technics. Technics always had overheating problems, trust me. Every since they started, their amps would get so hot they would hurt to touch. The reason the fan is not coming on seams to be something inside the circuit board. I'm sure that technics could fix this. If the fan works out of the receiver, then it must not be the fan. ;P
I would maybe get a computer fan, and just put it on top of the receiver and turn it on, or send it in for fixing. Also, do you have to crank the volume to get the speakers to play at your volume, and does the impeadence match the receiver. Because you may be pushing the receiver too hard.
Oct 11, 2009 | Technics SA-DA10 Receiver
Which port do I plug in MP3? aux or phono. This is a Technics Sa 200
You'll want to use the AUX, because it, for sure, does not have any RIAA equalization, which the phono input may or may not have.
Short answer: Plug the mp3 player into the AUX inputs.
Mar 04, 2009 | Technics SA-DA10 Receiver
Technics SA-DA10 jumps into overload after 10 minutes
Have you tried connecting speakers? What was the result?
Yes, when you turn the volume up on these amps (or when the output gets past a certain level) the cooling fan should automatically come on.
Oct 14, 2008 | Technics SA-DA10 Receiver
SA DA -10
If all the speakers are connected proper and it still says "Overload!!!!!"
Your output amplifier module is most likely failed.
Mar 08, 2008 | Technics SA-DA10 Receiver
Overload on Technics SA DA10
Cracked solder joints due to excessive heat cycling. Do not place in a shelf system. Top MUST be open for 1 ft. or better for proper convective cooling effect. Mine suffered same fate but repaired locally.
Feb 23, 2008 | Technics SA-DA10 Receiver
Technics SA-DA10 Receiver Logo
1,388 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
