Question about Toshiba 1370 Black and White Copier
Shows error code of c5 on copier
We just replaced the lamp on the coier and now it is showing error code c5 and it makes noise. Thank you very much for your help
Iron on top of the drum unit is fault replace it with another one it work.
Posted on Feb 23, 2008
Crafft. What is error code H3?
MY SPLIT AC IS SHOWING "C5" ERROR CODE. KINDLY HELP ME PLEASE.
THANKS
Aug 26, 2015 | Heating & Cooling
Its a WD-52631 Rear projection TV. I have sound but no picture. The lamp is still good the problem is somewhere in projecting the picture onto the screen. I have done all the resets i can do and sometimes...
Hi Mark,
First of all thank you for posting your question here at Fixya.
You've mentioned that you can hear a slight grinding noise. This noise came from either a faulty color wheel or fans. To isolate where the fault came from, first I would advice you to access the "error code operational check". This is a built-in software that log and give an equivalent error code by means of blinking LED to determine the exact caused of the symptoms.
How to access the "Error Code Operational Check".
1. Turn on the TV and wait until it automatically shutsdown.
2. Pressing the front panel "Input" and "Menu" buttons at the same time, and holding for 5 seconds, activates the Error Code Mode. The Timer LED flashses denoting a two digit Error Code.Example, if the error code is "42" the led will flash 4 times pause and flash 2 times and it will cycle for a total of 5 times.
Please let me know what is the error code.
If you can't access the error code mode because the TV didn't gone to shutdown. I would advice you to open the rear panel of the TV to pinpoint where the grinding noise came from.
1. Remove 8 screws (A) from the external input frame.
2. Remove 10 screws (B) form the rear cover.
3. Pull the rear cover from the TV.
Tape the lamp cover switch to closed position like on the picture above or else the unit will not turn on.
Your TV has a 3 fans :
1. DMD fan
2. Lamp fan
3. chassis fan
If the grinding noise came from the fan(s) you have to replaced it. All fans have the same part no. 299P312010
However if the noise came from the optical engine assembly, you have to replaced it part no.938P059050
Jdvillanueva
Dec 19, 2011 | Mitsubishi WD-52525 52" Rear Projection...
For Model: URC517MP - Can you clarify Error Code C5
Hi ess0,
The Amana error code F5 means that you have a failed Electronic Range Control (ERC. The only way to resolve this problem is to have the Electronic Range Controller be replaced. You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Thank you for using FixYa.
May 31, 2011 | Amana RC17 Microwave Oven
Minolta EP2100 Copier - Error Code C5
Mite try amozon/craigs list for parts, The machine is legacy system
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jun 15, 2009 | Konica Minolta DiALTA Di200 Copier
Error C5 and large noise in Amana RC22
hi my name is mark, that code stands for current sense.CS the following is a list of the possable things it could be. 1. interlock sw. 2.open thermal cut-out 3.open/loose wire 4.power relay 5.H.V. board 6.diode 7. magnetron 8.capacitor 9.transformer 10.triac it is worth fixing. RC22s are very expensive ovens if you need part #s i will need the serial # and P# [P132....M] to get correct parts. hope this helps. thaks for your question.
Mar 06, 2009 | Amana RC22S 2200 Watts Microwave Oven
Minolta ep 2151 D has C-5 error code
If you look at the fuser heatting lamp and it looks like a cande cane it is blow. You will have to replace the lamp to reset the code. You may also need to change the thermal fuse and or the thirmister as well. They all deal with a c5 error code. If I remember correctly there is a trouble reset botton on the back of the copier, it is on the main controler of the copier it is a small "Black" botton. You will have to take the back covers off to get to it. I believe a c8 has to do with the scanner power cable getting stuck. It has been about ten years since I worked on one. Good Luck
Jan 28, 2009 | Canon imageRUNNER C3220 Color Copier
Minolta EP2030 shuts off immedietly when I power it on
Do you see a error code? Like a C5? Try holding the power botton on and look for a code that shows up on the display. You may have a blown heater lamp or scanning lamp. You are losing your AC power some where.
Jan 22, 2009 | Minolta EP1083 CS/PRO Copier
Replace a lamp on a photocopier
Hello, the C5 code will only show up after the C7 code -- Fuser temp. to low. First put a meter on the Thermal fuse and the Thermistor and see if it is blown. The fuse and thermistor are under the black ( usually) fuser cover which runs the lenght of the fuser. If the fuse and /or thermistor are blown, replace. The lamp will not come on if the fuse or thermistor are blown. If the fuse and thermistor are good then take the end cap off of the fuser ( usually 1 screw) and disconnect the brass (usually) from the lamp. Check the lamp ( continuity), is the lamp okay. If not replace the lamp. If all of these are good then check the Solid state relay unit ( usually in the lower right hand side looking at the back of the machine with cover off). If the relay is good then you have to replace the PWB-A, the main board.
Jan 12, 2009 | Office Equipment & Supplies
Popping noise, about once every 24 hours, no change in sound or picture.
DID ANY ONE CLEAN THE MIRROR AFTER BULB WAS REPLACED EVEN THOUGH MIRROR ON INSIDE IT WILL STILL HAVE A HAZE FORM ON IT NEEDS TO BE CLEANED FROM TIME TO TIME
Oct 24, 2008 | Sony KDF-42WE655 Television
Error code on a T-A TA215Z copier.
C5 is a Main Charge Wire Error. Either the main charge wire is broken or the plastic blocks are arching out.
Open the front door, and look for a gray handle that will slide out towards you. This is usually located above the drum.
The main charge wire is a very very thin wire that charges the drum in the copy process. If the wire is broken, no copies can be made. To make sure that this is the problem, leave the charge stick out, and close the front door and let the machine warm up. If it does, then you have located the problem.
If it still show a C5 error, the the problem is in the Transfer Charge coronas which is located under the drum.
Let me know what happens, and I can try to help you further.
Good luck.
Mac
Mar 16, 2008 | Office Equipment & Supplies
Toshiba 1370 Black and White Copier Logo
200 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
