Question about AOpen AK77-8XN Motherboard
Computer will not boot to desktop
I installed a SATA pci host card on my Aopen AK77-8XN because there are no SATA sockets on this motherboard. When I boot, the SATA drive is recognized, however the next screen gives me the options to boot to safe mode, boot windows normally, last known configuration, etc. When I choose an option the computer locks up and will not continue. I have been in the BIOS to check boot sequence, and I have tried all combinations with no success. I have an Athlon XP 2600+ processor running Windows XP Professional SP2, 1.5GB of RAM and a 550 watt power supply. The latest Bios is installed. Please help.
    Novelist:
  • 77 Answers
1. Unplug the SATA drive and see if you get a desktop then.
2. If so, then go to hardware/device and look for PCI sata card.
3. If it is listed, check the details, copy down and post here.
4. If it is not listed, see if it is listed under computer management/hardware/devices or in the "problem device" or "conflicts" tabs. Post any mention here.
5. While I wait for your reply/you wait for me to catch it, you should also try switching the card to another PCI slot. Sometimes, with new technology added to older boards, the slot ID is important.
Posted on Feb 24, 2008
  • Dana Stienheimer
    Dana Stienheimer Feb 25, 2008
    I am waiting to see your results. As a second thought, be sure your IDE hard drive is compliant with this new arrangement. It may need to be set as "slave" in order for this rather unorthodox arrangement to work. Last, it is also entirely possible that your IDE hard drive itself is the problem. Its ROM might preclude any possibility of accommodating this arrangement, if it remains as the active/dominant hard drive. The wisest choice is always to dedicate the newest drive as a default operating system. To do that, you need only set master/slave jumper appropriately, and start from the WinXP CD-Rom, and install a new OS on the SATA. This will also assure that the most recent drivers are installed, for SATA drives (I doubt that has been done already). Post your IDE name/mfg and model, please.
Upgrade hard drives on 670
There is a 2TB limit with MBR (Master Boot Record), but even a larger drive can be partitioned. So a single 4TB (biggest on the market) drive will look like several drives.
External drives that are bigger than 4TB are really several physical drives combined by an array.
RAID 1 requires optional SCSI drives, cables, and even software?
http://support.dell.com/support/edocs/systems/ws670/en/ug_en/before.htm
Add on SATA 3 cards to PCI are not a good idea if you are looking for speed. They just bottlenecks the throughput.
Oct 22, 2012 | Dell Precision Workstation 670 PC Desktop
I have a rebuilt computer with various parts, when it would boot up it would just come to a black screen where I could see my muse and move it but only had a black screen. I was told to unplug everything...
test all leads that attach to your hard drive including electrical extensions SATA
the leads from your ((motherboard to your hard drive)) Sata make sure they have a secure connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty ?
even something as small as an electrical extension or a faulty fan lead can cause this problem
a computer needs all of the data and electrical current to travel through every working device and to have an end for a computer to be able work properly
make sure your graphics card is securely seated with no dust in its socket
if you physically remove your graphics to check the socket card restart your computer this should activate found new hardware wizard
hope this helps
Sep 19, 2011 | AOpen AX4SG-UN Motherboard
I have a MSI-7309 motherboard and I was wondering if there was a pci card that I could get to give me more sata connections then just the 2 that I have filled up.
Hello there,
Yes there is it should look like the image below. They call this raid card or simply PCI SATA card it sells for $15 -20++.
There are a lot to choose from, consider your requirements some cards do have e-sata or IDE. it also comes with one 18 inch sata cable. Use up to 4 SATA I or SATA II Devices using this SATA I Speed Host Adapter, since PCI Bus is not Fast Enough for SATA II Speed if you wish to save money this card will provide you with access to all four SATA Ports at 1.5GB/s per port. Use New 1TB Western Digital Seagate or Hitachi Drives with your older PCI Based computer. supports up to 2TB of Hard Drives.
Hopefully this information helps.
Thank you for using FIxYa.
Aug 14, 2011 | Intel Motherboard
Have a d530c tower how do you add a sata drive?
Hi richo64
It seems your motherboard is not equiped with Sata plots :
http://h18000.www1.hp.com/products/quickspecs/11632_na/11632_na.HTML.
If this is the case , you need to purchase a PCI Sata controller card with at least one internal Sata plot .
Disconnect power plug and make sure you are not static electrically loaded . Open tower by removing side panel . Install PCI card on an available PCI plot inside your tower . You will also need to acquire a Molex/Sata converting power cable and a Sata interface cable . Once done , install your Sata drive in an available place in your desktop and connect the cables .
Start your pc . If you have kept the old Pata drive in operation , immediatelly and repeatedly hit a F key ( often Fi or F3 or F8 , it depends on the machine ) to acces bios , select the Sata drive and fix the boot priorities .
Sata controller cards and cables are easy to find by googleling on the net or in any computer shop .
Best regards ,
fanaudi .
Jul 23, 2011 | HP Compaq d530c PC Desktop
Is it compatible to use a sata hard drive
Not without a host card like this one: http://www.newegg.com/Product/Product.aspx?Item=N82E16816102065
You don't have any SATA ports on your motherboard. You can use a host card to add those ports in, if you have a free PCI slot.
Have fun and good luck.
Mar 01, 2011 | ASUS P4B533 Motherboard
How to connect a sata cable to pcv-rs420
There are no SATA headers on the motherboard. (Connector on motherboard is a Header)
You have 1 AGP slot for a graphics card, and 3 PCI slots, (White in color)
You can however, buy and install a SATA adapter card in one of those PCI slots. (The computer comes with a modem adapter card in one, of the PCI slots, therefore you may have two PCI slots that aren't being used)
This is Sony Support, and the main page for the Vaio PCV-RS420 Desktop PC Computer,
http://esupport.sony.com/US/perl/model-documents.pl?mdl=PCVRS420
Under the heading - Specs, you can click on - Marketing Specifications
(PCVRS420)
This tells you the Expansion Slots you have, ( 1 AGP, and 3 PCI)
(Plus other specifications)
In case you do not have the User Manual anymore, you can download it by clicking on - VAIO User Guide - under the Manuals heading.
(Shows how to open the computer case, among other information)
This is an example of a SATA adapter card with internal SATA headers, and external e-SATA ports,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4350464&CatId=508
Any additional questions about this, and I'm right here.
Regards joecoolvette
Dec 12, 2009 | Sony VAIO Digital Studio PCV-RS420 PC...
My Computer did not access Western Digital Hard Disk, Model No. WD 1600 AABB Caviar SATA.
Good morning! Please make sure that the drive’s power and SATA cables are properly connected. If the Serial ATA host adapter card is installed in a 64-bit PCI slot on the system motherboard, move the card to a 32-bit slot.
Verify that only one power cable (either SATA or legacy) is connected to the drive. Check to see that the power connector and SATA interface cable are securely attached and that the
SATA host adapter card is properly seated in the PCI slot.
The Serial ATA interface connects each drive in a point-to-point configuration with the built-in SATA port on the motherboard or with the SATA host adapter card; therefore eliminating the master/slave relationship as required with EIDE. Each drive utilizes its own
cable for data transfer rates. Jumper settings for Western Digital Serial ATA hard drives are mainly used for enterprise storage environments.
Most third party controller cards and RAID adapters are recognized as a SCSI device under Device Manager. This is normal and will not affect your drive or system performance.
To verify if the Serial ATA drive is recognized by the system, Right-click on the My Computer icon, select Properties, left-click on the Hardware tab, and click on Device Manager in the window. Double-click on Disk Drives. Your new Western Digital Serial ATA drive should be listed as a "SCSI Disk Device" or "Serial ATA Disk Device." If not, make sure that all cables are securely attached and that your system BIOS has been properly configured. regards
May 12, 2009 | Computers & Internet
New Build PC not booting
do you get any onscreen information like a bios screen?
Feb 22, 2009 | Gigabyte GA-M57SLI-S4 (4719331821180)...
Motherboard
Most of the new systems and motherboards support SATA connectors onboard. In your case there is none as you have found. So the best option is always upgrading to a new motherboard in case you need to add more SATA drives. You can also try to find SATA add-on cards, may a little costly types. These cards use PCI interface and very easy to install but hard to find one. I hpoe you could find one from a hardware store near you. If your motherboard has ordinary PCI slots then the SATA adpter will be less costly, otherwise (if it features a PCI-X slot) it will be costly. Following is a simple description on what the market has to offer: SATA II - 150 4Ports PCI-X with NCQ, Raid 0+1, Raid 0 and Raid 1 ! You can upgrade your desktop computer to have four Channels Serial ATA Generation 1 and Generation 2 transfer rate of 1.5 Gbps. The board provides a 64bit, 133 MHz PCI interface on the host side and four, fully compliant Serial ATA ports on the device side to access Serial ATA storage devices such as hard disk drive, ZIP drive, CD-ROM, CD-RW, DVD-ROM. Note: Fault tolerance: RAID 0 (Striping), RAID 1 (Mirroring), RAID 0+1 (mirrored-stripping) and RAID 1+S (Mirrored-Sparing) improve the data performance and provide the data redundancy and rebuilding.
Oct 09, 2007 | HP Pavilion 513n (P9850A#ABA) PC Desktop
AOpen AK77-8XN Motherboard Logo
93 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
