Question about Technics SA-DA10 Receiver
Overload on Technics SA DA10
Went to turn on my stereo, OVERLOAD displays. I power off, power back on, OVERLOAD appears. I unplugged the reciever, waited 10 or so plugged back in, STILL getting OVERLOAD message? Can anyone offer any solutions to this? So frustrating!
Cracked solder joints due to excessive heat cycling. Do not place in a shelf system. Top MUST be open for 1 ft. or better for proper convective cooling effect. Mine suffered same fate but repaired locally.
Posted on May 27, 2009
  • Technics Master
  • 5,568 Answers
This is an old message so you may not be interested any more.
There are a couple of possibilities; the high power of this unit seems to fry speakers fairly often and although they mostly fail 'open,' they can overheat causing the voice coil to lose its insultation and cause a short instead.
This may also be caused by the failure of one or more output modules causing the power supply to limit and give you the overload indication.
If an output module has failed and the unit is not limiting current, it may destroy speakers too.
Some knowledge and a decent meter would reveal the nature of the failure pretty quickly but describing the steps necessary to troubleshoot this is a little beyond the scope of this forum.
Posted on Apr 23, 2008
My technics av control stereo receiver sa-g76 keeps shutting off(overload). can you please advise on how to avoid this situation?
Is there anything on top of the av receiver? Try and run the reciever so that it has enough cooling. B) Allthough overload, there is a possibillity it is causes by speakercables who are shortcircuiting once in a while. Usually somewhere at the back of the reciever or speakers.
Apr 24, 2014 | Audio Players & Recorders
My Technics AV Control Receiver SA AX530 is in overload
An amplifier should never be turn on without speakers, it will overload internally.
make sure speakers work and try again.
Dec 04, 2009 | Technics SA-AX530 Receiver
My Tchnics Sa-Da10 shuts down on what appears to
Ahh technics. Technics always had overheating problems, trust me. Every since they started, their amps would get so hot they would hurt to touch. The reason the fan is not coming on seams to be something inside the circuit board. I'm sure that technics could fix this. If the fan works out of the receiver, then it must not be the fan. ;P
I would maybe get a computer fan, and just put it on top of the receiver and turn it on, or send it in for fixing. Also, do you have to crank the volume to get the speakers to play at your volume, and does the impeadence match the receiver. Because you may be pushing the receiver too hard.
Oct 11, 2009 | Technics SA-DA10 Receiver
Overload at medium (4-6) volumes. Can you adjust or disable the overload protection on these Technics amps??
try this mate:
http://www.electronicspoint.com/googlesearch.php?cx=002919058480771089906%3A03mranmmdze&cof=FORID%3A10&ie=UTF-8&q=Technics+SA-GX550&sa=Search#862
May 23, 2009 | Technics SA-EX400 Receiver
Technics SA-DA10 jumps into overload after 10 minutes
Have you tried connecting speakers? What was the result?
Yes, when you turn the volume up on these amps (or when the output gets past a certain level) the cooling fan should automatically come on.
Oct 14, 2008 | Technics SA-DA10 Receiver
Technics SA-G9057 overload
Check the fan connections at the back. The connections (just two flimsy metal prongs) came apart (I believe), so I have had to re-enforce them with electrical tape so the connections stay together until I investigate a further replacement fan. For now the connections are extremely sensitive to motion/viberation/impact/etc... but it does work now.
Sep 23, 2008 | Technics SA-EX300 Receiver
SA DA -10
If all the speakers are connected proper and it still says "Overload!!!!!"
Your output amplifier module is most likely failed.
Mar 08, 2008 | Technics SA-DA10 Receiver
Technics SA DA20
I have a Technics SA DA20 control receiver. I was given it by an electronics workshop and it has this same error of OVERLOAD coming into the display when switched on. I removed the plates from underneath and re-soldered as far as I could all the points along the stereo amplifier ICs and as far as access would allow. The unit then worked normally for several hours. I was very pleased, and went out shopping!. But on my return after it had been off for about an hour, the same problem has come back. But my boss at the electornics workshop thinks it it just a dry joint, or series of dry joints. The unit is complex to dismantle, so patience and care is required in taking it apart and making a note or diagram of how it comes to pieces and how to re-assemble it after the board has been re-soldered. It does not appear to be a component problem or fault with the SVI power amplifier ICs.
petertaussig33@hotmail.com
Feb 23, 2008 | Technics SA-DA10 Receiver
Overload
internal wickman fuses blown check speakers high unts tweeters\ gone short primary transistors /ic blown
Dec 31, 2007 | Technics SA-DX940
Technics SA-DA10 Receiver Logo
1,133 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
