Question about HP LaserJet 2430dtn Printer
Printing My hp laserjet 2430 won't print,its stays is printing mode but does not print and the data light keeps flashing????
  • Matt Jurach
    Matt Jurach May 11, 2010
    is it connected by USB, or by a network cable?
Network cable,Thanks
Posted on Feb 28, 2008
    Master:
  • 555 Answers
Usually this means the internal print queue is in an error state.
To clear the error and refresh the system settings, power cycle the printer. Either turn it off and then on with the power switch, or you can do it remotely using the printer's built-in web console.
Also try printing a test sheet from the printer itself. Press the "Menu" button, then select "Information" and then "Print Configuration"
If there is an internal problem, the test sheet won't print. But if it is just a data problem, it should be clear.
Posted on Feb 29, 2008
Where do I load the original to be copied on this printer. I don't have the manual.
Here's a few links that might help you with the printer in general.
The HP LaserJet 2400 Series Manual - This covers 2410/2420/2430 HP LaserJet Printers. I uploaded it to my dropbox and this is the shared link for the .pdf file.
HP Laserjet 2400 Series Software Manual - 2410/2420/2430 LaserJet Printers
Here's the HP2400 Series Software Manual - I've also uploaded this to my dropbox account.
HP LaserJet Printers - Steps to Print Manual Duplex Using the Application Settings or HP LaserJet Driver Settings
Aug 31, 2013 | HP LaserJet 2420 Printer
Our Data light keeps flashing and the printer won't print. How do we get the data light to stop flashing so we can use our copier again with our computers?
Sounds like a bad print job stuck in a print spooler.
Turn off copier. Go around to all computers that print to it and open the print queue. delete all print jobs. reboot each PC. Power up copier and see if it clears
Jan 15, 2013 | Sharp Mx-M450nb Digital Copier
PC communicates with my HP laserjet 1020 but paper does not seem to pull through and wont print and orange fault light flashes then stays on
nothibg to warry about it just check tonner if its ok then do the servicing and also see for the paper jam chek may be ther e inside paper was jamed yeterday
Jun 07, 2012 | HP LaserJet 1020 Printer
HP LaserJet 2600N All colors are empty, but Black is brand new. It still says Replace Supplies and the light keeps flashing. Oh, and it won't print anything. So even if I want just B&W, do...
None of the cartridges can be empty if you want to print.
Even if you only want to print black, just black you need to
replace the other three cartridges.
Yes color laser printing is expensive.
Jul 14, 2011 | HP Color LaserJet 2600n Printer
Green horseshoe light is continually lit
If it is solid on, it means the printer is ready to print; no action is required. If it's flashing, it means the printer is processing data and should print soon.
If you are printing from your computer and nothing comes out, with the "Horseshoe" light staying solid, I suggest checking the connection between your computer and the printer, or at least the printer configuration. Most of the time, unplugging, then plugging cables back in does the trick.
Jul 06, 2009 | HP Color LaserJet 2550n printer + HP Color...
HP laserjet 2430 dtn little typed letters print on the left side
Probably a bad FUSER. The teflon is probably worn off.
Also take out the toner and move the drum cover aside to look at the drum..It should be clean.
Feb 17, 2009 | HP LaserJet 2430dtn Printer
HP Laserjet 2200 Keeps Spewing Out Blank Paper
sounds like it has a solinoid that is stuck open.
Dec 16, 2008 | HP LaserJet 2200D Printer
LaserJet 2430dtn printer
Have you checked the settings on the printer's menu. It should be under paper handling.
Jun 13, 2008 | HP LaserJet 2430 Printer
HP LaserJet 2430dtn Printer Logo
362 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
