Printer Printing blank page issue can be occurred when you have low or dried ink cartridge, blocked nozzles, dirty print head and ink cartridge installed improperly. Follow the troubleshooting steps to fix printer printing blank pages:
·Restart the printer ·Check printer ink cartridge ·Clean the printer print head ·Update the printer drivers
Have you checked the print que
Printer problems can be a real hassle.
From time to time, due to document layout or settings on
your computer, in your software of choice, or even on your printer, a blank
page may get "printed" with the rest of your document.
Fortunately, this issue is a simple one to troubleshoot.
Click "Print Preview" when you are finished with
your document and ready to print.
Observe your document.
If you see an extra, blank page, you have
created a second page.
To delete the second page, close Print
Preview, go back into the document and eliminate any blank lines in your
documents that you may not need.
You may also find an inadvertent page break at
the end of your document.
Place your cursor on its symbol and delete it.
Locate the symbol by clicking on the Show
Formatting paragraph icon in the toolbar.
Circumvent this "ghost page" if you do
not see a second (or additional) blank page in Print Preview.
Specify the number of pages you wish to print,
within the Print dialogue box.
This is typically done by selecting the
"Print From" option, then entering the page numbers desired.
If your document happens to be ten pages
(without, of course, that final blank page), then enter in the "Print
From" field the numbers "1-10".
This will print only pages 1 through 10,
without an eleventh (blank) page.
There is an option in the print driver to print a separation page (typically just a blank page unless you specify otherwise) so that each person's print jobs can be differentiated easily.
This option probably got enabled somehow on her PC. Have her go into the print driver's properties (right click on the Canon in the list of printers and select Properties) and look for the option that says separation page or separator page and deselect it. Then click Apply or OK, and it should be good.
hi,check your printing setting and then print.
or....
uninstall the printer then install the printer again then printer has default setting and print the paper.
sometimes printer current pages print wich is selected by setting.you must select all the pages.
to change the setting,,,
1-open control panel then open printers and faxes then check seeting.
Try checking the ink cartridges and make sure they have ink in them or it will keep printing blank pages. Then try printing a test page by going to control panel, clicking on printers and faxes and right clicking on your printer and going to properties. Then go all the way down to the bottom of the page and click print test page. It will clean the printer cartridges and align them to print correctly. It should work after that.
> unplug the usb cable from the computer
> click on "start--> control panel--> printers and faxes"
> select the printer icon associated with your printer and delete it.
> now plug the usb cable to the printer
> wait for few minutes while all the drivers are installed.
thats it... now try to print... it should be resolved
