Question about Canon EOS-1Ds Mark II Digital Camera
Hot shoe loose
Camera hot shoe metal plate has come loose, causing intermittent problems firing flashgun.
  • akp169 Feb 23, 2008
    Thanks, you've just saved me two sixty mile round trips and £40 at the camera repair shop and I wont have to hire a body to get some work done in between.
  • Anonymous Apr 05, 2009
    Thanks for the tip.  I used your advise to fix my 1ds mk II with the same problem.  It took 5 minutes and two small screwdrivers.  I think it saved me a hundred bucks and loss of use for a week and a half.  Thanks again.
    From California, USA.
  • 667 Answers
Canon typically hides the screws under the metal plate on the shoe itself. You have to free it at the front and slide it back to get access to the screws holding the shoe
Posted on Feb 23, 2008
  • Kevin Pettit
    Kevin Pettit Feb 23, 2008
    Excellent, be pleased with the fact you have a Canon. Nikon puts their retaining screws for the hot shoe on the inside. Cheers
Brilliant Saved me £120 fee at fixation in london.
As a little more clarity:- the cover over screws is quite thin and there is a small hole (2mm diameter) in it: centre towards the front of the camera. If you insert the sharp object in that hole and gently lift and slide the cover off to reveal screws.... you will need mini phillips screw drivers as they are small screws....... took about 3 mins to fix.
Posted on Feb 24, 2009
I had the same problem and fixed it within a few minutes' time. I'd like to clarify the process a bit, however. To "free it at the front," it's best to insert small sharp object and LIFT a small amount. Then slide the thin metal plate backwards to reveal the four tiny screws. My 580 EX II now fires properly. Thanks very much!
Posted on Dec 02, 2008
How do I stop down my flash on my olympus E410 so its not so bright when I use it.
I just saw a picture of your Olympus and it is clear it isn't fitted with a flash but a variety of flashguns can be fitted to the hotshoe bracket.
A standard flashgun has a fixed flash and must be diffused or bounced if it needs to be toned down.
There are programmable flashes available but these are more suitable for manual cameras.
A model-specific computerised flashgun can communicate through multiple contacts of the hot shoe with a computerised camera and should provide the flash duration/intensity to suit the camera's settings.
Maybe your flash isn't fully compatible with the camera.
Dec 17, 2017 | Olympus Cameras
The foot on the hot shoe mount seems to be broken. I'm sure I can replace the part myself, but where can I find it?
You need to do some work on the web because you did not give us the make and model. Try these links they should get you started.
Konica Minolta Camera Repair Parts
USCamera com distributors of spare parts for digital film and video...
The foot on the hot shoe mount seems to be broken sure can replace the...
Samsung Galaxy Note 4 Rear Facing Camera Lens Cover and Bezel Fixez com
May 29, 2016 | Cameras
The internal flash on my canon eos 60d camera won't pop up
On the hot shoe when you fit a flashgun it pushes two tabs down to disengage the pop-up flash some times the tabs don't fully return after flashgun removal
Jan 17, 2016 | Canon EOS 60D Digital Camera
Nikon fm manual
A sync cord between the camera and the flash is usually more reliable than the hot shoe. Before getting a cord though try cleaning the contact in the middle of the hot shoe and the contact on the bottom of the flash with an ink pen eraser. They are more aggressive than a pencil eraser but still won't hurt the metal contacts.
Nov 26, 2017 | Vivitar Cameras
Does not have a flash shoe but has a red M snd a
The M is for flashbulbs, the X is for electronic flash. Sorry, but it won't sync with flash powder :-)
I don't see a manual for the FT, but I found manuals for the FTN and the FT2 at
Feb 18, 2010 | Nikon Nikomat FT 35mm SLR Camera
Vivitar 285 HV won't fire
If you know basic soldering, Open the old hot shoe from base
(4 screws).Note down the position of the wires.
Try to fire the flash with shorting two trigger wires,most ly it will fire.
If the springy contact is adjustable do it.If it is not repairable, you can get metal hot shoe from ebay easily.
Caution: metal hot shoe will short circuit 4 TTL contacts (on digital camera) ,so you need to put cello tape at bottom of hot shoe with only center hole.
Hope this solves.
May 12, 2009 | Vivitar 285HV Flash
Olympus e510 hot-shoe doesn't respond...
Have you tried cleaning the hot shoe contact? If the contact is dirty it may not communicate with the camera. The "contact" Its the metal "circle" in the middle of the hot shoe. Using a pencil eraser, rub the contact gently until you create eraser crumbs, then gently rub the "circle" with a soft cloth. See if this fixes it.
Mar 11, 2009 | Olympus Safe Hot Shoe to PC Sync Flash...
My flash won't charge. the yellow charge light won't go off when the camera is charged. The flash will pop open but won't flash. I have purchased and installed a new battery but it didn't solve the...
Either the internal thyristor charging circuit has failed or the flash capacitor is unserviceable.
Neither fault is worth repairing. Buy a small auto-exposure flashgun and use it in the hotshoe; they're dirt cheap and there are plenty of used ones for free if you ask on FreeCycle.
You'll need to go into the DSC-V1 menus to enable the hot shoe on the top plate of the camera and you'll find that even the smallest and least specified flashgun will give better results, but try to get one with at least two aperture settings within the range f2.8 to f8. Anything outside that range is useless to you as that's the entire aperture range on the DSC-V1. You'll also need to ensure that when taking photos, the camera is set to the same aperture as the flashgun. To do this set the camera mode switch to "A" for aperture priority mode and use the thumbwheel to select the correct aperture, the camera will choose the appropriate shutter speed. You can also use "M" for manual mode in which you set both the aperture and choose the shutter speed. At night, choose 1/60 but the actual exposure will be measured in the thousandths of seconds in which the flash is illuminated.
If you're rich or lucky you'll get a Sony HVL-F32X flashgun; it dwarfs the camera and is very powerful but everything is fully automatic with no manual overrides. For this flashgun, the hotshoe menu setting must be "OFF".
Nov 20, 2008 | Sony Cyber-Shot DSC-V1 Digital Camera
Flash attachment for Minolta SRT 101
You can find flash units on e-bay at a very reasonable price.
Nov 18, 2008 | Photography
Vivitar 3200 Flashgun and Canon EOS 400D
Using Vivitar 3200A flash gun on a DSLR is risky for the following reason. The trigger voltage of a DSLR at flash hot shoe that takes it to its TTL (through the lens) circuit is less than 10 volts, it is about 6 to 8 volts in the recent DSLRs. The trigger voltage generated by Vivitar 3200A at full charge flashing is around 180 volts (max). That is a fatal dose for a sensitive DSLR TTL circuit. This high voltage flash gun will work endlessly, the only damage is to the TTL flash circuit. When you attach a TTL flash to the DSLR after using Vivitar 3200A for sometime, your TTL flash will not communicate with your camera. It will be just another ordinary flash without any auto functions. There is a Wein adapter that you can fix b/w your cameral hot shoe and the vivitar flash gun that is said to reduce the trigger voltage that passes into the camera. Try it if you get it. Without this gadget it is better not to use non recommended and non TTL flashes on latest DSLRs.
Apr 13, 2008 | Cameras
Canon EOS-1Ds Mark II Digital Camera Logo
228 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
