Samsung HP-S5033 PLASMA 50-INCH HDTV Pixels Stay on...
There is a line of pixels at the bottom of the screen that is about 2 inchs wide that always stay on.They seam to be mostly white & black.I noticed they do go away when you run the burn in removing funtion that this set has.Sorry for the poorly formated post here!
  • Pinballdan Feb 23, 2008
    Thanks for the info! Now i'm just afraid of what they will want to fix the module :-( but will have to give them a call!
  • johnwiencko Oct 15, 2008
    what fixed this problem thanks john 858 578 2568
  • 616 Answers
3246247
Posted on Jul 07, 2010
Its looks like a dinky
Posted on Mar 24, 2008
    Problem Solver:
  • 11 Answers
Call P.T.S. Elecdtronics at 1-800-844-7871 and give them the model # . They will tell you which module to send to them to repair and the cost to repair it. Ask for technical assistance which is location # 3, #1 is customer support. I guarantee they can fix and they have a 90 day warranty on the module.
Posted on Feb 23, 2008
Lg 60ps40fd green line 1mm or about 2 pixels top to bottom
this problem is for bad contac in the flex conector, this can not be repair, you need change the display.
Mar 29, 2014 | LG 60PS60 60 in. Plasma HDTV
Samsung 63 Inch TV 1080p Plasma HDTV line across screen
You have dead pixels , It may cost more to fix than getting a new tv, ill recommend calling samsung and talking to them to see if your still under warranty. Thanks -JC
1-800-SAMSUNG (1-800-726-7864)
Mon - Fri: 8am - Midnight (EST)
Sat - Sun: 9am - 11pm (EST)
Oct 11, 2013 | Samsung HP-R5072 50 in. Plasma HDTV
I have a LG DU50PX10C with a black vertical line
Plasma televisions have anywhere from 24 to 40 drivers that control the individual rows of pixels comprising the screen. Should any of those drivers fail, the screen will display a 2 or 3-inch black vertical line, and probably shift the image to one side or the other. Driver failure is considered a manufacturing defect, and is not preventable by the owner. In some instances the line can be caused by faulty pixel ribbons that run top to bottom, either faulty of just loose in their connectors etc.
Then there are Stuck Pixels, Pixels become "stuck" due a failure to turn on from its standby state. Occasionally, these pixels die in rows, spanning the full height or width of the screen, or be only a few inches long. These "dead" pixels can turn on randomly, or stay a different color other than black. This is an issue caused from the wire filaments inside the panel failing, or an offshoot from a driver failure. Impact to the screen can cause a row to stick as well, even if there is little to no external indication of damage.
However, in most cases, inspection by an engineer is usually necessary to diagnose exactly what has caused the fault, unfortunately this can be an expensive prospect, not to mention the potential for a painful bill for the repair alongside the inspection fee. If your TV is in its warranty, don't hesitate to claim on it.
I hope this helps you, or at least gives you a better idea of what you potentially could be facing. Good Luck.
Jun 17, 2012 | LG 42PX5D 42 in. Plasma HDTV
Samsung HPR4272X/XAA has 2 black bars going from top to bottom.
I really do not know there is the "Stuck Pixel Fixer programs" I think that Program Breakdown another IC. For this issue is absolutely the Plasma display panel have problem. You shall exchange it.
Apr 17, 2010 | Samsung HP-R4272 42 in. Plasma HDTV
Samsung 50 in. HPS5033X/XAA colored lines running vertically and won't go away.
How wide are the lines. Do they change width? Where on the screen are they located?Connections on the c boards at the bottom to the panel flex cables or bad c board itself can cause 2 inch wide verticle bar. Before touching these connectors be sure power supply is disconnected from the 2 sustain boards on the sides. If you don't there will be an arc that will destroy the flex cable thus you will have to replace the panel. If C boards or connections don't fix it the replace the plasma panel. If the lines are thin lines then panel is likely bad. Contact Panasonic even if out of warr they may help.
Dec 06, 2009 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Horizontal Lines when Viewing HD TV
Would you please change the picture mode 4:3 or scan fit to 16:9?
Nov 19, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Samsung hpr4252x perfect picture in
You have a burn in problem from watching widescreen movies.If you have access to a signal generator or tv setup disc run a perfectly white screen on the plasma for about 30 min.This should help even out the pixels on the display.
Mar 05, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Line in center of screen
if the line is about one inch wide you may have a chance that the address board has failed, if it is only 1 pixel wide then there is a really good possibility that the plasma panel itself if bad, this set had a 2 year warranty from samsung, you might want to give them a call,,they are very customer satisfaction oriented
Nov 28, 2007 | Samsung HP-R5072 50 in. Plasma HDTV
Televison & Video Logo
443 people viewed this question
Top Televison & Video Experts
