Yes it is very good to have a transformer for your pc and most specially to your monitor...it will prevent to much current that may hit your computer...
but for me i suggest that if you are willing to buy much reliable unit.. you can buy a ups (uninterrupted power supply) it is very useful most specilly if you have experience power failure in your location it will give you as much as two hours power of your computer...it is like rechargiable battery....you can finish your work even if it is brown out..
Hello, most common faults, such as CRT TV will not turn on. The reason stems from the low power supply failure, or from the high power supply. There are two transformers suppliers, with more common high-tension transformer goes bad. Price of 80 or $ 100, sounds reasonable replacement of transformer. Along with this need to perform some tests that require a professional, to confirm that the problem is due because of transformer. One test is to test basic stability, voltage power reaching the high-voltage transformer. If lower than normal voltage. Then perform the same test, when you break the initial snap of the transformer. If the voltage rises to the desired level must be to replace the high voltage transformer. Good luck!
