Question about Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television
Replaced bulb. Still doesn't work.
Hey,
I just replaced this TV's bulb with a brand new one, and when I press the on switch it blinks green for a second and then blinks red; no picture or anything. What can I do?
  • 927 Answers
Make sure the lamp is seated properly, the lamp cover/door is in place, unplug TV from wall outlet for 4-5 minutes, plug back in and try again.
Posted on Feb 23, 2008
    Sergeant:
  • 261 Answers
Make sure the safety switch or the lockout switch is not activated. Usually near where you opened up to replace the lamp. Sometimes the switch is visible and other times it isn't. IF you can see the switch, manually hold in and see if set turns on then. IF it does, you have just solved your problem. IF it doesn't it could still be a bad power supply or better known as a ballast powersupply. Listen for a buzzing sound. That is better know as the powersupply trying to fire up the lamp. If u hear that it is most likely good. Also, Keep in mind, that the new lamp could be bad!! Just because it is new, Doesn't always guarantee that is GOOD. Try these things and get back with me. Good luck....GURU JAY
After replacing bulb on WD-82738 still not working
How to replace the lamp in your Mitsubishi TV - YouTube
? 3:13
https://www.youtube.com/watch?v=_ONPuB5L-x4
Nov 1, 2012 - Uploaded by Mitsubishi3D
Your Mitsubishi television is powered in part by a 180 watt lampthat illuminates your TV's vivid colors. ... The first time they delivered my TV it was broken. ... I just barely got myreplacement bulb in today and it still only blinks orange light. .....I was watching my mitsubishi 73 3d model wd-73740 and ...
After replacing bulb on WD-82738 still not working - Fixya
www.fixya.com/.../t26028385-after_replacing_bulb_wd_82738_still_no...
6 mins ago - after replacing bulb on WD-82738 still not working bulb went out and burning smell. Replace the bulb, turned it in - Mitsubishi WD82738 82 ...
Mitsubishi WD-82738 Blinking Green Light - Tom's Guide
www.tomsguide.com/.../id.../mitsubishi-82738-blinking-green-light.html
Jan 12, 2015 - I have a Mitsubishi WD-82738 with the blinking green light of death as I have seen it called. ... Sounds like you replaced the parts, and it still is not working.... It would not work for us if we did it after the blinking. ... overnights. an ive already t akeing out the bat Forum; blinking green light changed bulb help!
Amazon.com: Mitsubishi WD-82738 DLP TV Asse
Dec 29, 2015 | Mitsubishi WD82738 82 1080p 3D DLP Home...
Heard a pop , bulb blew out , replaced bulb , it worked for two days , now red light blinks three times pauses then three times and so on , tv won't turn off light won't turn off unless I unplug...
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
Oct 26, 2011 | Sony KDF-E42A10 42 in. LCD Television
Magnavox tv when the power button is pressed the green light comes on but nothing else happens; there's no picture or sound or nothing; but the green light simply stays lit (no blinking).
first, press the channel -/+ button on the TV. If that doesn't turn on the TV, then it means you have to replace the bulb of your TV. The bulb is most likely dead.
Replace the bulb and your TV should be restored.
Let me know if you need further assistance.
Regards.
Aug 12, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Lamp went out & replaced it but no picture. Sound comes on!!!
you have a safty switch open most likely on the door you took off to replace lamp
Feb 03, 2010 | Toshiba 62HM95 62" DLP HDTV
Sony Wega KF-42E200A Projection Bulb
New bulb is just fine.
3 blink shows that lamp cover after replacement of bulb in TV is not fixed properly or not seated well in its position.
Put new bulb and carefully place back lamp cover in its position because lamp cover will press tinny safety switch inside that will send signal to system control of TV that lamp is installed properly.
Turn On TV and get vivid picture of Sony.
Thanks.
Oct 17, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
XL 5200 bulb replace and NO Picture or Sound
3 times blink error code shows Lamp Door is not seated / fixed properly, please recheck it and make sure that door close safety switch is pressed as this switch sends error signal to system control chip.
May 30, 2009 | Sony KDS55A2000 55" HDTV
My tv sony kds-50a2000 dont tur ON
I have a Sony KDS-50A2000 50 in. HDTV Television. I just replace the lamp because I got the message that appeared on the TV. Lamp needs to be repaced. I replace with a Sony lamp and now TV cut off after 2 to 3 hours off watching the TV. Any Idea what is going on with this TV
Jan 02, 2009 | Sony KDS-50A2000 50" HDTV
Panasonic PT-50LC13 Power Light Blinking Yellow
My Panasonic PT-50LC13 when turned on has a green light for a few seconds you can hear the fans turn on and then you have a yellow/amber light that starts to blink 8 times i have replaced the bulb and the door is closed any ideas?
Apr 01, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Sony 55" rear projection tv
TIGHTEN THE BULB --AFTER YOY CLEAN THE DUST OFF THE BULB VENTS ON THE BULB ITSELF. PROBLEM SOLVED. EASY--CHEAP. Hey it worked for me. My picture was turning off blinking 29 times for picture 37 times for audio. This was the first issue with my KDF-55WF655 since I unwrapped it almost 5 years ago......... ITS STILL ON!!! I hope this helps someone.
Feb 14, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television Logo
120 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
