Question about NetGear WGR614 Wireless Router
Wireless connection i changed my computer my netgear wgr614v6 will not let me connect
  • 1 more comment
  • Anonymous Feb 23, 2008
    I recently had to do a Recovery to my laptop. I can not find where to enter my ip address for my wireless router. I can only get internet by plugging my cord directly into my computer from my cable box/router.
  • JLew5120 Feb 29, 2008
    I am having a similar problem and was wondering if someone could provide me with a solution. I have a WGR614 wireless router. My computer had a virus and I had someone rebuild the operatinig system. I have the computer back and cannot get on the internet through the wireless connnection. An icon used to pop up and I could choose among wireless connections. Do I have to reinstall the router software?
  • John  Savage
    John Savage May 11, 2010
    Potts19,
    Can you go into a little more detail of exactly what you mean by "changed my computer"
    Guest,
    You can enter the IP address for your router by right clicking on the icon for your wireless NIC, going to properties and double (left) clicking on internet protocol (TCP/IP) there you should be able to either select an automatically assigned address or enter one manually.
    J
  • 37 Answers
JRSavage - The solution you supllied is to assign the IP address to the client. It appears Guest is asking how to log into the Router.
Guest - If the router is a wireless router then you should not have to know it's IP to connect to it, simply looks for it's SSID in WIndows Zero Config wireless util (or the util that came with your wireless adapter)
If you're connected and looking how to log into the router itself you'll want to enter the router's IP address into the address bar of your internet browser.
If you're looking for where you enter the router's IP for NIC configuration, you would enter the Router's IP as the Gateway address.
Posted on Feb 23, 2008
I can not connect to my netgear wgr614v6 with my hp netbook. I can connect with my other laptop and the netbook has been connected before. It keeps saying "acquiring Address"
If you're trying to connect wirelessly, and it says "acquiring address" and never connects, it's most likely because your wireless network has an encryption key enabled, and the encryption key on your laptop/netbook doesn't match. You should disconnect from your home wireless network, and then try to re-connect to it. Verify that you're using the correct wireless key to connect. If that still doesn't work, you should reset your router to factory defaults so that there's no wireless key required to connect - and then try again. If you want to put the wireless key back, you can run the CD or connect to the router using the web interface and configure it again.
Mar 07, 2010 | NetGear WGR614 Router
A random guy came in and setup a home network for us using a Netgear Wireless router (WGR614v6). We have a PC on main level, an iMac and laptop in the basement that connect wirelessly and without any...
Hi whioch computer has a problem ?
A PC with the new hard drive ?
Mkae sure that you have the wireless adapter working on the computer.
If it is working then try to find the network .
Click Here for more info about wireless network.
Oct 08, 2009 | NetGear WGR614 Wireless Router
ITouch not connecting to wireless
Do you still got your manual? If you do go to the back and find your page that has a number for your apple ipod type, then they should be able to help you with your probelm. If you don't have it, go to your ipod website and type in there search box WGR614v6. Then it should have help or support or firmware and it should fix it. Hope it works.
Aug 26, 2009 | Apple iPod touch
Netgear wireless router wgr614 not transmitting
Yes changing channel will make a diffeence most of the time for this kind of issue. The reason is there could be multiple routers or interference in that area locking to the same frequency.
Aug 01, 2009 | NetGear WGR614 54 Mbps Wireless Router -...
Unable to factory reset - all port lights stay on with just power cable plugged in
All port lights showing on a router indicate a bad control board in the router. I'd say it's toast.
May 25, 2009 | NetGear WGR614 Wireless Router
Router (WGR614v6) Secure Connection Issues
you need to remove the connection saved.
after securing the wireless router, before you try to connect. Go to
-Control Panel
-Network Connections
-Right Click your Wireless Adapter
-Click Wireless Network Tab
-Remove The Network
Then Try to reconnect.
Feb 11, 2009 | NetGear WGR614 Router
Netgear WGR614 v6 router drops connection
Hi, what ISP are you using (aol,tiscali...?), and how are you connecting to the router? Wired or wireless? I had similar problems with mine, it wouldn't connect or would drop connection, or loose all the settings. I updated the firmware to the latest from here:-
http://kbserver.netgear.com/products/WGR614v6.asp
Be sure this is the correct model as firmware differes from model to model.
Then I had to manually configure my ISP settings etc. Or you may have software from your ISP which configures for you.
Hope this helps.
Jan 22, 2009 | NetGear WGR614 Wireless Router
The microsoft wireless adapter on my Xbox360 does not connect to my wireless network
How Can I connect a network adapter from my room to downstairs about 20 yards away?
I need XBOX LIVE badly, everyone has it cmon FIXYA help me out on this.
The router downstairs is a TalkTalk modem help me!
Jun 28, 2008 | Computers & Internet
Block code
I am assuming by code you mean Encryption key. Use a computer already connected to the router, open Internet Explorer. Type in 192.168.1.1 enter the user name and password. user is usually admin and the password is usually password. You will see a wireless security link. If it doesn't show you the key, you can just make a new one and type it in all the computers as doing this will change the old one.
Jun 04, 2008 | NetGear WGR614 Wireless Router
Netgear Wireless Router WGR614v6
so chitodel click on start button
then CONTROL PANEL>NETWORK CONNECTIONS> right click WIRLESS CONNECTION>PROPERTIES>in GENERAL tab click on INTERNET PROTOCOL>PROPERTIES and then click OBTAIN AN IP ADDRESS & OBTAIN DNS SERVER ADDRESS AT LAST CLICK O.K. this will help u try it now..........................
GOOD LUCK.
Feb 06, 2008 | NetGear WGR614 Wireless Router
NetGear WGR614 Wireless Router Logo
91 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
