Question about Hoover S3330 / S3332 Straight Suction Telios Bagged Canister Vacuum
Cord rewind The power cord is jammed and won't go in or out. I can't find a way to get the cover off to have a look at it. Any suggestions please?
  • 3 more comments
  • iaindart Feb 24, 2008
    Hi Liz
    Its a Hoover Telios. There doesn't seem to be any screws to get the outer shell off.
  • Anonymous Mar 12, 2008
    I Have the same problem: the cable is on the side of the cord winder, but I cannot open the shell to see i something is broken or if it's only a cord jamming.
    How can I open the shell? I found only two ***** inside, but does not release nothing...
  • mekirstin Mar 17, 2008
    Help! i have the same problem here in the netherlands.... how can i open it!!!! once i have it open there must be a way to get it working again....
  • wendy mortimer Jul 04, 2008
    i have a hoover sprinter 1700w the cord won't rewind and this is what is stopping the vacuum from working, i wiggle the cord it works then it stops, is it worth repairing or can i do it myself..or is it knackered.?
  • TradJ Apr 23, 2009
    Hoover Telios 1700 It really worked out!! Thanks, J from portugal
    President:
  • 389 Answers
A bit late for the original questioner, but perhaps this will help someone else.
There are many models of the Hoover Telios. This solution applies to the T5603 at least, but perhaps not to all models... sorry, I don't know about the others.
Anyway, this is it. The cover is held to the base by 8 screws. Two are clearly visible near the handle, two are in the bag compartment. They are easy!  The problem is finding the others, because they are concealed by the foot-operated switch plates, and you have to get those plates off without breaking them.
Basically, those plates slide off backwards (i.e. away from the handle end) but you have to release a plastic catch first.  The catch is part of the switch-plate, and is located roughly mid-way along the straight side of the plate, just by the raised bump.  You can just see the catch if you shine a torch light down the gap.  The catch is released by inserting a small screwdriver or other flat blade and levering it away from the centre-line of the machine.  If you apply gentle rearward pressure on the plate while doing this, you will soon feel when it's released.
Once the catch is released, the plate will slide off completely and the remaining four screws are revealed.  After that, it's simple!
Hope this helps someone!
Posted on Feb 07, 2009
Thanks odin223. I had tried for hours to get the cover off my telios 1500. With the above info I had it solved in 10 mins! Wish I checked the plug first though! The reason the Hoover wouldn't trun on was a broken wire in the moulded plug.
Posted on Sep 27, 2009
  • 75 Answers
If the cord winder is broken it needs to be replaced. What type of vac is it?
Posted on Feb 23, 2008
How to rewind the power cord assemble?
The only way to rewind the cord assembly is to take the cord real out of the vacuum and rewind it and put it back in. There is no easy way to do it
Apr 29, 2014 | Miele S514 Solaris Electro Plus Vacuum
My cord wont rewind
The rewind tension spring may be broken or fully extended. Try to yank hard on the cord and pull toward you with some force. Pull until the line will no longer come out and if it won\'t recoil then it needs to be repaired.
Apr 01, 2014 | Electrolux Vacuums
Cord won't retract or pull out
No, but we have a great network of warranty repair centers. You can find one near you at this link:
Jul 03, 2013 | Bissell PowerGroom Helix Rewind Bagless...
Power cord will not come out
There is probably a crossed cord in the rewinder. I am not sure but if you can get into the rewinder you can free up the cord it should go, hope this helps. Chris
Feb 07, 2011 | Hoover UH70120 WindTunnel TSeries Rewind...
Cord rewind hoover s3765
Remove the 5 Phillips-head screws carefully without stripping the heads. There are 2 at the front bottom, 2 at the top back (above the wheels), and 1 at the back beneath the dustbin. After the screws are loosened/removed, you can remove the top cover of the vacuum (be careful with the attached wiring harness). Then remove the black plastic cover over the cord rewind wheel, and you can easily remove the wheel. Pull the cord out a bit to give yourself some slack. You should be able to free the jammed cord and then reassemble the vac.
Nov 14, 2009 | Hoover S3765-040 WindTunnel Bagless...
Automatic Cord Rewinder is not rewinding anymore
I had the same problem - the power cord for my Hoover Elite Upright (U5507900) was stuck a few inches out and wouldn't go any further. But when I unscrewed the rewinding mechanism, the cord had clearly gotten twisted and partly buried under itself so after some work I was able to free it. Now it seems to be working fine, at least for the moment. Note that I had to use small screwdrivers to unscrew the cord rewinding compartment, like the kind of screwdrivers you use for computer repair.
HTH!
May 27, 2009 | Hoover Elite Rewind Bagless Upright...
Hoover s3639 vacuum...cord does not rewind
I had the same problem with my Hoover s3639. The cord rewinder started squeaking, and retracted less and less of the cord each time, until it finally stopped retracting the cord at all. Here is what I did. I hope it will work for you as well. Open the covered tool storage and remove the tools. You should see three screws. Unscrew the screws. Remove the cover. You should see the motor for the vacuum and the cord rewinder. Between the vacuum motor and the white wheel where the cord is, you should see two brass wheels that turn into each other in order to operate the cord rewinder. Spray a small amount WD-40 between the two brass wheels. This should solve your problem.
Dec 29, 2008 | Hoover S3639 WindTunnel Bagged Canister...
Power cord won't retract on anaerus 5500 vacuum cleaner
What you can do is take out the six hex screws on the bottom of the machine while on it's back. When all the screws are out, flip the machine back over, making sure you don't lose any of the screws. From there, open the bag cover and leave it open. Remove the cord release button. (The big rectangular button near the rear of the machine. Usually a firm pull up will get that thing out without incident.) Grasp the handle with one hand and hold the machine steady with the other. With a firm pull, pull upwards. This should seperate the chassis from the main cover.
With the machine guts exposed, place the main cover on the side for now. Now, this next part you can do one of two ways. You can either leave the cordwinder wires attached, (there's only 2 connected wires to the cordwinder, the white and black. Black is on the inside prong while the white is on the outside) or you can take the wires off. I find it easier to disconnect the wires.
Now, remove the cordwinder from it's place, making sure you take note of how the cordwinder rests in the groove from the motor. From there you can rewind your cord fully. Once this is complete, continue winding the cord while holding the cord in place. Take note of the spring. Make sure you are winding in the direction that is TIGHTENING the spring. Make sure you don't overtighten as the center plastic piece will surely snap due to the overtension. This may take a few tries, but be patient. Once you have met your estimated tension needed, replace the cordwinder, put the cover back on WITHOUT SCREWING IT BACK IN PLACE and replace the cord rewind button.
Replace the large cord release button and pull your cord out at least halfway. Hit your Cord rewind button. If your cord rewinds fully, congratulations, you got it in one try. Replace the screws and you are finished. If not, re-open the machine and continue rewinding the cord in the direction that TIGHTENS the spring with emphasis on overtightening. Once you break that center plastic prong, you need to buy a new cordwinder, so emphasize patience. If you're getting frustrated, go take a break and come back. Repeat until the cord winds fully, replace all the screws and you are finished.
Apr 20, 2008 | Electrolux Vacuums
Power cord retrieval
Depending on which model you have, take the bag door or lid off by pushing it back and it will unhook and come off, there are 4 screws that hold the cover on over the where the cord rewind button is, take that cover off and you can get to the cord reel.
Feb 12, 2008 | Kenmore 23313 Whispertone Bagged Canister...
The cord won't rewind anymore.
all these rewinds are a pain! the rewind mechanism is a spring-loaded coil. fault is possibly that the cable is jammed and you may be able to free it by gently tugging and releasing. otherwise there is a problem with the spring and that is not worthwhile repairting
Mar 26, 2007 | Bosch BSG81313UC Premium Bagged Canister...
Hoover S3330 / S3332 Straight Suction Telios Bagged Canister Vacuum Logo
657 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
