Question about IBM eserver xSeries 360 8686
Planar PCI device does not respond or disbale by user
Hi, Help please, i ahve IBM X series 360 Model 8686-1Rx server connected to IBM 300 Raid controller thorugh SCSI cable, this morning suddly i got the blue screen of death and when system was restarted we got error as source : POST BIOS, error code : 00180700 and error data : 9005008F planar PCI device does not respond or disable by user
please instruct me what to do
thanks
  • Anonymous May 19, 2008
    i have the same problem
  • a920 May 20, 2009
    same problem
Planar fault IBM 3550 M3
Ok, That' s a motherboard issue. You would have to replace motherboard...
Workaround:
1: Set server in minimum configuration(single processor and two RAMs)
2: Remove any PCI cards added in server
3: Turn on server check for issue
If plannar fault appear, you have to replace motherboard..
Thanks
Feb 14, 2013 | IBM x3550 Server
Ibm raid controller drivers for x series 346 server
I have a problem with x346 server i need raid drivers for windows server 2008 32 bit please if some one can help/
May 13, 2011 | IBM xSeries 346 Server
Hi I have an IBM 3400 server running 2008 sbs 64X. All I want is to monitor the raid controllers so that I can see if all is working as it should. I know the software is on the original disks but...
Welcome to fix ya
Yes you can monitor the raid controller by using IBM RAID MANAGER softwfare. Hope you are having windows platform . Click the below link and download the software.
http://www-947.ibm.com/support/entry/portal/docdisplay?lndocid=MIGR-61707
please download the file named ibm_sw_srapp_9.20-16999_anyos_32-64.iso . After download burn it into cd . Now insert the cd and install the raid manager software.
Thanks
Please vote me if you are satisfied with my answer
Apr 06, 2011 | IBM x3400 Server
If we use the server without PCI-PCIe Raiser card, it can boot into the OS. However, it cannot boot into the OS when we install the PCI-PCIE Raiser Card into the sever, and it alerts message error as...
The problem seems to be 2 things..
1.) firstly send the boot priority in the bios to HDD 0 or the harddrive connected directly to the board with the os.
2.) second thing, the Raiser Card, if it has raid Harddrrives connected via the ext. one of the raid harddrives connected to it is malfunctioning , remove and disable one at a time until u find the correct one. Or it could be the Card itself is malfunctioning.
I'm guessing here that you have a IDE card connected to the Raiser card with raid harddrives on it, One of them is malfunctioning.
Apr 01, 2011 | Dell PCI-X Riser Card for PowerEdge R200/...
When i install MS windows server 2003 in IBM x3400 server it gives me message that setup could not find any hard desk installed in your computer. guys please help me temor
Ensure drives are seated correctly and set up the RAID config.
Then on the Blue screen of Windows installation it will say "press f3 for 3rd party drivers", hit F3 (I think its F3), then insert a floppy disk with the drivers for you RAID controller, setup will then say it has found the followign drivers "your device xxx" then it should* pick up the hard drives later on in setup.
:) - RAID controller drivers can be got from the manufacturer websites.... normally.
Sep 05, 2010 | IBM x3400 Server
Need x series 226 IBM server drivers
What is is OS? Do you need the drivers for the for the RAID controller? Which variant of the 226 is it? Feel free to contact me through my website on business servers, especially if you're near Rockville, MD
Oct 26, 2009 | IBM xSeries 226 Server
Defunct drive
You could rebuild the defunct drive with the raid program on your server.
i don't know your type and model of your server.
8488 or 8648 and the model 3 digits.
for this you need serveraid manager
http://www-304.ibm.com/jct01004c/systems/support/supportsite.wss/docdisplay?lndocid=SERV-RAID&brandind=5000008
please do not update your firmware or drivers at this point if applicable.
if rebuild of a defunct drive doesnt work you'll need to change the drive. remember in a raid 5 you need min. 3 drives.
Dec 06, 2007 | Computers & Internet
Could not Copy Autoexec.bat
hi okey u have not mention which os ur installing pls go through this link it will help u much http://www-304.ibm.com/jct01004c/systems/support/supportsite.wss/supportresources?topicind=103&catselectind=0&brandind=5000008&familyind=5093441&typeind=5093452&osind=5118054&taskind=1 thanks
Aug 16, 2007 | IBM eserver xSeries 360 8686
IBM eserver xSeries 360 8686 Logo
7,120 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
