Question about Gigabyte 8VM533M-RZ (GA-8VM533M-RZ) Motherboard
Jumper setting how motherboar get power?
  • Anonymous Mar 07, 2008
    i have formatted my pc and i don no how to install sound driver. some on epls help me how to dounload this and and when i try to dounload they are asking for one registraytion key an dalos i cant find that key some one pls help m e
  • tesrap_2004 Jun 26, 2008
    JUMPER SITTING. NO POWER.........HOW TO POWER THIS MOTHERBOARD?
    President:
  • 2,351 Answers
You will need a manual for this board. There is no manual for USA. This link below is for euro.
http://www.giga-byte.com.tw/Products/Motherboard/Products_Overview.aspx?ProductID=1766
There are two power connectors. Both can be seen on pg. 6
Motherboard layout.
There is one ATX 20 pin connector just behind the Floppy drive cable connector. The second power connector is to the left of the CPU & down behind the intergrated USB. It is a 4-pin ATX_12volt connector. If either one is not connected correctly the moard will not boot. The case to motherboard connectors is located on
pg.15. F_Panel (2x10 pins Connector) & PWR_LED = (Power LED) for case.
Please use the manual as your guide.
& please vote...
Posted on Feb 23, 2008
I have a ASUS Kv SE Deluxe Rev 1.13. I had a power suply 600w wich burned and I'm trying to use a 400w. The motherboar gets on, the video card functions aswell and the hard disk too. There's no beeps at...
yes you need to reset the bios look on the board for a c mos jumper short it out or take the littel battry out also mahe shure you take the main power of aswell
Apr 05, 2011 | Computers & Internet
My bios is in german, all i need is to change my boot sequence!
Well, powerof your PC. Unplug all power cable. Then open the cabinet cover and find a battery in the motherboard. If you find it then remove it from motherboard and give one minute to resotre the bios. Set battery on motherboar with acurate polarity. You are done.
Sep 08, 2010 | IBM ThinkCentre M52 8113 - P4 551 3.4 GHz...
I got problem to input sound on g31 motherboared, please guide me how can i input sound in g31 motherboard>
The G31-M7 TE MB has a intergrated sound chip.
Enter the bios. Open Chipset. Open South Bridge configuration. Find Audio controller. This should be set to [Azalia] Save and exit the bios.
Next check JAUDIOF1: found on page 14. If you are not going to use the cases front audio and mic than there should be a two pin jumper covering pins
5 & 6 and pins 9 & 10. If you're case supports front audio / mic ports, (You can not use the front audio ports and the rear audio ports at the same). time). Once everything above is set, got to Biostar and download the audio driver software;
http://www.biostar.com.tw/app/en/mb/driver.php?S_ID=363
If you still have a problem with you're sound. Explain any actions you have taken.
Mike
Jun 06, 2010 | Biostar G31-M7 TE Motherboard
I release jumbers from motherboard 6VIA83B V:B
Go to the Gigabyte web site, follow the support/download menus and download the istructions for your motherboard. Therein you should find all jumper settings
Mar 20, 2010 | Intel Motherboard
Motherboar reconected
Remove the hood, and double check that all of the cords and wires are correctly plugged in and secure. Hope this helps, Thanks
May 27, 2009 | eMachines W3611 PC Desktop
Dear sir/Madam i have a PC 800mhzVIA , 256DDR2, 40GB, PC model is TC700 and its PS2 keyboard ,Mouse are nor working due to some hardware designing .Help me in this matter thanks
the best solution is to get USB mouse since PS2 muuse is not working. and if you cloned the system yourself i suggest you take a look at the motherboar and youy will see a jumper labelled on the board PS2 keyboard and Mouse, place the jumper in the next pin. and try and see if it will work.
Dec 15, 2008 | Computers & Internet
Im looking for the jumper settings on a compaq motherboared. its a presario 7478
hello CAVdesert,
I don't think you ever have to change the jumper settings on the motherboard.You may need to change in few cases but otherwise, changing motherboard jumper settings is not recommended.
However, if you need to configure the jumper settings for your Hard Drive, CD/DVD Drive etc, Please refer to the following document.
Jumper Settings for the Installation of Hard Disks and CD, CDRW, and DVD Drives
Oct 12, 2008 | Compaq Computers & Internet
Jumper settings
There is no jumper settings, it is just a small bridge aside the bios Chip. you bridge the two pins and power to reset cmos.
A much easier way is removing the Cmos coin shaped battery from motherboar for few seconds, and put it back, this will reset Cmos the same .
Oct 05, 2008 | Toshiba Satellite A135-S4527 Notebook
Motherboar dproblem
hi,
The CMOS battery & jumper will be placed below the touchpad buttons to view these you need to open entire laptop.
please open this part if you are good in laptop trounble shooting.
or else you can log a complaint to IBM support 1800-425-6666 (india) they will take care.
if u did some small mistalk laptop will not boot
Nov 30, 2007 | IBM ThinkPad T40 2373 Notebook
Gigabyte 8VM533M-RZ (GA-8VM533M-RZ) Motherboard Logo
435 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
