Question about Sony Ericsson M600i Cellular Phone
Battery Hi there Just to find out maybe i doing some thing wrong but i can charge my phone totally as required, but only lasts for a couple hours. I have changed batteries to see maybe there was a fault with the original battery but it keeps happening the same. What would be your advise
    Problem Solver:
  • 9 Answers
Maybe ur bluetooth remains on or u r using a lot of the phone...closing them shuld solve ur problem
Posted on Feb 23, 2008
    Novelist:
  • 142 Answers
If u have changed the batteries , that should sort the problem , but if still you are facing the same problem , just make sure that your phone is not in a low coverage area which can result i a low sigal strngth, due to which the phone starts consuming more power in order to find a signal and battery dies out much earlier than expected.
Also check that the network settings for your phone or set to the appropriate signals, it shud be automatic ideally , coz if the network setting are not set right then also ur phone will try to find signals after every now and then which would result in more power consumption.
If still the problem is not resolved, take it to the mobile manufacturer and make sure u are not using any fake batteries
BEST OF LUCK
I always charge my phone before i go to sleep and when i wake up it says it is charge but when i unplug it .. it says 75 percent what do i do??
First, every phone battery has their own required / maximum time of charging. Charging it before going to bed will over charge the battery.
Since you're getting 75% of the battery status, it means that the battery is now starting to become defective. The best thing that you may do is to buy a brand new battery for your phone.
Most brand new batteries requires 6 to 8 hours of charging. After the initial charging, the next charging will be 3 to 4 hours only. BUT, you have to make sure that the battery runs out of charge before plugging it in to the wall socket. This will make the battery life lasts long.
Thank you and good luck!
Aug 18, 2010 | Cell Phones
My battery on my iphone runs out in 2 to 3 hours. What to do?
I think you must check your charger and if ok replace your battery
Mar 31, 2008 | Cell Phones
Tip
Mobile phone battery not holding charge and going flat to quick
hi, now this is a very common problem the only thing you can try is to let the battery go totally flat and keep switching it on untill the phone wont even light up.
Then what you need to do is give it a full charge for at least 8 hours this may lengthen the time your battery takes to go flat.
Now what the shop should have told you and didnt and what they should tell you in the owner's manual and dont is that once a month you are supposed to let the battery go totally flat and then do full recharge.
Doing this will ensure you get maximum time out of the battery and it makes the battery last at lot longer before you need to replace the battery.
If after doing this your battery only last an hour or two then the chances are the battery needs replacing so if you do this just remember to let it go flat at least once a month as the battery never does a full charge due to the fact that the battery never goes totally flat so this then causes bad cells in the battery so follow those rules and your battery will last longer than normal
on Dec 03, 2009 | Cell Phones
Battery charge only lasting a couple of hours
There are little differences in the battery,they are all BR50 battery's.but some have a notch with another contact on the top side and some don't.I have found that the battery's with out the notch do not work properly in all V3's.You could also try a different charger,maybe your charger is getting weak.
May 13, 2010 | Motorola Mobility RAZR V3
Battery life dies out quickly on Nokia 6301...
if you have had your bluetooth on or have been listening to music for a long time that can drain the battery very quickly . the other problem could be if you are not lettting it die of totally then charging it the battery remembers so when you do charge it the battery dont last long . try turning your bluetooth off or just lettin your battery die off totally then charge it fully
Aug 07, 2009 | Nokia 6301 Cellular Phone
After leaving my Sony DSC-T2 camera unused for only a couple of days the battery was flat. I recharged it fully but again it only lasted a day or two. I assumed the battery was dead and I purchased a new...
If the troubleshooting section in the back of the user guide doesn't help, I sugget getting in touch with Sony and asking them if it's normal, the only thing I can suggest in the meantime, is taking the battery out while it's not in use, or recharge it a few hours before you're due to use it. Phones get like it after a few years and with technology advancing the way it is these days, you'd expect a battery life lasting longer than a week, not a day.
Things to consider:
1. When it's off, is it off or left on standby?
2. Where did you buy both the camera and batteries from?
3. When you charge it up, do you charge it up with a half charged battery or a totally dead battery?
Jul 20, 2009 | Sony Cyber-shot DSC-T2 Digital Camera
Battery not charging
Hi this problem is going to ba faulty battery i had the same problem after replacing the battery it was fine.
The problem was a couple of bad cells inside the battery but what your supposed to do to prolong the life of the battery is to let it go totally flat once a month i mean totally flat so it wont even light phone up then do full charge this keeps the cells good in the battery so remember to do this often should keep the battery lasting ages let me know if you need further assistance
Jan 22, 2008 | Nokia 3110 Cellular Phone
Battery life under 5 hours
have you let the battery go totally flat as this is recomended to do every couple of months because if you dont let the battery go totally flat this stops the battery from full recharging and will cause bad cells in the batt so i would let hte battery totally flat till it wont even light phone up then fully charge for 16 hours see if this improves the battery if not then the charger is probably over heating and cutting off so you could replace the charge hope this is some help to you
Nov 19, 2007 | Samsung SGH-D900 Cellular Phone
Samsung YP K3 only lasts for 2 hours
1. totally discharge the battery so it wont come on.
2. Charge the battery fully
3. Reset the player
Now check how long the battery lasts. If it is still 2 hours there is a problem with the battey and you will need to return the player.
Oct 29, 2007 | Samsung YP-K3 MP3 Player
Battery not holding charge
THAT IS AN ERROR ON YOUR BATTERY METER YOU NEED TO DO A HARD RESET AND IT WILL CORRECT THIS PROBLEM...*2767*3855#
Oct 28, 2007 | Samsung SGH-D900 Cellular Phone
Sony Ericsson M600i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
