Back to:
Tags:
Dell 2.8 GHz Second Processor for PowerEdge 830 Server Pentium 4  Processor Upgrade
Cpu
posted by yonapse on Feb 23, 2008
my pc freeze when i set my cpu on default. it did not freeze when i underclock it to 2.7 ghz from 3.o ghz. It is an intel e 6850. my specs are e 6850, 8800 gt oc, 2 gb ddr 2 800 5-5-5-31 . my power supply is a 550 watts psu.
Comment by yonapse, posted on Feb 24, 2008
my motherboard is p5n-e-sli
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Feb 26, 2008
Not Rated (0)
Orac13
Rank:Master Master
Rating: 83%, 21 votes
You motherboard is probably not compatible with this processor. The Intel 1333 fsb processors require a different voltage regulator than other core 2 duos. Try an updated board BIOS from the asus website. Next look for power supply issues. Make sure the 8 pin connector is connected to your motherboard, and that the PSU has enough amps to run all of your devices. Make sure your RAM is set at it's RATED Voltage and timings. Turn off spread spectrum. Reset the CMOS jumper. These processors will have thermal protection which makes the cpu underclock/volt itself when overheating. Make sure you heatsink has adequate thermal paste evenly distributed between the processor and heatsink. Good Luck
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on cpu:
I don't want to Accept this solution
Solution #2
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Sounds like a power supply problem to me. Make sure your 8 pin power line is connected to the motherboard, and also see if you have enough amps to run all of your devices. Next, make sure you have an updated BIOS from you boards manufacturer, because the motherboard might not support the new 1333 fsb processors from intel which will underclock themselves if overheated, so heat at defaults is not usually an issue. Next, make sure your RAM is set to it's rated timings and voltage. Try resetting your CMOS jumper. Good luck.
Thank You!
Solution #3
Not Rated (0)
Buschchris1
Rank:Wiz Wiz
Rating: 85%, 127 votes
Yeah, i would say the same, Try cleaning oput any dust, make sure the Fan and Heat sink are adequet for that processor.
Intell is known for overheating issues, the only way they can stay ahead of AMD is to clock there CPU's really high, often they over heat, i have this issue with my job where i work on dells all day that have INTEL CPU's they overheat.
Go o a computer store and get a quality cooling fan and heatsinkl for the type of processor youhave. Get one with a higher RPM and a larger heatsink, make sure to use the CPU thermal Grean between the CPU and the heatsink to inssure even contact.
Thank You!
Solution #4
Not Rated (0)
Eblackadder
Rank:Guru Guru
Rating: 86%, 108 votes
How is your cpu cooler? Sounds like it could be a heat issue. How long before it freezes? Will it actually boot through to the operating system or freeze on start up? If it runs for a while then freezes it sure could be overheating.
Thank You!
Can you Help with these Processors problems?
Processors
this unit was bought from a casino and the cabinet is...
Processors
hi i keep having a dialogue box appear on my laptop when i...
Processors
no trabaja y cuando llamo a att me disen que el sofware...
Processors
i have this old dell pentium III that i'm trying to...
Dell 2.8 GHz Second Processor for PowerEdge...
I have dell server poweredge 830 and install the window xp...
Loading problems.
Repair Service
Find Processor Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
