Question about Ovens
How to light our gas cooker
Weve just bought a second hand neww home stove 550 si dlm,we cannot get the gas cooker to light,the clock does not light up could this be the problem?please help!!!
    Problem Solver:
  • 14 Answers
Modern gas cookers use an electronic ignition switch rather than a pilot light to light the gas for cooking. This means you can light your gas cooker with the touch of one button instead of using several matches or a flint lighter. Of course, you still have the option to light the gas cooker by hand with matches or a flint lighter if the ignition switch does not work the first time.
1.Open the gas regulator valve by pushing it in and turning it to a low setting.
2.Push the ignition switch once.
3.If the gas cooker does not light on the first try, close the gas regulation valve for one minute by pushing in on it and turning it back to the "Off" position.
4.Open the gas regulation valve, set it a bit higher than you did on the first lighting attempt, and push the ignition switch again.
5.Light the gas with a match or a flint lighter if the gas cooker does not light when you push the ignition switch again.
Posted on Aug 06, 2012
    Problem Solver:
  • 9 Answers
Check the stove outlet properly. it must be blocked. but if u can get the smell of the gas wen u put it on then try using a lighter to light ur stove
Posted on Feb 23, 2008
I have a stoves 720ef anf for no obvious reason the clock resets to 23.59 and the oven turns off, can you suggest anything
You obviously have a power loss somewhere. The oven will not work unless a time is set on the clock. I would suggest you have problem with the feed to the cooker which an electician should be able to check it out. If anything else is wrong on the cooker, it shouldn't reset the clock.
Nov 28, 2011 | Stoves 720EF Electric Double Oven
I have a Caloric Heritage Series gas stove in which the oven will not light but the broiler does work. This stove has a analog clock and we have no idea what the model is. Please help us. Thank you,...
We replaced the igniter which I bought from the appliance repair service. We now have a working oven.
Thankyou for responding to my email.
Cheryli
Dec 29, 2009 | Ovens
How do i set the clock on a stoves 700gr mk2 double gas cooker
my stoves 700gr has stoped workin can you pls help
Dec 12, 2009 | Stoves Ovens
Manual for cooker
just wondered if u ever managed to get a manual for the stoves new home 600 si dlm ? if so,could i be cheeky and ask u to email me a link please?
thx in advance :)
Ant
flatlanderuk21@yahoo.com
Mar 08, 2009 | Stoves Ovens
How to fit oven bulb
You should have a glass cover over the bulb itself. It may either screw on or it may have 2 or 3 screws at the base of the glass to take out. Then you should be able to unscrew the bulb as you would any other light bulb in your house. You will want to replace it with another appliance bulb 40 watt. If you have another type bulb or set up in your oven let me know and we will work through it.
Feb 11, 2009 | Stoves Ovens
Fisher and Paykel electric cooker (Pepper)
No, it's the first 2 buttons on the left pushed together as well as the + or - to set the right time
Jan 07, 2008 | Ovens
Stoves Newhome GL916
The timer has broken and needs replacing
I had the same problem, we checked all the wires inside and all ok, so phoned stoves and they said that the it sounds like the timer as this is the first port
Replaced the timer and cooker is now working fine - only thing to remember when ordering the timer - my cooker is green and now has a red light instead of green
Hope this helps
Cost of timer from stoves £56.83 inc vat and delivery
Oct 28, 2007 | Ovens
Ovens Logo
464 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
