My audio system says protect on display
I am getting PROTECT sign on displays and it is not doing anything so can you please help me out.
my sharp cd ba-1700 just stopped working displaying the word protect, now i can do anything with it, it turns on but within second it turns of with protect! can u help plz
    Brigadier General:
  • 6,966 Answers
Hi Jean,
Without a brand and a model, best that I can provide are generic possibilities:
1. unplug the unit from the mains for a couple of hours. This is supposedly to reset most systems; and/or
2. check the speaker wires and make sure none of any bare wires are touching each other.
If your concern has not been corrected after completion of the above procedures, pls post back brand and model.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Feb 23, 2008
  • Louie  Role
    Louie Role Feb 24, 2008
    Hi again Jean,
    Understand now that your concern is a Sharp BA-1700. The message "PROTECT" indicates that the built-in diagnostics have determined an internal fault which could either be:
    1. the logic circuitry or the firmware controlling it;
    2. amplifier circuitry or its components;
    3. mechanical problem.
    Of the above, I tend to suspect the audio amplifier section to be at fault. Normally this would be a single power pack IC that provides audio amplification to drive your speakers. They often fail when driven loud.
    If you have done any or both of the two procedures initially posted and no positive results, am afraid that your only alternative is to seek the services of a qualified professional since this would require opening the unit. Further diagnosis and appropriate repairs would require that you be familiar with electronic circuitry and components, use of a DVM and a soldering iron.
The display just reads "protect"
Protect is bad. It means the amplifier thinks it is overloaded. Check the speaker wires to make sure there are no loose connections or shorts.
Mar 01, 2011 | Sharp CD-BA2600 CD Shelf System
CD-C622 SHARP PROTECT MODE
This is a common fault. Check following:
RY801, C815, and Q803. Replace audio output IC and check nearby low ohms resistors for open.
Jul 07, 2009 | Audio Players & Recorders
Protect error on model # CD BA200 Sharp Stereo
If you are a technician desolder the Audio amplifier IC,and check if the stereo turn on but with no sound.If the stereo turn on the audio amplifier IC is in short circuit and need to be replaced.
Good luck
Jun 05, 2009 | Sharp CD-BA200 CD Shelf System
Display says protect
check your low voltage fuses, the protect light up when a overload comes....
Jan 28, 2009 | Audio Players & Recorders
My Sharp model no. CD-BA250 is displaying "protect". It will not turn off on or anything!! How do i clear it out to fix the problem.
Disconnect your speaker boxes. If the "protect" error goes, then the speakers or wires may be at fault. If the error remains, most likely the audio output IC is blown.
Sep 17, 2008 | Sharp CD-BA200 CD Shelf System
PROTECT mode
I have a Sharp cd-c2900 home stereo and a "protect" word came up on the lcd?? The stereo is not working now and olnly shows a "protect" word?? Can you please tell me if there is a reset button some where?? Thanks , "Joel" My Email address>> Jovelopa22002@yahoo.com
Jul 17, 2008 | Sharp CD-C2900 Shelf System
Protect push power
hi, everytime i switch on my sony hi fi it the display screen says protect push power. It won't let me do anything not even put cd's in. If you could help that would be very much appreciated.
Jun 12, 2008 | Sony LBT-XGR6 CD Shelf System
"PROTECT" in Display
Probably your output amp. is worn out
Feb 19, 2008 | Sharp CD-BA300 CD Shelf System
As Shown Here, A Sharp-Associated Repair Person Suggested Replacing A Specific Output IC, As Well As Two Other Small Components. The Total Of The Three Replacement Parts Is $55.43. I Suggest Doing The Repair Yourself, As The Stereo Would Be No Longer In Warranty, Unless You Have No Experience With Working With Electronics. You Could Also Get The Repair Done By Circuit City, Best Buy, Or A Similar Electronc Consulting Business
Jan 10, 2008 | Sharp CD-BA150 Shelf System
Sharp CD-BA300
An audio output IC may be defective. This set carries two output IC's.
Aug 14, 2007 | Sharp CD-BA300 CD Shelf System
347 people viewed this question
 Grubhead
Grubhead
