Question about Hitachi 53UWX10B 53" Rear Projection Television
Hitachi 53UWX10B 53 convergence color lines dont move w\RC
After replacing the I.C's,two, with the CORRECT I.C's the T V will now come on,no more red blinking light and burning odor.The screen is a mess, no color of the three are even close to each other and the screen bows top to bottom.
While in convergence mode I found I was unable to cause movement of any color in any direction,and magic focus is OUT, Magic Focus displays colored stars they are unmanageable. I hope you can help,,,again. Thanks,
Dactag
  • 927 Answers
After replacing IC's, double check the solder connections for bridging or no solder on pin(s). Check all bias resistors (low ohmage). Make sure you have your VCC voltage, should have a positive/negitive voltage of about 24 v on each IC and +38v.Also, make sure all cables are plugged in and fully seated
Note: All bias resistors are very low ohms eg; 3.3, 1.8, 2.2 make sure correct value, very important.
If can't adjust still CPU digital convergence board (near ic's) shielded may be defective.
Posted on Feb 23, 2008
We have an 80's hitachi mts 52" tv/ monitor and it has a 3d effect how do we fix this?
Tv have a problem known as convergence problems,it dead.Tv R,G,B colors lines mis alignment,Colors shadows or 3d pictures effect.The tv convergnce board is dead.The tv convergence board,require replacing 2 STK convergnce ICS and some or all it resistors.To solved tv convergence board,to solved tv convergence pictures problems.The shop,will cost u like $300-350 for parts and labors.
Sep 11, 2010 | Hitachi 53UWX10B 53" Rear Projection...
I have a hitachi 53fdx20b and the red and green colors line up fine, but the blue is droopy at the top and doesnt line up elsewhere, any help?? :)
Ur convergence is dead.U know how to solders?Try this website,Tv repair World.com.to buy a convergence kit,replace what in that kit.
Oct 20, 2009 | Hitachi 53UWX10B 53" Rear Projection...
I changed the IC chips on my hitachi 53uwx10b tv like you guys said that helped alot but still have wavey lines on both sides of the screen what do I change on the con. board now? Thanks alot Jim
Resistors " RK42 3.3ohms
RK46 1.8ohms RK50 2.7ohms RK54 1.5ohms RK58 3.9ohms RK62 2.2ohms After you replace all of them then enter convergence by pulling OFF bottom front panel there on front of convergence board is a small blue button press it and a convergence pattern will come up now aline each color red then blue.
Sep 24, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Convergence settings on hitachi 53uwx10b
Yes - You will need to either remove the circuit board or lift up the tray. If you are not sure how to do it yourself read the link below.
  • This is a very common failure on Projection TV sets.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 10, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Akai color alignment
This is a convergence problem that can be as simple as poor solder connections on the pins of the convergence ICs or defective ICs. If you wish to attemp the repair yourself, please let me know and I'll look up the parts and provide additional details and instructions.
Dan
Feb 18, 2009 | Hitachi 53UWX10B 53" Rear Projection...
53UWX10B blurred pic and blue/yellow lines
you can try the convergence first
if you cant converge the lines into one to correct this then you would require service for the convergence stage of your set
this is not a uncommon problem and usualy runs around 280 to 350 to repair unless the dcu is at fault
Jan 20, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Hitachi 53UWX10B Convergence cutting in and out
Good Day, Armenian;
You have poor connections on the convergence IC's , re solder and your TV should be back to normal.
Good Luck, big IRISH.
Aug 04, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Hitachi 53UWX10B Projection TV colors not lining up...
This is a convergence issue..both chips need replacement.
Dec 14, 2007 | Hitachi 53UWX10B 53" Rear Projection...
Hitchai 53UWX10B colors dont line up.
I have a service manual for the 43/53 uwx10b
Oct 16, 2007 | Hitachi 53UWX10B 53" Rear Projection...
Open Questions:
See all Hitachi 53UWX10B 53" Rear Projection Television Questions
Hitachi 53UWX10B 53" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
