Question about Brother MFC 210C All-In-One InkJet Printer
Brother MFC-210C is ghosting!
My printer is back up and running after changing the old ink tank but the print qualiyt is ghosting; some lines a re crystal clear but others appear to have been over printed several times.
Does anyone know how to fix it?
  • 1 more comment
  • Mac_515 Feb 26, 2008
    Already tried all thoise options without success; I'm beginning to think its a software problem as there is no ghosting on the actual alignment test page, which I'm assuming come direct from the printer?
  • Mac_515 Feb 27, 2008
    That's great and thanks I'll give them a call to see if they can help. It will probably be cheaper now to just buy a new printer; shame.
  • Anonymous Mar 12, 2014
    I have been having printing problems with brother mfc210c since error 46 occured. I moved printer slightly on to its side and a whole lot of black ink poured out from the base. Still having alignment and ghosting problems. My printer is a fax,scanner and copier. I do not use the fax.
Hiya,
I had the same problem this evening, so I went onto the Brother support site.
This link solved my problem:
"How can I improve poor print quality?"
http://tinyurl.com/27xv4r
Hope that helps.
-areacode514
Posted on Feb 26, 2008
  • 832 Answers
Set the alignment by pressing ink etc.
press the numbers that matches best.
Posted on Feb 25, 2008
  • Mix-it-up
    Mix-it-up Feb 26, 2008
    No. The printhead can be mechanical adjusted, too. This can only be done by a brother service partner near your home which can be found on the homepage.
Brother mfc 210c printer problem
try t clean the print head, or maybe you did not use fine ink...
Jan 24, 2014 | Brother MFC 210C All-In-One InkJet Printer
Problem with my Brother MFC 210C Printer won't print the colors.
Check your ink cartridge if they are properly installed.
Check your print settings.
Make sure your ink cartridge are not empty.
Replace your ink with the original Brother ink cartridge.
Sep 08, 2009 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC-210C won't print
I have cleaned, retested and new ink and it still will not print Black
Jul 11, 2008 | Brother Multi-Function Center MFC-240C...
Only print on black and yellow
did you use generic ink? those ink will clog the ph espacially the mag + yellow channels.
do use original brother ink carts because these contains special cleaning fluids!
Mar 20, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210C All-in-One Ink Cartridges
near empty message is a reminder: plz buy a new cart (but do NOT change until EMPTY). You still can print.
the ink left in an empty cart keeps the system alive when some ink is neede for the automatic cleaning cycle.
If you print until this cart is really empty air will get into the tubes and ph. That leads to faulty printings.
brother had made sure that the amount of printable ink can be consumed. The rest is for service.
Jan 31, 2008 | Brother MFC 210C All-In-One InkJet Printer
MFC-210 Brother Printer
do run the alignment (pressing ink management/print qual./ etc.).
Jan 22, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210c
press menu then start bc copy then 4 times arrow up. What error code does the machine display.
Dec 12, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
968 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
