IIYAMA PL431 TFT cut-out
I have been having the problem of picture cu-out recently - the screen starts up ok, but picture appears to cut out after 10 seconds. I can see the picture if I shine a torch on the screen so it appears to be the back lights. I thibk its something to do with their power supply maybe. If Ipress the auto tune button the back light comes on for a few seconds again then backlight goes out. please advise what could be the problem component to change. I guess this problem is not the CC tubes as I have a second identical screen and if I swap the power supply I get same on the other screen os its the power supply I assume. There are mainly passive components caps 1 or 2 electrolytics and one main chip BA9741F and 2 smaller ones BE4U14 - msny thanks
  • Alex_Alanine
    Alex_Alanine Feb 23, 2008
    No remote and this is a PC TFT monitor not a TV - no tuner, no remote and its a hardware issue - thanks.
  • Alex_Alanine
    Alex_Alanine Feb 24, 2008
    Yes, its been disconnected from the power for days even this has no effect at all, thanks.
    President:
  • 1,944 Answers
Did you try disconnecting it from the power for a few hours to hard reset the unit? Did you check the power connectors?
Posted on Feb 23, 2008
    Genius:
  • 3,422 Answers
Depending on the make and model of TV, there's sometimes a menu option to set the display. This is often only accessible via the remote control - somewhere!!!
Waiting for your reply..
  • Priya darshan Feb 23, 2008
    I also want you to check THIS link out.
Have owned a iiyama 17" pro crt for a few years,
These were a fine monitor and with the kind of image quality you cannot get on TFT's.
If you know the graphics card you are using is working ok, have checked the VGA cable connection and socket at the monitor and computer and have tested the monitor on another computer, that would rule out any problems as far as connected devices are concerned.
The problem you describe, and it is unusual that it has happened so quickly, points to a failure of the monitor internal board. You may be able to get this repaired at a reasonable cost by seeking the opinion of a TV repairman, who might be able to fix it.
Jul 25, 2011 | iiyama Vision Master Pro 400 (White) 17"...
Iiyama prolite e1902wsv white screen , no picture
From time to time, I've the same white screen problem with my IIYAMA E1902WSV.
I can resolve that issue with a reset to factory settings.
1- Turn ON power (blue led)
2- Push on the MENU button and keep the button pushed while
pulling out the power cord.
3- Plug the power cord back while keeping the MENU button
pushed.
You should see the picture again.
Oct 18, 2010 | iiyama ProLite E481S-B 19" LCD Monitor
EVGA Geforce Nividia 5200 video card. Works with IIYama Vision Maker 450 monitor when using Windows XP. Doesn't work with Ubuntu (Linux). Computer = Dell Dimension 8200. Would like it to work with...
1) Boot your PC
2) when the grub menu appears, use the down arrow to get to the menu option listed as (rescue system)
3) when the text-based menu appears, choose a menu option that gets you to the root shell, then following the instructions mentioned in this link: http://www.cyberciti.biz/tips/black-screen-while-starting-x-window.html. Debian instructions will work for Ubuntu.
Good luck
Jan 18, 2010 | ViewSonic VP230mb 23.1" LCD Monitor With...
Fujitsu-Siemens P15 TFT power/picture problem. it take time to turn on.
It does indeed sounds like the capacitors, I had this problem last year with a Medion monitor where it would turn on and off, when I spoke to Medion they did say that it would need a repair but at the time I wasn't enclined to pay the repair fees for something that may happen again!
Personally I would stick with your plan of getting a new monitor because my view on monitor hardware issues is that if it's happened once it will happen again even if you do repair it resulting in a lot of hassle!
May 27, 2009 | Fujitsu Siemens Premium Line P15-1 15" LCD...
  1. No start-up. Clicking sound from speakers
  2. solution
  3. Replace C922 and C923 (both 1000uF/16V). Also replace C924 and C925 (both 470uF/16V). on powerboard
JK electronics
Den Helder
document.getElementById('showwaitmessage').style.visibility = "hidden";
Aug 11, 2008 | Fujitsu Siemens Premium Line P15-1 15" LCD...
EONON 13 INCH TFT LCD COLOUR MONITOR PICTURE FAULT
PROBALLY CUZ URE CHEAP *** AINT BUYIN D RITE CABLES N ****
Jun 08, 2008 | Audiovox VOD102 Car DVD Player
Iiyama Pro 452 clicking sound during start-up
Your CRT Monitor will fail soon. The clicking sound is coming from your CRT's power circuit.
Make plans now to replace it. This problem is known to be a fire hazard in some cases. So, better safe than sorry.
Sorry for the bad news.
Hope this was helpful.
Worldvet
May 21, 2008 | iiyama Vision Master Pro 454 19" CRT...
No menu
One of the buttons on the front of your monitor is probably stuck.
(Only one of the buttons work at a time on most monitors)
I cannot recommend taking it apart your self (have a tech do it)
But take off the front, check the buttons after you take off the front, and if it still occurs unplug the buttons from the monitor.
If it stops (which it should) replace or fix the controls)
If it doesn't, call an exorcist (just joking) or buy a new monitor.
Mar 14, 2008 | iiyama Prolite E430 17" LCD Monitor
PC monitor wont come on.
Check that the power cord is fully plugged in first.
It is probably the inverter board inside the monitor.
(if the screen does properly display ever then it is not the screen)
It CAN be fixed but I do not suggest anyone open up a monitor (LCD or CRT) who is not "technically inclined."
If you really want to fix this particular one then take it to a local tech and get an estimate first. If it's almost as much as a new monitor then buy a new one.
Mar 14, 2008 | iiyama ProLite E434S 17" LCD Monitor
Computers & Internet Logo
408 people viewed this question
Alun Cox
David Payne
David Payne
