Question about IBM Webcam
Pls help me..
Good day!!! My camera is working good for ages. I just wonder that all of the sudden, the camera turns black when i am in yahoo messenger. I closed it and open the IBM PC camera icon as shortcut in the desktop and it says, the system cannot open file hr=0x80070004. please help me how to solve this problem.
    Sergeant:
  • 226 Answers
Sounds like you may have lost the driver for the webcam. Probably have to de-install and then re-install. Suggest total removal of the original folder which means using Windows Explorer to do it. This to remove any left-over files that may contribute to bad re-install. Also if the cam is real old, it is possible that the cam itself has finally bit the dust, but before making that assumption, try the re-install.
Let me know what you find out.
Posted on Feb 23, 2008
My pictures have lines across the screen in the viewer and are also sometime dark. this happened suddenly. The message boards point to a shutter problem with this camera. Is it fixable, worth fixing, a...
Sound like a malfunctioning CCD-image sensor. Rare, but possible problem with your LCD screenviewer... in both cases (LCD or CCD) this isn't a job that you could solve yourself; this wrong include distorted images or abnormal colors, scratchy purple lines, blank or black pictures, and/or black videos with good sound being recorded on the camera's flash card.
I suggest check THIS LINK for additional details in this previous solutions for an Defective CCD (Charge Coupled Device) and next contact your Samsung service.
I strongly suggest (taking into consideration the age of your camera) to evaluate the cost of repair versus the cost of a new camera with similar features, before making a final desicion.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Sep 07, 2011 | Fuji FinePix F470 Digital Camera
I have had a Samsung s630 for a couple of years now and it has worked great. All of a sudden the pictures on the screen are looking all washed out with a green tint and appears to have lines through it. ...
If teh photos on the pc still look good the screen is damaged or at least to flatcable from the screen to the camerabody.
If the foto;s on the laptop and the screen look alike then you might try to clean the chip inside the camera. Thats a delicate job and you might let the delaer do it for you.
cost about 50 bucks
Pls let me know if it worked
thanks
rene
Jun 08, 2011 | Samsung Digimax S630 Digital Camera
All of a sudden, my hp 3320 printer will not print black. I changed the printer to test that and the other one won't print anything. I put in a new black cartridge, nothing. The color works. I uninstalled...
Good day!maybe a problem with the carrier of your cartridges..it cannot print black anymore..maybe there are inks that blocked the cartridge from flowing inside the carrier which called printer head..i think you may replace a printer head if any testing is not effective.
mastergani
Mar 29, 2010 | HP DeskJet 3320 InkJet Printer
Have an issue with kodak v1253. black screen taking pics
CCD failure !!
ask kodak they might repair it free of charge dont worry just call them in ur region i think they will do it as all are doing it free see the link below for ur problem
http://www.imaging-resource.com/badccds.html
pls rate me
Mar 28, 2009 | Cameras
Camera won't power on. Lense won't retract.
Pls check the batteries are they supplying full power to camera are they aged or old try replacing them with good power batts and Memory card try re formatting it on a PC card reader
lense is coming out at full length or there is a grinding noise or abnormal behavior in it pls check may be u dropped ur camera or any other incident broken its lense gear.
pls check and reply me for more help
Feb 27, 2009 | Olympus FE-220 Digital Camera
Sony Cyber-Shot DSC-P72
Check the battery contacts inside the camera and see if there getting a good connection. If there spring loaded you might have to pull up on them slightly to get a contact going for charging. Look for corrosion as well.
Aug 29, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Iphone display
keep the home button and the power button pressed together untill a yellow triangle appears on your screen and it will restart............this should solve ur problem.
I tried it and never saw a yellow triangle but it rebooted the phone and it worked again!
I just don't know why the screen goes blank
Jul 30, 2008 | Apple iPhone Smartphone
Startech USB 2.0 TV Tuner
Pls verify that the tuners color standard is identical to that of the video camera. Depending on where you are, there are a number of color system but dominant are PAL (for most European) and NTSC (for US). So you have to select which ever is being used by the video cam.
Hope this be of help.idea. Pls post back how things turned up or should you need further information.
good luck and kind regards.
Jan 25, 2008 | ATI TV Wonder 650 (DNH100715331) Video...
Our TV reset itsself to sales pitch
1) Demo mode clears by holding vol up & chan up at the same time at the set front buttons. Or try menu & power.......
2) Black box is called a text box = part of closed-caption option.
Select CC to turn text box off.........
Note:Always provide Model # , Chassis # and age......
serial # not needed / helpful..........T.
Nov 05, 2007 | Televison & Video
TV TROUBLESHOOT
step 1 check the ABL, step 2 check the junggel ic
Oct 26, 2007 | Akira HPT5001D Television
IBM Webcam Logo
48 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
