Sony KP-46WT510 46" Rear Projection HDTV Logo
Reno Claudio Posted on Feb 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Not able to flash focus or use manuel converence i think i need a convergence kit where can i purchase this kit
Anonymous
Level 3:
  • Sony Master 3,459 Answers
  • Posted on Mar 19, 2010
Anonymous
Sony Master
Level 3:
Answers
3459
Questions
5
Helped
849984
Points
5558
You probably need to get a Sony TV Convergence Kit for your model. More information can be found using the link below.
Convergence Symptoms:
  • Screen Looks Distorted/3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
You can see some examples and find a fix here...
not able to flash focus or use manuel converence i - bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Set 51uwx20b, how do i fix magic flash to reset factory settings
Convergence board needs repair, google you model # and see if you can purchase a repair kit.
IMAGE GHOSTING
Have you tried the auto converge or flash focus adjustment? This feature allows you to adjust the convergence automatically. If it doesn't work,convergence circuit is faulty. You need to replace the convergence kit, To do this you need some basics on electronics.
1helpful
I HAVE A 43H70 WITH WHAT APPARENTLY IS A CONVERGENCE ISSUE. NOW IT WON'T START UP BUT THE RED LIGHT FLASHES. DO YOU THINK REPLACING THE STK-110'S WITH STK-180'S WILL SOLVE THE PROBLEM?
Usually even with the convergence problem the set comes on, I would check for pica fuses blown, and the 160 or 180 will do just higher amps. And check for burnt resistors in conver. area
3helpful
Flash focus,convergence not adjusting pic quality currently have green to the left and red to the right cant adjust into alignment
Thats a convergence Failure. You can get the Sony type 1 convergence repair kit which is the correct kit for your model at www.tvrepairworld.com the kit contains the replacement parts and the CD with instructions for the repair.
Sony rear projection tv will no longer focus. tried flash focus & manual focus
Convergence issue. The sony type 1 convergence kit from www.tvrepairworld.com should repair that issue. The kit contains the parts and CD with instructions.
1helpful
04 sony 56 inch convergance
Convergence has failed. The Sony type 1 convergence repair kit from www.tvrepairworld.com covers your model. The kit contains the parts and the CD with instructions.
Can you manualy fix the covergance arrows one by one flash focus wont line up had controll replace and stiil wont work the tv repair guy said he needs to fix covergace switches one bye one but the model...
if your talking about a samsung set, then probably the convergence modules are gone. there has`nt been manual convergence setup controls for more than 10 or 15 years i think
Auto focus and manual focus(red+will not move left
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Hue wont align and causes ghosting
you need to replace the convergence ICs and pico fuses. The KP46WT510 convergence repair kit at the following link works for your model as well and the kit comes with instructions on how to do the repair. Its listed under the convergence repair kit category.
http://servicemanuals.vstore.ca/
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
