Question about iiyama ProLite E434S 17" LCD Monitor
Colour changing i have a iiyama prolite e435s monitor and it keeps changing colour can anyone help me with this problem
I found this on another site:
[QUOTE=numbnutjas]I had the same problem along with lots of others who bought this great prolite monitor.
Whenever you turn the power off for more than five seconds the monitor looses an important bit of info of a hidden menu. Iilyama are not keen on publicizing the fact their monitor has a bug!
Follow these steps very carefully, it might not work the first time but it does work I promise.
Make sure that the moniter power button is off.
Unplug monitor from mains ( the auto exit button should flash red after about five seconds and you hear a popping sound.)
plug monitor back in mains.
hold down + and - on the monitor
now hold down power button on monitor
let go of power when power button when the green led lights up
let go of + and - buttons
wait a few seconds and press menu, a hidden menu will appear in the top right
use the + and - buttons to move the hilighted option over the auto colour option in the menu
push the menu button.
It does work, but if you have any problems: email at : miamoo2038 at hotmail dot co dot uk
Posted on Jun 05, 2008
  • waz480 Aug 28, 2010
    Thanks very much dude worked second time,
    cheers
    waz
    cheers
    waz
Thanks worked perfect
Posted on Aug 31, 2008
Can't get my Iiyama Prolite E2407HDS out of test mode
from iiyama tech support (UK):
  1. Switch off the monitor.
  2. Connect all 3 input types with live connections (VGA + DVI + HDMI)
  3. Turn the monitor on.
It will select an input and display as normal.
I have tested this and it does work!
Good luck
May 25, 2012 | iiyama E2407HDS-1 24 inch LCD Monitor
Iiyama prolite e1902wsv white screen , no picture
From time to time, I've the same white screen problem with my IIYAMA E1902WSV.
I can resolve that issue with a reset to factory settings.
1- Turn ON power (blue led)
2- Push on the MENU button and keep the button pushed while
pulling out the power cord.
3- Plug the power cord back while keeping the MENU button
pushed.
You should see the picture again.
Oct 18, 2010 | iiyama ProLite E481S-B 19" LCD Monitor
Where on earth could I find the data for an Iiyama Prolite e435s's EEPROM?
This PDF file provides the Diagnostic info for the E435
lease click on this link to download this PDF file :-
http://www.koyoele.co.jp/english/support/pdf/DL205_M1.pdf
Jun 06, 2010 | iiyama ProLite E434S 17" LCD Monitor
Iiyama Prolite 434S monitor is too dark
Dim or dark display can be caused by a faulty inverter board or faulty CCFL lamp. The inverter supplies high voltage to the CCFL lamp, the CCFL lamp is a miniture fluro tube and these dim with age.
Check out LCD Parts for service, parts and DIY info - click on this link to their WEB site. :-
www.lcdparts.net
Sep 28, 2009 | iiyama ProLite E434S 17" LCD Monitor
PC monitor wont come on.
Check that the power cord is fully plugged in first.
It is probably the inverter board inside the monitor.
(if the screen does properly display ever then it is not the screen)
It CAN be fixed but I do not suggest anyone open up a monitor (LCD or CRT) who is not "technically inclined."
If you really want to fix this particular one then take it to a local tech and get an estimate first. If it's almost as much as a new monitor then buy a new one.
Mar 14, 2008 | iiyama ProLite E434S 17" LCD Monitor
Prolite e435s iiyama screen
Monitor screens will have color tints when any of pins of the VGA connector is damaged or bent(I assume you are using a 15 pin VGA connection :) ) Please remove the monitor connector cable and check if you have bent or damaged pin at either side of the cable.
If it does not resolves the issue, replace any devices or equipments that may have electro magnetic fields like an UPS from the premises of the monitor.
Also, you can try resetting monitor. All the monitor will have an option for reset in the Menu.
Hope this works!
Good Luck
Mar 09, 2008 | Computers & Internet
Screen keeps changing to different colours when i switch pc on
Have you tried checking that it's plugged in firmly to your CPU?
You might need to screw the caps on the side to ensure that's the case.
Feb 23, 2008 | iiyama ProLite E434S 17" LCD Monitor
Blueish screen
Follow these steps to solve the problem... Make sure that the moniter power button is off. Unplug monitor from mains ( the auto exit button should flash red after about five seconds and you hear a popping sound.) plug monitor back in mains. hold down + and - on the monitor now hold down power button on monitor let go of power when power button when the green led lights up let go of + and - buttons wait a few seconds and press menu, a hidden menu will appear in the top right use the + and - buttons to move the highlighted option over the auto colour option in the menu push the menu button.
Jun 08, 2007 | iiyama ProLite E434S 17" LCD Monitor
iiyama ProLite E434S 17" LCD Monitor Logo
1,515 people viewed this question
Top iiyama Computers & Internet Experts
William Miller
William Miller
RS Technology...
RS Technology...
Are you an iiyama Computer and Internet Expert? Answer questions, earn points and help others
