Question about Vacuums
Empties water out
My quickwash keeps emptying water out. after it has done this it stops sucking up water. i have taken it apart and messed with the valve which is operated by the handle mechanism. when its put back together the machine does work again for 2/3 washes but then the same thing happens. can any of you wiz/gurus help.
maria
  • marka1862 Feb 24, 2008
    Thanks for replying. The switch appears to be doing everything required of it. The machine is just out of warranty (15months).
    Maria
  • 75 Answers
The switch is most likely bad. How old is the machine?
Posted on Feb 23, 2008
It keeps losing suctionm and the ball comes up and it stops sucking. Why?
sounds wilk a wet /dry vacuum cleaner
if that is the case the ball comes up to stop water / froth from being sucked through the motor
if that happening put more anti suds mix in the water or empty the receiver tib more often
Jul 26, 2016 | Vacuums
Can not get my steam vac to suck up water everything else works.done half floor empty water to do other half of floor and it just stopped sucking up water
  • There a twist lever on the side to change from floor to tools. If "everything else works" then you have it on tools. Twist it back to floor and it will work.
Sep 11, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
My vax power 8, 2200 watts 300 air watts 4L capacity upright Hoover is brand new, I emptied out the dust/dirt collecter and cleaned the motor filter yesterday for the first time, i switched it on and all...
I had the same problem. It looks like the seal on the lid on the bottom of the cylinder has fallen out when it was emptied. There is no longer a proper vacuum being created so you don't get the cyclone effect and the dirt doesn't collect where its supposed to. it just clogs up the filter. I put sellotape to seal the lid and it works fine.
May 14, 2013 | Vacuums
Oreck carpet cleaner wont **** up water
Your reservoir is full. Empty the water and it will work properly.
Feb 20, 2013 | Oreck XL Shield Power Scrubber Floor And...
My steam vac stopped sucking the water up
make sure the lid on the dirty water container is on tight and the tank itself is locked into place, also check to make sure the clear window in the front of the machine is tightened down firmly
Oct 20, 2009 | Hoover F5858-910 SteamVac Vacuum
My fantom vacuum stopped sucking stuff up
Most likely there is a clog, either in the 'knuckle' between the power head and the wand, or in the connection where the hose comes into the canister. In either case, unplug the hose and you should plainly see it.
Mar 07, 2009 | Fantom Vacums Lighting Canister Vacuum
I have a Bissel proheat 7901 carpet cleaner and it is not sucking the water up. Normally when I clean the water gets sucked back up and I have to empty the dirty tank. Now no water is in the tank when I am...
I'm not sure if this will help but I had the same problem and was about ready to pull my hair out. I ended up taking the fill tank off and if you look inside where the red overflow flap is you will find a small screened opening. I found that mine was pretty clogged up with debris but once I removed the mess and put my machine back together it is now sucking like a champ. I hope this helps. Here's hoping that you don't have the pay for a service person to look at it.
May 18, 2008 | Vacuums
Within an Hour my SpotBot stopped working
Some of that water must have gotten inside amd shorted something. If this is less then 1 year, it would be under warranty. It iwll have to be taken apart and checked.
Dec 02, 2007 | Bissell SpotBot Robotic Wet/Dry Vacuum
Vacuums Logo
56 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
