HP Deskjet 460c InkJet Printer Logo
Posted on Feb 09, 2010
I can't connect to my HP Deskjet 460 via bluetooth, only via cable (usb). I have installed the printer via cable, and then I try to install the wireless connection via "Add a bluetooth unit" in the "My bluetooth locations" section (in quotes: translated from Norwegian). My PC is an Asus EeePC laptop with WinXP. The printer works fine, both via cable and bluetooth, with my Dell XPS (Vista). Regards, Irene
Anonymous
Level 1:
New Friend:
  • Contributor 18 Answers
  • Posted on Feb 09, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
18
Questions
0
Helped
8044
Points
40
Is your Deskjet still in the default "Private" mode? If so, change it to the "Public" mode.
In the toolbox, go to the printer services tab and choose configure Bluetooth settings. Change the mode to public mode.
Go to --> http:/h10025.www1.hp.com/ewfrf/wc/document?docname=c00625408&cc=us&lc=en&dlc=en&product=466208
I have an Acer 5321-1805 laptop and installed a Medalink version 3.0+ class2 dongle, but I can't print on my hp 6980 deskjet printer which also has a dongle installed. It pairs, but the printer driver...
Welcome to FixYa.
You have to configure the Bluetooth settings of the printer first. I assume that you have the HP bluetooth dongle on your printer.
Configure Bluetooth settings
You will need a USB cable to configure the Bluetooth settings
  • Connect a USB cable from your computer to the rear USB port on the printer.
  • Open the printer Toolbox.
  • Click the Configure Bluetooth Settings tab.
  • Configure the settings you want, and then click Apply
    Keep me posted.
tip
EZ steps to install HP printer in Windows 7 without Installation software
  1. Make sure that the USB cable is not connected to the product. If the USB cable is connected to the product, disconnect it.
  2. From the Windows taskbar, click the Windows icon, and then click Devices and Printers. The Devices and Printers window opens.
  3. Click Add a printer. The Add Printer window opens.
  4. Click Add a local printer.
  5. Click Use an existing port.
  6. Click the Use an existing port drop-down list, select LPT1: (Printer Port), and then click Next.
  7. Under Manufacturer in the Install the printer driver window, click HP.
  8. Under Printers, select approriate drive from below list provided and then click Next.
  9. In the message window, click Finished.
  10. Connect the USB cable to the product, and connect the USB cable to the computer. A Device driver software was not successfully installed window opens.
  11. Click Close to close the window.
  12. In the Devices and Printers window, right-click the name of the product and then click Printer Properties. The Printer Properties window opens.
  13. Click the Ports tab.
  14. Click the drop down menu, and then change the port from LPT1 to USB or DOT4.
  15. Click OK.
  16. In the Properties dialog box, click the General tab.
  17. Click Print Test Page.
Determine the appropriate compatible driver
Deskjet 3320, 3325, 3420 and 3520 -------------Deskjet 3600 *
Photosmart 7600 series------------------------------ Deskjet 5600
Deskjet 5850 ---------------------------------------------Deskjet 5600
Photosmart 130, 145, 230 and 245 ---------------Photosmart 330 *
Photosmart 7350 and 7550 --------------------------Deskjet 5550
Deskjet 6122 and 6127 --------------------------------Deskjet 990c *
Deskjet 3820 -----------------------------------------------Deskjet 970cse *
Deskjet 656 ------------------------------------------------Deskjet 660c *
Business Inkjet 1100d ---------------------------------Business Inkjet 1000
Business Inkjet 1100dtn ------------------------------Business Inkjet 1000
Deskjet 9300 ----------------------------------------------Deskjet 1220c *
Deskjet 9650, 9670, 9680, 9680gp---------------- Deskjet 9800
* Available only through Windows Update.
(Happy Printing)
Regards
Rizwan
After installing the software when it comes to the part of connecting printer via usb cable to computer, nothing happens, on the screen it shows a picture of the cable trying to connect.
make sure that your printer is turned on and your printer has a good physical connection w/ your pc
try restarting your pc then reconnect your printer
Just purchased an iMac computer for my HP DeskJet 880C
You can log on to the hp site and get the current driver/printer software for your printer. Get the mac os version and install via usb. Download and install then restart your imac... then attempt a print...
Should work fine with an iMac.
K
Installation problems with HP dj 460c drivers
unplug the printer then install the drivers then reboot the PC then plug in the USB printer to USB port then insert again the CD installer..if their is same the problem you need to re-install the OS/windows...good luck
I cannot get my HP deskjet 932C installed again. I disconnected it to have my computer repaired. I did unstall and re-install the software, but am still getting the same message that it cannot find LPT1....
To begin with, here is a link for the user guide for your printer:
HP 930C User guide (Even though it says 930, your 932 should be nearly identical.)
Page 40 begins the setup instructions. If you are going to use the parallel printer cable, the printer port must be enabled in your BIOS. What did you have "repaired"?
It would be easier to get a USB cable and connect it with it, that is if you have a USB connection.
What operating system are you using? That may help me understand your problem better.
2answers
I cannot instal my "HP Deskjet F380 All-in-One" in my "Acer Aspire 4720Z" Windows Vista. When I star the installation, a warning is shown telling me -in Spanish- the following: "This software you cannot...
Try to connect the printer by using another USB Cable and in different port may the USB port in computer side or the usb cable is damaged that is why fail to send signal to your acer then try againt to install by using add hardware wizard
Deskjet 970cxi will not print
I need to get the driver software Dekjet 970cxi
Can I get driver software.
k24674
Grand Canyon Tech
Grand Canyon Tech
