Question about Dell A940 All-In-One InkJet Printer
Grabs paper My A940 is grabbing paper an pulling it into the printer crooked, thus jamming it and screwing up every print job, not to mention wasting a lot of paper.
    Scholar:
  • 35 Answers
To fix the Paper jam issue please try the steps below:
To fix the paper Jam errors please try the following steps:
1. Confirm that no foreign materials are inside the machine.
2. Confirm that usable paper is set.
3. Confirm that the paper is set properly.
4. Confirm that recommended paper is used, and the number of sheets set does not exceed the required limit. 5. Confirm that the paper trey Guides are ste in such a way that it is equal to the size of the paper, it should be set exat to fit the paper.
5. Disconnect the printer power cord as well as the printer cable form the printer.
6. Turn the printer upside down and shake the printer in order to remove any obstacle which is stuck inside the printer causing the paper jam error.
Open the printer cover and remove the cartridges and check carefully if there is any small piece of paper which is stuck inside, if so remove it carefully.
7. Disconnect the printer power cord and press and hold the power button on the printer for about 15 to 20 seconds( this will release the flee power) and reconnect the printer and check.
If the above mentioned steps do not fix the issue please up-grade the printer firmware form the Support.dell.com web site. However make sure that you do not turn off either your printer or computer when you are downloading and installing the printer firmware.
Should you require any further assistance regarding the printer or even for any other computer related issue please feel free to contact me I will be more than glad to assist you.
Regards
Malik Khan
Posted on Feb 24, 2008
Dell 1720 printer single-sheet feed stopped working
Pull out the paper that is jammed and continue.
Nov 29, 2012 | Office Equipment & Supplies
I have a Canon MP495 printer. It grabs the paper crooked and then it jams. I use regular copy paper for my print jobs. I took the paper out of the printer, and it grabbed and jammed. How can I fix my...
Same problem. Turned out to be a small nut lodged in the array of small rollers, just behind the ink cartridges. Managed to lift the roller bar at one corner, and shake it out.
Oct 15, 2012 | Lexmark X73 All-In-One InkJet Printer
It grabs the paper crookedly and causes it to
If you have previously had a paper jam, and it tore the paper, there could be a very tiny piece of paper stuck in the feed on the side...it only takes something very tiny to prevent the paper from feeding correctly...a child dropping a little piece of food, it could be anything...but I'd be about 90% sure that it's there. I found one once and it was so small it took forever to find it, and it was even harder to get out...you kind of have to work at it with some Q-tips, eyebrow tweezers2_bing.gif, a paperclip, something that you can go in and attempt to clear the feed. If you dont/can't find it you may have to take it apart, and that's not fun, and runs the risk of it "never" aligning correctly...so be persistant.
FYI...I had another guy with the very same post today, and gave him the same suggestion...he found a pen cap in the back of his printer, LOL...so get a flashlite, some very small tools, and have a look-see.
If this post has been helpful, please remember to vote.
Jun 15, 2010 | Epson Stylus C83 InkJet Printer
Paper feeds crooked into the printer
Check the adjustments for the paper your using. Open the printer and look on the rollers you'll probably find paper or an obstruction clear it and also clean then rubber moving parts with isopropyl alcohol to give them their grip back.
Jun 21, 2009 | Canon PIXMA MP190 All-In-One InkJet...
Every time I try to print, the printer grabs the paper crooked.
There's a leaver where the paper comes out, make certain it's to the left when printing with paper and to the right for envelopes.
Jun 14, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Feeder grabing the paper crooked causing jams and paper unable to go through the feeder smoothly. it stops once the feeder grabs the paper.
set the paper tray size to the size of the paper...if this is ok...clean the pick upo roller with damp cloth and soap water...if this doesnt help ...change the pick up roller..
keep me posted
May 04, 2009 | Computers & Internet
My MP460 printer wont grab paper and feed through
It sounds like the pickup rollers are worn or damaged and would need to be replaced
Feb 11, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Epson c88+
Ther is a obstruction in paper path, something has dropped down where paper goes in, or a fragment corner of a removed paper jam is in paper pathway
Nov 16, 2007 | Epson Stylus C88 InkJet Photo Printer
Dell A940 All-In-One InkJet Printer Logo
117 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
