Question about HP Compaq Presario V6000T Notebook
My laptop seems to have lost the wireless propertie
On the connection manager doesnt show the second point to click to activate the wireless properties
just show the local access
When you open the panel ,you check the power ic may there any one that is burnt then you remove with the help of sordering lead and iron,then you will replace the bad one ,and it start working again
Posted on Feb 23, 2008
  • akin olalere Feb 23, 2008
    just follows the instructions ,it will work
Cannot remember password to enable second laptop to system
There is stored password in laptop which is already connected to router. If Windows 7, then go to Control Panel, Network and Sharing Center. Click top left Manage Wireless Networks, then right mouse click on preferred network, click Properties. Then switch to Security tab and mark show characters.
Aug 19, 2011 | D-Link DIR-615 Wireless Router
I can not turn ON My Intel wifi Radio , it shows in the bottom right corner but when you open it it is off and Grayed out , unable to hit enable . Have tried several remedies that did not work and this...
It seems that the Windows wireless utility is active on your computer. Try to open the Wireless Network Connection properties on your computer. (Start > Control Panel > Network Connections > Internet Connections > right click on the Wireless Connection > choose properties ) There should be a Wireless Networks Tab. Un-check the option that says use Windows to configure the wireless connection. That should allow you to use your Intel wifi-Radio. But personnally, I would prefer to use the Windows wireless manager that any other wireless utilities.
Please refer to the pictures attached to be easily guided
Jul 04, 2011 | Computers & Internet
802.11n problem.
Please follow the mentioned step to check if the Wireless card is installed properly
Step 1 :
> click on start (assuming it to be a windows OS)
> right click on "my computer" and select "Properties"
> you will have the system Properties window pop-up
> under the Hardware tab, click on Device manager button
> under the device manager list look for network adapters
> you should now be able to see your wireless card under network adapter - check if the adapter is enabled ( if not kindly enable by right clicking on the adapter)
> once the adapter is active - it will have a green icon with not error on it.
> Now try to search for the network again - this should work..
Oct 17, 2009 | Belkin N1 Vision Wireless-N Wireless...
I have wrt160n router, when i tried to add my laptop(xp) it doesnt allow. msg says, "router has been set up but can not detect internet connection" pls help.
Likely you need to run the connection wizard in order to regain your connection. Also when using more than one PC with a router, some ISP's only allow one pc to be connected per account. To fix this problem, use the clone mac address feature in the router to clone the mac of the original PC that was connected, the router will then behave as that PC and split the connection by routing to any other pc connected using a single mac address. When you add a second PC because the provider only allows one pc per account - it then loses connection. The router fools the ISP by cloning the original mac.
Aug 29, 2009 | Linksys WRT160N Wireless Router
Cannot connect wireless
My best suggestion is not to use the Intel wireless manager. Please go into the wireless manager and take off the "check mark" where it says the Intel Manager manages the wireless card.  This will disable the Intel wireless manager from managing your wireless card and give control back to Windows.
-Right-click "Recycle Bin" and choose "Explore"
-Right-click "My Network Places" and choose "Properties"
-Right-click on wireless network (should only be 1, maybe 2) and choose "View available wireless networks"
-Click on the wireless name from the list that belongs to your office Access point.
-If it needs a key, enter the key when prompted (it will ask you to enter it twice, one for each line).
-Once you complete this step, you should have wireless access once again.
-Intel will keep prompting you if you'd like for it to manager your wireless, I suggest you ignore this message from this point forward and only use the Windows wireless manager (built-into all Windows OS). :)
Jun 29, 2009 | Intel PRO/Wireless 3945ABG Network...
I cant get to the gatway interface
It seems to be a hardware failure with the unit. Reset the AP using step below:
At the back of the router you will find a small tiny hole (which has a small button inside it). Press the button with the help of a paper clip. and hold it down for 30 seconds. After 30 seconds, please release the button and power off the device for 5 seconds.
Check if you are able to access its configuration page using the steps below:
1. Connect the computer to the access point.
2. Click start button (extreme bottom left corner of the screen) on the computer.
3. Click Control Panel from the list.
4. Click on Network Connections.
5. Right click on 'Local Area connection' icon and click on properties.
6. Select Internet protocol TCP/IP from the list of components and click on properties.
7. Select use the following ip address.
8. Assign ip address as: 192.168.0.90 ; subnet mask as: 255.255.255.0 and Default Gateway as: 192.168.0.227
9. Press 'OK' and 'close' the properties window.
Login to the access point page using the following steps:
1. Open a browser (Internet Explorer or Mozilla Firefox).
2. Access the router (usually http://192.168.0.227).
3. Login to the AP(User Name = admin and Password = password).
Rate it, if it helps.
Jun 24, 2009 | NetGear WG602 802.11g/b Wireless Access...
Can't connect to netwoork
Just configure the wireless settings your laptop. Go to Network Connections > Right-click on Wireless Network > Properties. Go to Wireless Network tab and look for Preferred Networks. Just remove all of them and click OK.
Now, On the Network Connections, right-click on Wireless Network Connection > View Available Wireless Networks. Connect to your own wireless network and enter your wireless network key if it tells you to type it. That should fix your wireless connection. Now if your wireless network is not showing, you need to change the wireless channel of your router by accessing the router's setup page using your wired computer.
Apr 18, 2009 | NetGear WGR614 Wireless Router
Hp Pavilion dv1000 laptop wireless connection doesnt always work? Sometimes it shows that a connection is available but it wont connect. Sometimes it works fine but drops out right in the middle of what...
you might have to review the driver version of your wireless. try to check if there are updates that might fixed the bug. go to my computer, right click, manage, device manager, network adapters - under it move your mouse on top of the wireless, right click, properties, driver and check driver version and date. then go to your hp pavilion product support http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&prodTypeId=321957&prodSeriesId=432999&taskId=135
and look for new version of network wireless driver might have. let me know if this doesnt fix the problem.
Apr 15, 2009 | HP Pavilion dv1000 Notebook
Dell D600 wifi
Do the Basics First;
  1. Make sure you turn it on or switch it on
  2. Reboot your PC
  3. Make sure your router is set to broadcast your SSID
  4. Right click your wireless connection and select "repair"
If still doesnt work;
  1. Select and double click your wireless connection
  2. Click on properties
  3. In the middle of the box find, select and highlight Internet Protocol (TCP/IP)
  4. Click on Properties
  5. Make sure "Obtain IP address automatically" and "Obtain DNS server address automatically" are the only ones selected
  6. Click on the "Wireless Network" tab
  7. On "Preferred networks" make sure your wireless is there ( your SSID) if not Add it, move it up or remove the others
  8. Once its added highlight it and click the "Advanced" button and make sure to select "Access point (infrastructure) networks only
  9. Make sure this is NOT checked "Automatically connect to non-preferred networks" then click "Close"
  10. Highlight again and this time click "Properties"button
  11. Check "Connect even if this network is not broadcasting"
  12. Check authentication configuration
Jan 18, 2009 | Dell Latitude D600 Notebook
Lost wireless connection
Do one thing right clik on my computer and choose manage option after that services in that service
in that wireless zero configuretion will start after then go for the right clik on my network place in that propertities
wireless network icon in that right clik and properties .tcp/ip protocol clik and properties
give the obtain automatically.
May 25, 2008 | Computers & Internet
HP Compaq Presario V6000T Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
