Question about Dell - NPS-200PB-73M (NPS200PB73M) Power Supply
TO bogdan my power supply not drives pc.led blinks when turn on the pc.
    Champion:
  • 207 Answers
Check the twisted paired wires that are found inside your system unit..usually it has a color red, green, blue and white wires..check your motherboard wire pins usually located at the sides of the board or near the BIOS chip. IF you can see those wires, try reseat those wires( but make sure you have an assistance of a qualified technician to avoid wrong connections and to fry your motherboard).
Goodluck!!
Posted on Feb 23, 2008
PowerEdge t110. powered on, led 134 light up a sec, the system fan starts & shuts off. then all leds 1234 light up and off. all turns off & after few seconds, the amber light goes on and no blinking.
Sounds like the power supply is dying. Startup is the highest power draw. If there is a CD or DVD drive, make sure there is no disk in the drive. The optical drive startup is a huge power draw when starting. You should also disconnect any eternal peripherals. You might want to try disconnecting the hard drives, as they also have a large draw. If it starts after that, your supply is probably dying. Looks like a 300 watt supply. Looks like these are about the age I'd epect a power supply to die. I'd get a supply rated about 500 watts, but make sure if fits. Dell often uses proprietary supplies that are odd sizes. I'd look for supply from pc power and cooling or look at the newegg.com site for reviews of any 500 watt model that will fit.
May 24, 2017 | The Computers & Internet
My d530 minitower powers off unexpectedly and red lights starts to blink on System's LED//
Hi Kindly let me know how many times the red light blinks
Condition Code Service Actions Processor thermal protection activated. Power LED blinks red twice, once a second, followed by a two second pause.
  1. Make sure the computer air vents are not blocked and that the cooling fan is running.
  2. Open the hood, press the power button, and see if the processor fan spins. If the fan is not spinning, make sure the fan cable is plugged into the cable header on the system board, and that the fan is properly installed and seated.
  3. If the fan is plugged in and seated properly, but is still not spinning, replace the processor fan.
  4. Reseat the processor heatsink and make sure the fan assembly is attached to the heatsink properly.
Processor is not installed. Power LED blinks red three times, once a second, followed by a two second pause.
NOTE: This condition indicates a missing or improperly installed processor, not a defective one.
Make sure there is a processor in the system. Reseat the processor and verify that it is installed properly. Power failure (power supply is overloaded) Power LED blinks red four times, once a second, followed by a two second pause.
  1. Check the voltage selector, located on the rear of the power supply, is set to the correct voltage (the correct setting depends on the region).
  2. Open the hood and make sure the 4-wire power supply cable is fully connected to the power connector on the system board.
  3. Check if a device is causing the problem by removing all attached devices (such as disk drives and expansion cards), then power on the system. If the system enters POST, power off and replace one device at a time, repeating the procedure until the system power failure reoccurs. Replace the device that caused the failure, then replace each of the other devices and confirm that they are functioning properly.
  4. If you cannot isolate the failure to a specific device in the previous step, replace the power supply. **
  5. Replace the system board.*
Pre-video memory error. Power LED blinks red five times, once a second, followed by a two second pause, and five simultaneous beeps are sounded
  1. Reseat the DIMMs in the memory slots on the system board, then power on the system.
  2. Replace the DIMMs one at a time to isolate the faulty module.
  3. Replace 3rd-party memory with HP memory.
  4. Replace the system board.*
Pre-video graphics error. Power LED blinks red six times, once every second, followed by a two second pause, and six simultaneous beeps are sounded. For systems with a graphic card:
  1. Reseat the graphics card and then power on the system.
  2. Replace the graphics card.
  3. Replace the system board.*
For systems with integrated (on-board) graphics, replace the system board. PCA (system board) failure. ROM detected failure prior to video. Power LED blinks red seven times, once a second, followed by a two second pause, and seven simultaneous beeps are sounded. Replace the system board. Invalid ROM based on bad checksum Power LED blinks red eight times, once a second, followed by a two second pause, and eight simultaneous beeps are sounded.
  1. Reflash the ROM using a ROMPaq diskette.
  2. Replace the system board.*
System does not power on. No beeps or blinks since the system is not functioning. Press and hold the power button for less than four seconds. Perform the following steps depending on whether the hard drive LED turns green.
If the hard drive LED turns green, then:
  1. Make sure the voltage selector (which is located on the back of the power supply) is set to the correct voltage for your region.
  2. Remove the expansion cards one at a time until the 3.3V auxiliary light on the system board turns on. If removing a card turns the light on, replace the card and then see if the system works.
If the hard drive LED does not turn green, then:
  1. Make sure the computer is plugged into a functioning AC power outlet.
  2. Open the hood and make sure the power button is securely fastened in the power harness and that the harness is connected properly to the power connector on the system board. In other words, make sure that the power button is making contact with the power circuit.
  3. Make sure the power supply cables are connected properly to the power connectors on the system board.
  4. Check to see if the 3.3V auxiliary light on the system board is not turned on, replace the power supply. **
Dec 29, 2009 | HP Compaq d530 Convertible Minitower PC...
Pc not turning on led light blinking
check if there is a switch on the back of your power supply if there is try turning off then on again .still no power replace you power supply
Jun 26, 2009 | HP Pavilion A210N (DF210A#ABA) PC Desktop
My asus mother board not working
STEP: Ensure Correct Power Button Is Used and Is Not Sticking or Broken. If the power button remains depressed during the power-on attempt, the computer immediately powers off, mimicking a "no power" symptom. Ensure the button is not being held down too long or binding against the bezel or chassis. If necessary, remove the front cover to press the button directly.
2. or else...STEP: Check the Power Button LED on the Front of the Computer (on Blinking yellow)
Initial state of LED at power up.
Indicates system has power, but the POWER_GOOD signal is not yet active.
If the hard drive LED is off, it is probable that the power supply needs to be replaced.
If the hard drive LED is on, it is probable that an onboard regulator or VRM has failed. Look at the diagnostic LEDs for further information. or lese..
3. STEP: Restart the Computer Using the Power Button.Press and hold the power button down until the computer powers off. This should not require more than 10 - 15 seconds.Press the power button to turn on the computer.
4. STEP: Verify the Power Supply Voltage Selector Is Correct for the Region. Verify the setting for the power supply:
*Unplug the power cable from the back of the system. *Press and hold the power button for at least 5 seconds to discharge remaining power.*Inspect the voltage selector setting on the back of the machine (Figure 1). Ensure that the voltage select is set in the correct position for the region the in which the system is operating: For Europe and Asia, the voltage setting should be 230V.In North America, Mexico, parts of Central and South America, and parts of the Caribbean, the voltage setting should be 115V.*Plug the power cord back into the back of the system.*Turn on the power.
STEP: Try a Different Known-Good Wall Outlet.
STEP: Remove All External Devices. Turn the system off.
Unplug everything from the front and back of the system except for the power cord or AC adapter, including: keyboard mouse monitor speakers printers scanners USB devices handheld PDAs external Zip or CD-R drives joysticks/game pads, etc
Attempt to turn the system on.
Blinking Amber/yellow: Initial state of LED at power up.
If all the lead is off, then have the mother board replaced
May 06, 2009 | Dell Dimension 2400 PC Desktop
Computer will not turn on
  • Blinking Amber/yellow: Initial state of LED at power up.
Apr 28, 2009 | Dell Dimension 4600 PC Desktop
Won't boot
1. STEP: Ensure Correct Power Button Is Used and Is Not Sticking or Broken. If the power button remains depressed during the power-on attempt, the computer immediately powers off, mimicking a "no power" symptom. Ensure the button is not being held down too long or binding against the bezel or chassis. If necessary, remove the front cover to press the button directly.
Apr 26, 2009 | Computers & Internet
Maxtor external Hard drive not recognised on any pc
Hi cimbom76,
Sorry to hear of your problems. The following is taken from the Seagate (they own Maxtor) website at :-
http://forums.seagate.com/stx/board/message?board.id=PersonalStorage&thread.id=192
For Maxtor Basics and Personal Storage 3100 and 3200 drives, there may or may not be an LED on the power supply, but the light on the drive should usually remain solid during normal operation, while powered on.
1. But if the power supply does have an LED on it, isolate the problem by connecting the power supply into a power outlet without the hard drive connected to it. If the LED blinks in this configuration, the power supply is faulty. Please contact Technical Support for replacement information.
2. If the LED remains solid, connect the drive. Once it is connected, turn the drive on. If the LED begins blinking, the drive has an electronic failure. Please replace the drive. You can create a warranty replacement order to replace the unit.
From what you have said i'm afraid it sounds like there is an electronic failure of the drive. I haven't followed the process through but they do offer a Data Recovery Service at :-
https://services.seagate.com/index.aspx?lng=en-us
There is an online form to fill in or you can telephone
020 7432 4619 to talk to a Data Recovery specialist.
I hope this helps and I hope that you can recover your pictures and videos.
Mark.
Apr 12, 2009 | Maxtor Basics Personal Storage 3200 Hard...
Powers On if I plug it in, and power supply fan runs...
Think of blinking amber as the initial state of the LED. As long as the system is receiving power from a power source and can pass that power through the system board to the LED on the Control Panel it should, at least, blink amber. As a result, a blinking amber Power Button LED is a reliable indicator that the system is receiving power from a power source. This, in turn, tells us that the source and power cord are likely to be functional. The Blinking Amber LED also tells us that the power supply to system board connection is good as well as the connections between the system board, I/O Panel and Control Panel. Depending on the components installed and the condition of those components, the LED may progress past blinking amber and move to solid amber. If the LED does not progress past blinking amber it indicates that the system is not able to properly distribute power to the system components. This is discussed in the next section of the interaction.
It does not indicate that the power supply is bad. It simply indicates that, for whatever reason, one of the power supply 'rails' is not operating within its specified range or, simply, that there is a short somewhere in the system.
The LED state could be the result of a misconfigured or incorrectly installed system component. A bad drive, for example, may be shorting out one of the rails. Incorrectly installed memory can cause a blinking amber front panel power button LED.
Feb 05, 2009 | Dell PowerEdge 1800 Server
ECS P4M800-M V 2.0 wont POST
may u have a grouded DVD drive, did u try another DVD or CD drive? may be it will help.....
Aug 14, 2008 | EliteGroup ECS P4M800-M Socket...
Sony vaio pcv-rz40c1b
You might also consider a power supply. Sometimes they don't die completely, you'll still get a little power from them, but they still need replaced. The motherboard would be the next option, then finally the CPU. CPU's rarely go out before the power supply and motherboard.
Dec 09, 2007 | Sony VAIO PCV-RZ40C1B PC Desktop
Computers & Internet Logo
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
