Question about Dual Televison & Video
Dual dvd 858 with sony KV-28FQ70U TV
I HAVE NO PICTURE OR SOUND (CONNECTION IS FINE AND BY SCART).
THE TV MANUAL DOES NOT LIST OUR DVD BRAND SO NO 3 DIGIT TV REMOTE CONFIG CODE TO ENTER!
techman
  • 3130 Answers
SOURCE: No picture while playing DVD or VHS tape
Your unit has it seems to have developed a video problem. it could be in the video switching IC or the video processor. Its going to need a trained technician, who knows how to use an ocilliscope to find the video problem.. Good Luck
Posted on Aug 02, 2006
  • 70 Answers
SOURCE: vhs dvd combi panasonic dmr ez47
If you select the HDMI channel to watch a dvd does it do it then, if not disconnect both ends of the scart lead and reconnect or replace. If the scart lead is not in properly this could happen, when you switch on the player and play a disc your tv will automatically switch to the AV/Scart channel, but you are better off manually turning the TV over to the HDMI Hi-Def channel for DVD.
Posted on Jan 03, 2008
SOURCE: i need the list of 3 digit codes for tv,vcr,dvd, cabl
rt76
SOURCE: connecting tv, set top box, video etc
Explain the IRC and component settings on a DVD/Television connection (with sattelite box).
Posted on Jul 21, 2008
SOURCE: NEED CODES TO USE WITH ONE FOR ALL UNIV. REMOTE URC3300
Try holding down the tv power button and keep holding it while you press the channel button until your tv comes in.. It takes a few pushes. Make sure your tv is off first though.
Posted on May 30, 2009
Polaroid led tv ssdv311-11 sound but no picture, connected thru cable box
The TV electronics for the picture may have failed. Do you get any picture ever, like when you turn it on, or when you connect a DVD to it?
If you do then replace the scart cable with a good known brand. Cheap scart cables often do not have all the pins connected up.
Dec 21, 2013 | Polaroid 1521-TLUB LCD TV
Hissing and Humming when trying to use the speakers for the tv
The sony manual tells you how to connect to a TV however most of us now watch TV connected to a SKY box. The Scart lead needs to be connected to the Sky box for the sound to work correctly. Ignore the Manual and connect the Scart lead from the DVD Unit directly into you're sky box. It works fine.
Apr 04, 2010 | Sony Audio Players & Recorders
No colour when digital set top box attached
Ensure the set top box is set to the correct video out. Probably RGB if scart lead or CVBS if coax lead.
Jun 10, 2017 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony TV KV-X2973E uk model: no sound in SCART or AV1, AV2.
Do you have its schematics or service manual? This kind of problem needs detailed schematic diagrams of related product. Let me know, are you Tech-Person or TV-Repairman?
Aug 15, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Wire up tv dvd vcr and freeview
hello
connect your sound output from the rear of the TV to your surrond sound system input.
and all should be well.
Thanks Guy9
Mar 14, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Picture Problem
Your TV's tuner is the problem. 1st thing to try is just to sesolder its connections to the main circuit board. If that doesn't work replace the tuner. Also could put a meter on the power coming into the tuner and see if it is drooping in sync with your picture. Tuners are not that expensive to replace.
Jan 06, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Vhs dvd combi panasonic dmr ez47
Dec 24, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
No picture but sound works.....
  • adjust brightness setting when playing tv.
  • adjust screen control located on flyback transformer.
  • hope this will help.
Oct 23, 2007 | Sony KV-36FS16 36" TV
No sound
If I remember correctly, this model can only have sound from either the SCART or the standard input. The solution for this set is to have all the devices work through a common A/V switch box.
The best solution is to update the set to one with more active inputs that are adequate for your needs.
Jerry G.
Nov 19, 2006 | Sony KV-32S26 32" TV
Sony tv picture keeps flashing
You likely have bad solder connections around the tuner area. This model has a history of problems in that area or the tuner itself.
Aug 29, 2006 | Sony KV-32S35 32" TV
Televison & Video Logo
70 people viewed this question
Top Dual Televison & Video Experts
Demonic-2011
Demonic-2011
Tom Chichester
Are you a Dual Televison and Video Expert? Answer questions, earn points and help others
