Question about Dell Inspiron B130 Notebook
Compaq armada e500 850mhz p3 laptop
I have a 60 gig fugitsu drive installed 8 m chache ata100 4200rpm . i wanted a faster drive with more space , so i purchased a hitachi hts721010g9at00 this is a 100 gig hd with 8 m chache at 7200rpm , yes ata-100 standard ide . once installed laptop refused to reconize it , keep saying disk read error . so i got my adapter hooked it up to my desktop and it installed winxp no problem . so i tried it back in the laptop , but still disk read error . Is this some sort of limitation of the bios . i mean with the old bios they was a 23 gig limit but the upgrade fixed that . Also with the new drive the cdrom will not boot .
  • 1 more comment
  • willj3440 Feb 23, 2008
    add to posting , yes i tried the jumpers on the drive everyway possible
    map996 , thank you . but i guess you never been in a armada e500 bios before , the bios is so simple that it does not show a hard drive detection and it is not the FAT . I have a Fugitsu 60 gig hd NTFS partition works wonderfull in the laptop . but the 100 gig hitiachi drive will not even do anything but give a disk read error while installed in the laptop . BUT IF I TAKE THE HITIACHI HD , PUT ON ADAPTER HOOK TO DESKTOP . THE DRIVE READS AND WORKS JUST FINE . Oh and I will remind all I have been building computers for 26 years , so all the simple stuff , I already tried .
    what i need is some one who can slightly alter a rompaq or .bin . Uh a person who knows what they are doing . to view and understand the installed bios , and to create new bios from old by adding new hd support .
    President:
  • 2,351 Answers
I'd like you to get into your bios. At the main bios window make sure your bios is seeing the hard drive correctly (model number). Also check that your cdrom is listed. While in the Bios go to boot & correct the boot order. 1st should be cdrom, 2nd should be your new Hitachi.
You mentioned you connected it to a PC. Than you installed WinXP & everything went fine. Disk read error means your laptop does not like the FAT. When you bought the Hitachi did you get a disk utility? If not download it from the link provided here & test your drive. Use the disk utility to set up your new drive & format
it with the utility. Try again to boot to your cdrom & install WinXP. If your XP does not include SP1 or SP2 your drive may show a smaller size.
http://www.hitachigst.com/hdd/support/download.htm
Good luck, I hope the disk utility fixs the problem.
http://www.hitachigst.com/tech/techlib.nsf/techdocs/50C8DBC2A315A4C786256F400065B756/$file/7K100_SATA_FINAL_DS.pdf (Info)
Posted on Feb 23, 2008
  • Mike Peluso
    Mike Peluso Feb 24, 2008
    No willj3440, never been in armada e500 bios. I do not favor flashing either. Like you I haven't edited a .bin. Not for a notebook. Suggest you re-post and ask what you want as you mentioned above. There are some pretty smart people here. Food for thought I hate NTFS. I love running fat32x on 4 SATA-II, 250's. Great speed......
    Just re-post like I mentioned. We here at FixYa don't mess with others who have answered a user. So you'll get a faster response by re-posting. Good luck willj3440! I hope this works out for you.
    GB
I recently bought a fixer-upper Compaq Armada 1700 and was wondering a few things. 1) What is the maximum hard drive space that this model will support? 2) What is your opinion on using Ubuntu on this...
This would use a EIDE disk which generally tops out around 160GB. It is a disk problem not a computer problem. Unbuntu would work a lot better than any Windows OS. I'd go for it.
If this answers your question, I'd appreciate 4 thumbs. I do this for fun and do not get paid.
Jim
Oct 01, 2010 | Compaq Armada 1700 Notebook
Hi, I have inherited a Compaq Armada E500. Has Windows NT which I hate and doesn't register when anything is plugged into the usb. I was advised to install Ubuntu onto it instead of the Windows, but it...
Due to the specifications of the system:
http://h18000.www1.hp.com/products/quickspecs/10441_na/10441_na.HTML
You are going to have performance issues regardless of the OS (Linux or Windows) If the system has 512 MB RAM, it will run Windows XP fairly well but slow.
As for Linux installation, that system was never certified for Linux and depending on the distribution (Version) you are trying to install, there may be issues.
As far as drive space, linux should load on any of the drive sizes listed by default. If you have not done so, remove all existing partitions and try installing for a Clean HDD.
But to be honest, a Pentium III portable system is for all intents and purposes operationally obsolete. You might want to consider buying a system rather than fight this one.
Example:
http://www.dell.com/us/en/home/notebooks/laptop-inspiron-1545/pd.aspx?refid=laptop-inspiron-1545&s=dhs&cs=19&~oid=us~en~29~laptop-inspiron-1545_anav_1~~
Jan 02, 2010 | Compaq Armada E500 Notebook
Tryng to get a new 60 GB hardrive to work in my Compaq Armada
It Ended up being very simple. I simply found a Dynamic drive Overlay Software and all works fine
Jan 28, 2009 | Compaq Armada 1500 PC Notebook
How to set a Fugitsu HD as slave.
http://www.alyon.org/InfosTechniques/informatique/drives/fujitsu/setting/overseas/empa30xxat/epb10.html
Try to use google first before asking (not try to be offensive in anyways, and you are in the right place)
Anyways shouldn't this not be the right side (found in 8 sec checked it 2 sec) try a search like:
Fugitsu MPA3035AT jumper setting(s).
Nov 22, 2008 | Fujitsu Computers & Internet
Installing a Seagate Dive into an Armada M700
Here at my shop I have run into this exact same problem on several P3 Compaq's and a few Toshiba's. I found that some of these machines, not all, but some, will not accept the 5400RPM drive, but will take the 4200RPM drive just fine. It's just weird because some that do are the exact same model, and I'm not real sure why it won't accept them. I've looked into it and the best that I can surmise is that 5400 is too fast for the reading system in the bios, or it's a power issue. Go with a 4200RPM drive and you shouldn't have any problem. You won't be able to tell any difference in the machine's performance between the two RPM speeds.
Aug 01, 2008 | Compaq Armada M700 Notebook
Says ive used all my memory up but i havent
Armada M700 Specs
Full sytem requirements of FL Studio:
  • Pentium III or Athlon XP (any processor supporting SSE instructions) or Intel Mac with Bootcamp (running XP or Vista) or running Parallels
  • Windows 2000/XP/2003/Vista (32 & 64 bit)
  • 256MB ram
  • 200MB free harddisk space
  • Windows-compatible soundcard with DirectSound drivers. ASIO drivers are required for audio recording (FL installer comes with generic Asio4All drivers)
If your system meets the minimum system requirements, it'll be your actual system resources (memory, CPU, ...) that could impose limits on your FL Studio projects.
The faster your CPU the more channels you will be able to run simultaneously and/or the more effects you will be able to use. The more memory you have the larger the samples you will be able to load.
May 15, 2008 | Compaq Armada M700 Notebook
CPU Upgrade-Which Sockel?
Here is some information may be useful to you. Intel processors Socket 1 169 pins 486 SX/DX Socket 2 238 pins 486 SX/DX/DX2 Socket 3 237 pins 486 SX/DX/DX2/DX4 Socket 6 235 pins 486 DX4 Socket 4 273 pins Pentium 60 en 66MHz Socket 5 320 pins Pentium 75 t/m 200MHz Socket 7 321 pins Pentium, AMD K6/K6-2/K6-3, Cyrix M1/M2 Socket 8 387 pins Pentium Pro 150 - 200MHz Slot 1 242 pins PII, PIII en Celeron Slot 2 330 pins PII Xeon en P III Xeon Socket 370 370 pins PIII, Celeron, Cyrix III Socket 423/478 423/478 pins Pentium4 Socket 603 603 pins Pentium4 Xeon PAC418 418 pins Intel Itanium PAC611 611 pins Intel Itanium 2 AMD processors Slot A 242 pins Athlon Socket A 453 pins Athlon, Athlon XP, Athlon MP and Duron Socket 754 754 pins AMD Athlon 64 Socket 940 940 pins AMD Opteron Conclusion: You can not upgrade beacuse Armada M700 has a pentium III processor with 370 pins. So the Socket 478 pinned pentium is not suitable. Advise: Try to exchange it with a new laptop or buy a used laptop for suitabl configuration
Oct 01, 2007 | Compaq Armada M700 Notebook
CPU Upgrade Help Compaq M700
You might want to check this out I think it answers the questions you are asking? http://h18000.www1.hp.com/products/quickspecs/10382_na/10382_na.HTML
Sep 30, 2007 | Compaq Armada M700 Notebook
Dell Inspiron B130 Notebook Logo
276 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
