Canon i80 Printing with Canon i80 printer Error Number 64: The following ink tank is not installed? Any ideas
  • Anonymous Mar 09, 2008
    help! same problem
    Genius:
  • 1,019 Answers
take out all of the cartridges, and carefully inspect the mating ( chip surfaces ) for dirt-dust-debris.
This could be a sensor related issue, look carefully at the printer itself to see if theres any switches or relays, that the actual cartridge mates up with when installed.
sometimes, the cartridge just needs taking out, and simply reinserting, push firmly into it,s slot.
if non of this works, turn off the printer, and check the cabling for suspected damage wear, or connecting. i.e bent pins et,c.
Mike @ Compurepair.
Posted on Feb 23, 2008
I installed the Canon i80 driver and the printer is recognised by my PC however when i try to print the i80 does all the actions but no ink is shown on the paper. I have checked the print heads and the...
I know it sounds daft.. i had this on a word document... although the text was showing in black it was printing in white. try changing the text colour to black... hope that helps
Jan 10, 2011 | Canon i80 InkJet Printer
It falshes orange and it makes a raddling noise
This error is cauded when there is a issue with the waste ink tank, which in your case will have to be resetted. To do the same please follow the steps as provided in the below article:
http://tricks-collections.com/waste-ink-tank-full-reset-canon-i80/
Also you can visit the cannon website and it tells you in detail the meaning/resolution when the orange light flashes:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/i_series/i80#ServiceAndSupport
Fo to section "Services and support" and there in the dialog bos type "orange light flshes and it will give you steps to follow.
Please let me know if you need any further information.
Jul 21, 2010 | Canon i80 InkJet Printer
Blinng orange light
Answer Part 1 of 2
An error has occurred in the printer. The number of flashes indicates the type of error, as outlined below. Check the cause and take appropriate action.
Two flashes: Out of paper or paper feed error
Reload the paper correctly and press the RESUME/CANCEL button.
Three flashes: Paper jam
If paper has jammed in the printer, clear the jam, reload the paper in the printer correctly and press the RESUME/CANCEL button.
See Paper Jams
Four flashes: Ink tank is not installed properly
Open the Print Head Cover and check whether an ink tank is installed. If an ink tank is installed, push the button of the ink tank, and reinstall the ink tank properly.
Five flashes: No Print Head installed, or Print Head failure
Install a Print Head.
When the error continues, contact a Canon service representative.
Eight flashes: Waste ink absorber almost full
Ink used for cleaning is absorbed in a waste ink absorber placed in the printer. Eight flashes indicate that the waste ink absorber is nearly full. Press the RESUME/CANCEL button to cancel the error so that you can continue printing.
Important
If this error occurs, replacement of the waste ink absorber and maintenance of the printer are required. Canon recommends to contact a Canon service representative as soon as possible. Once the waste ink absorber becomes completely full, it cannot be printed until the Waste ink tank is exchanged.
Nine flashes: A specified period of time has lapsed without receiving a response from a digital camera or digital video camcorder / The digital camera or digital video camcorder connected is not compatible with this printer
Sep 30, 2009 | Canon PIXMA iP90 Mobile Printer
No colour printing
The problem with Canon printers sometimes is that, if you do not use original cartridges and put compatible ones, the printer will not recognise them. Even if you refill the originl ones the printer will still think that they are empty due to the microchip that every cartridge has. Try using original inks. If you already used original inks, then another reason might that the ink tubes have benn blocked because of dried ink if you haven't used your printer for a long time. Try performing a deep clean through the printer application.
Hope that helps
Apr 20, 2008 | Canon i80 InkJet Printer
Service error 5C00
Service error 5C00 might indicate the purge system.
The "rattling sound " is probably coming from the (gears of-) socalled purge unit. May be one ( or both) of the ink tanks is not properly put back in again,or the printhead-lock is not locked. and the purge system is blocked.
Remove the ink tanks and remove the printhead, closw the printhead-lock, close the printhead cover, switch the printer of, switch the printer on again. If the rattling sound is still there, than you might have an expensive problem to be solved.
If the rattling sound is gone, there is probably something wrong with the printheadlock.
Mar 12, 2008 | Canon i80 InkJet Printer
Colour Ink Tank error
I have the same problem, so far no solution found.
Still searching, it is not the microswitch and it is not the printhead, some board assy i think.
Suggestion from Canon: send it in for repair, $100 !
Feb 22, 2008 | Canon i80 InkJet Printer
New printer, blank pages
To remove the printhead:
Ensure that the printer is on and open the printheadcover.
----The printhead holder will move to the center.
Press for some seconds the resume/paperfeed button.
----The printhead holder will move a little to the right.
Press and lift the tiny grey handle now visible at the left and in front of the printhead holder, now you can remove the printhead.
Sep 23, 2007 | Canon i80 InkJet Printer
Computers & Internet Logo
77 people viewed this question
Alun Cox
David Payne
David Payne
