Question about HP - HP Photosmart 8250 printer
I cant find the problem on my HP photosmart 8250. The screen says: Print Cartridge cradle is stuck. I have tried everything. Please help me? Kat
    President:
  • 1,738 Answers
Although the support page of the following link is titled: 'Carriage Jam' this article (with pictures) shows the reader exactly what to look for when the Print Cartridge Cradle becomes stuck.
Click here: http://bit.ly/dpui4S
Posted on Feb 09, 2010
SOURCE:
Ink system failure
Might be carriage strucked in service station,needs to open entire printer other wise carriage damage chances are high, try it gently, dont force to pull it out.. if found difficulty better submit in service center.
Jan 31, 2012 | HP - HP Photosmart 8250 printer
I have a HP Photsmart 8250 it is telling me that the printer cartridge cradle is stuck. I have taken all cartridgese out and in again. I have opened the back and there doesn't seem to be a paper jam. I...
on the printer if the cradle is stuck on right position disconnect the plug from the outlet then push gently the cradle to the left then plug the unit turn on if it is stuck on left disconnect the plug from the outlet then push gently the cradle to the right, hope it helps god bless
Jul 31, 2011 | HP Photosmart 8250 InkJet Printer
Print cartridge cradle is stuck.hoe can I clear jam
It is require servicing if you can open the cover and apply some lubricant oil on the steel rod it will fix the problem otherwise show it service center.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Feb 19, 2010 | HP Photosmart 8250 InkJet Printer
I am getting a message that the print cartridge cradle is stuck. Where is the the cartiridge and how do i unstick it?
On HP's site at THIS LINK I found an article titled: "Resolving 'Print Cartridge is Stuck' Error Message". I hope this helps you. If you need any further help let me know.
Apr 09, 2009 | HP - HP Photosmart 8250 printer
Print cartridge cradle is stuck on Photosmart 8250
Go through the following website to download the product manual for your printer... you should get the steps here.. here is the link:-
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&lang=en&product=443024&
Jan 18, 2009 | HP Photosmart 8250 InkJet Printer
HP Photosmart 8250
when you open up the lid, there is another compartment that can be opened up.  in mine there was a paper obstruction that didn't allow the cradle to move.  remove the obstruction and the printer should do it's own maintenance.
I hope this helps!
Dec 08, 2008 | HP Photosmart 8250 InkJet Printer
My printer keeps telling me my print cartridge is stuck how do i fix this
Nov 17, 2008 | HP Photosmart 8250 InkJet Printer
The cradle is stuck
Fixed it myself...found this link:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00738923&dlc=en&product=443024
It would print the Tap Test as instructed in this illustration....but then wouldn't move to print anything else. So redid the Tap Test several times....then I lifted the lid while printing a test page so the cartridge was in the center and I could get ahold of it to slide it....left the printer ON, but unplugged the power cable...and then I was able to move the cartridge back and forth. I then took QTips with Windex on them and cleaned the silver bar the cartridge moves on. Got a lot of ink off of it.
A couple more test prints...and sliding the cartridge......and it is finally running again.
Jul 06, 2008 | HP Photosmart 8250 InkJet Printer
Print cartridge cradle is stuck ican't find where it is jammed
This might help . . . Mine finished printing one doc & then made a terrible noise & sent a message to my screen that "print cartridge cradle is stuck." When i opened door, i could see it was stuck off to the left side so left cartridge was obscured. I could not get it to budge, although i kept turning it off, gently pushing & turning it back on. Finally, i got my hand inside & determined that the little door to the left-side cartridge had popped open & was causing it to remain stuck. After some struggles (turn off printer first!) i was able to maneuver it around & close it tight. Now, all is well . . .
Apr 16, 2008 | HP Office Equipment & Supplies
588 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
