Question about HP LaserJet 1010 Printer
Printing problem My laserjet 1010 keeps printing the same stuff over and over and then hangs
    Scholar:
  • 148 Answers
ISSUE: A blank page prints after every print job using an HP LaserJet series printer. SOLUTION: A separator page may be turned on in the printer driver, within the application, or on the network. Try printing from several applications. If a page prints out in only one application, that application may have a summary page selected to print out. If a page prints out from different applications, a separator page may be turned on in Windows or on the network. Use the following sections to turn off separator pages. Windows 95/98/Me Follow these steps to turn off the separator page in Windows 95/98/Me:
  1. Select Start .
  2. Select Settings .
  3. Select Printers .
  4. Highlight the appropriate HP LaserJet printer icon.
  5. Select File .
  6. Select Properties .
  7. In the section labeled Separator Page, select None .
  8. Click Apply .
  9. Click OK .
Windows NT 4.0/2000 Follow these steps to turn off the separator page in Windows NT4.0/2000
  1. Select Start .
  5. Select File .
  7. In the Advanced tab, select the Separator Page button.
  8. Delete the location for the separator page.
  9. Select OK .
Windows XP Follow these steps to turn off the separator page in Windows NT4.0/2000
  1. Select Start .
  3. Select Printers and Faxes .
  5. Right-click on the highlighted printer icon and select Properties from the Advanced tab.
  6. In the Advanced tab, select the Separator Page button.
  7. Delete the location for the separator page.
  8. Select OK .
Software or applications See documentation for the specific application that is printing a separator page. The following steps are an example of how to turn off the summary page in Microsoft(R) Word 97:
  1. Open Word 97 .
  2. Select File .
  3. Select Print .
  4. Select Options .
  5. Deselect Document Properties in the Include with Document section.
  6. Select OK .
Novell environments Banner pages can be sent to the printer in several different ways in a Novell environment. The following instructions detail several ways to disable the banner page. NOTE: Banner pages can also be sent from the HP Jetdirect device itself. This page can be enabled and disabled through a telnet session to the HP Jetdirect device. The telnet banner will only print in an lpd/unix ® environment. Novell's Capture Command To disable a banner page using a Novell DOS capture command at a system prompt, type the following commands: capture L=x Q=queuename NFF NB NT TI=x where:
  • L = x -- The value of x would be 1, 2 or 3 depending on the lpt port being used.
  • Q = queuename - The value of the queuename would be the Novell queue setup for this printer.
  • NFF -- No form feed.
  • NB -- No Banner.
  • NT -- No Tabs
  • TI = x -- The value of x would be the timeout amount in seconds. NOTE: If the client workstation is restarted, and if a capture command is part of a login script that is being used, these settings will be reset.
Printer Properties The banner page for Novell networks can also be enabled or disabled in the Printer Properties using the following steps:
  1. To open the Printers Folder ; click Start , Settings, and Printers .
  2. Right-click the appropriate HP LaserJet printer icon and select Properties .
  3. Select the Printer Settings , or Capture Settings tab. The banner page can be enabled or disabled here.
NetWare Clients Follow these steps to disable the banner page for Novell NetWare clients:
  1. Right-click Network Neighborhood and select Properties .
  2. Select the Configuration tab in the Network window.
  3. Highlight Novell NetWare Client and select Properties .
  4. Select the Default Capture tab. The banner can be enabled or disabled here.
Posted on Feb 23, 2008
All the lights are on in hp laserjet 1010 printer i cannot print any page how to solve this problem
Try a hard reset of printer and/or reinstall the software, Check cartridges for ink and operation.
Sep 04, 2016 | HP LaserJet 1010 Printer
I have an HP 1010 laserjet and the red light keeps flashing so I am unable to print and do not know what the problem could be. I have had my printer about 4 or 5 years
Open all doors, remove toner, reinsert toner and shut door. Shut off the printer. Wait.....Turn printer back on.
If red light is still flashing, go to: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00028320#A0 to help identify what it might be. This is an HP site so it is safe.
Sep 09, 2010 | HP LaserJet 1010 Printer
I have an HP laserjet 1010. i got the paper jam
If you are getting correct test page without errors, simply unplug your printer's USB Connection from PC. uninstall Printer drivers and software. restart PC.. Re-Install New Copy of Drivers and Software.. THEN PLUG THE PRINTER USB CABLE TO PC.. try printing after proper driver is installed..
May 30, 2010 | HP LaserJet 1010 Printer
It does not print
my printer hp 1010 was printing fine and suddenly stop print pages.it take in page and through it out as blank page.
Jul 02, 2009 | HP LaserJet 1010 Printer
Paper gets folded at the edges
Clean damaged roller with the special liquid for recover rollers )) That's all))
Nov 17, 2008 | HP LaserJet 1010 Printer
300 dpi priting
Your printer doesn't have a 300 DPI setting, however, you can select "EconoMode" from the "Preferences" menu after you select "Print". Look for a tab that says "Quality". EconoMode will be lighter than normal 600 DPI printing, thereby saving toner.
Nov 13, 2008 | HP LaserJet 1010 Printer
Laserjet 1010
where do I download a free driver ofHP LaserJet 1010 Printer
Dec 23, 2007 | HP LaserJet 1010 Printer
Paper is getting twisting during printer
If it prints but comes out curly then
Paper is damp, try fresh paper.
Aug 16, 2007 | HP LaserJet 1010 Printer
HP LaserJet 1010 Printer Logo
714 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
