Question about Motorola Mobility RAZR V3
Motorole v3 When txting my phone freezes after 5 letters, making a continuous beep sound. I have to remove battery or hold down off button for a few minutes to unfreeze and use phone. everything else is fine
  • Chrissy111 Feb 23, 2008
    OK, sounds good... but how do I do that? How do I master reset my phone?
    Guru:
  • 167 Answers
The best solution to your prob.
is to master clear your phone and master reset,
Posted on Feb 23, 2008
  • Rustan  Garcia
    Rustan Garcia Feb 24, 2008
    press menu>select settings>go to initial set-up>select master clear.
    Enter security code will pup-up....
    just enter your security code default of motorola is 000000
    but some people change it for there own security.
    after you have enter your securitycode
    select yes...
    wait after 2or3mins. your phone is already master cleared..
    note all your phonebook entry and datebook entry, media files, will be cleared or deleted.
    after the phone re-boot do the master reset...
    just follow the instruction that i gave' up to initial set-up and selesct the master reset.
    enjoyandkeepupthegoodwork....
Bose p1 turns on but only first touch works then freezes
If you've done the complete walk around i/e--unplug from wall/remove batteries takes bout 1/2-to-1 hour don't be in a hurry then go bac & reset--if no go then your room interfac M-1 needs repair..1boseguy@gmail.com
Apr 16, 2017 | Bose 023795 LCD Touchscreen Remote Control
Tip
How To Reset and Re-Register Your Uniden Handset and Base
<b>Clear the Handset's Base Data<br /></b>1.To remove the base data from a handset when out of range of the base, press and hold the 'end' button and the '#' button simultaneously until the phone beeps.<br />2.It will now be de-registered from the base.<br />Note: This requires that the base and handset can communicate with each other.<br /> <br /> <b>Clear the Base Handset Data</b><br />1.To de-register all handsets from the base, remove power to the base, and remove the handset from the base.<br />2.Press and hold the 'flash/find hs' button while applying power.<br />3.Wait for the beep and release the button.<br />4.The charge light will now flash.<br />5.Sit any handset in the cradle.<br />6.When the flashing stops, re-register the handsets to the base.<br /> <br /> <b>Re-Register a Handset to the Base<br /></b>1. Remove Handset Battery.<br />2. Reconnect battery while holding down "*" and "#" key.<br />3. Then press the right upper key under the LCD.<br />4. Press the "End" key.<br />5. Wait a few seconds and then the phone will be ready to register to the base.
on Feb 14, 2011 | Uniden DECT 6.0 Cordless Phone ID
My htc sense turns on and freezes
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Dec 02, 2012 | Cell Phones
My phone wont turn on
5.Wait 10 seconds.
Step
Thanks
Sep 05, 2012 | HTC Vivid
Fully charged but will not switch on?
5.Wait 10 seconds.
Step
Thanks
Aug 08, 2012 | Motorola Mobility RAZR V3
Everytime i turn my phone on it has a blue screen with the motarola logo and it says- bootloader usb init
Sounds like your flash went bye-bye. Make sure you are NOT holding down */# on startup as that causes the phone to drop into bootloader. Alteratively, if your phone keeps booting into bootloader by default, try holding them down on startup. Also, try removing the battery, plugging in the charger, and wait for the unable to charge to appear. Insert the battery and let it sit for a few hours which should help.
Dec 26, 2008 | Motorola Mobility RAZR V3
Volume button sticks on Razr V3
the phone needs to have a keypad flex reflash in the phone to correct this issue, so you will need to take the phone to a mobile service center and ahve them do it for you or try modmymoto.com.
Sep 14, 2008 | Motorola Mobility RAZR V3
V3 got useless while ringtone transferring
you can take the phone and ahve the firmware reflash on the phone.
Jun 29, 2008 | Motorola Mobility RAZR V3
Phone keeps freezing
do a master reset and clear and if that does not work then take the phone to a mobile service center and have them reflash the firmware on the phone
Oct 01, 2007 | Motorola Mobility RAZR V3
Motorols Razr Display
maybe when u charge it try having the phone on. see if that works
Oct 16, 2006 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
95 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
