Question about Zanussi FJ1454W Front Load Washer
Pause during cycle
When i start the washer it starts fine but about 5 mins in after it has half filled with water the digital screen reverts back to the original numbers and the machine pauses. I skipped through the cycle to drain and spin the clothes, i then tried a different program, it worked.
The next time i tried my machine the same fault occurred but no program full runs.
Look forward to hearing form you
    President:
  • 1,294 Answers
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Posted on Feb 24, 2008
Fills, goes 4 minutes and fills, pauses, then fills, pauses then fills, over and over
Sounds like its syphoning out the water. If it was overfilling, you would have water everywhere, the machine would eventually flood. Check the drain hose. Make sure the end is higher than the water level in the machine and that there are no extensions running outside which have an end lower than the water level in the machine, it will start syphoning, usually after the first pump out.
Jan 01, 2015 | Washing Machines
I was getting the F H error code on my washer. I hit cancel twice to clear the code to see of a cycle restart would remedy. Now the wash cycle is stuck on 45 min. remaining & the cancel button is no...
The FH error code on your Kenmore Elite washing machine is an indicator that there is a problem with incoming water. When there is little water coming into the machine, the FH code will appear and the washer will stop. There are a couple of common problems you can check while you are resetting the FH error code. You will need to remove the power supply to the washer to reset the code.
  • 1 Look for the "Pause/Cancel" button on the washer control panel. The button will be below the digital time clock and to the lower right of the wash cycle selector.
  • 2
    Press the "Pause/Cancel" button twice to cancel the wash cycle. Unplug the Kenmore Elite washer from the wall outlet.
  • 3 Check for kinks in the water supply hose while the washer does not have power. Turn off the water supply spigots and remove the hoses from the back of the washer. Check the port screens at the hose connections for sediment buildup and clean as necessary.
  • 4
    Connect the water supply hoses back to the washer and turn on the water spigots. Plug the washer cord back into the wall outlet.
  • 5
    Select the wash cycle and press the "Start" button.
  • Apr 29, 2013 | Washing Machines
    Water pressure for Washer (rinse only)
    you nead to turn off both cold and hot water.next you nead to remove cold water hose from washer.remove screen and clean it and replace it.hookup cold water hose to washer and turn water back on.you should have better pressure.your rince cycle is cold water.
    Nov 18, 2009 | Kitchen Ranges
    Washing machine does not drain during rinse cycle?
    Turn timer to rinse cycle. let fill up and agitate. when it stops agitating it should pause then start to pump water out. After about 2 minutes it should pause for 3-5 seconds then start again and spin. If it starts the first time and never stops it will just continue to pump but no spin. The 3-5 second pause allows the transmission to shift to spin. If it does not do this the problem is your timer. You may need to do this a few times to verify the problem.
    If that is not the problem it is likely that you need a new clutch. You will need a technician to install a new clutch for you
    May 17, 2009 | Whirlpool LSQ9600L Top Load Washer
    Kenmore HE4T washer won't rinse. Valves open to
    An HF Code is a Water Inlet Problem- No or Insufficient Water Supply.
    Press Pause/Cancel twice to cancel the cycle. Then, unplug the washer.
    Run down the list again:
    Make sure faucets are completely turned on.
    Make sure the fill vavles (screens where water enter machine) aren't clogged.
    Make sure the hoses aren't kinked, etc.
    Plug the machine back in. Try another cycle. If the problem still occurs, You may need to replace your Water Fill Valve. Let me know if you need any further assistance.
    Feb 23, 2009 | Kenmore Elite 45986 Front Load Washer
    Kenmore 90 Series fills so slow on rinse cycle
    For low water volume - or "Trickling" effect...
    1. Turn off the water supply to both hoses.
    2. Remove hoses (one at a time so you don't get them confused)
    3. On the washer side - look for a removeable screen inside where you just removed the hose.
    4. Using a small screwdriver - pop out the screen and reverse-flush it/clean it. It will likely be full of sediment and calcium deposits from your pipes.
    5. Replace the inlet screens.
    6. Re-fit the hose to the machine.
    7. Turn on water supply valves.
    8. re-try.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
    Feb 09, 2009 | Kenmore 15944 Top Load Washer
    F20 CODE Whirlpool Duet Sport Washer wfw8300sw00
    Hi!
    “F20” on display
    (Water Inlet Problem—no water or insufficient
    water supply) Select PAUSE/CANCEL twice to cancel the cycle
    Unplug washer or disconnect power. Check the following: Are water faucets completely turned on?
    Are screens at inlet hose connection to washer
    clogged? Are water inlet hoses kinked? Are water inlet hoses frozen?
    Do rate the solution.
    Thanks
    Rylee
    Feb 08, 2009 | Whirlpool WFW8300SW
    Basin will not fill with water during rinse cycle but will agitate and spin.
    most new washers have cold water only rinse and spray rinse ck cold water coming into machine during wash if no cold comes in suspect cold side of fill vale not opening ..could be wiring issue or a bad valve
    Oct 24, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
    Whirlpool washingmachine
    Karen, start by removing the cold water hose to the inlet valve in back. It will have a screen in the inlet valve. Make sure the screen is clear of sand and debris. Start there and post back. Catriver.
    Apr 22, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
    Zanussi FJ1454W Front Load Washer Logo
    141 people viewed this question
    Top Zanussi Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    shaun taylor
    Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
