-   I need driver for usb flas drive 256 mg -   zaheen
Jun 30, 2008
-   hi, I am not able to use my 1 GB kinston pendrive in window 1998. pl provide me free download web site for this-   manu_p1983
May 29, 2008
-   i have 4 gb pen drive , when i use with window nt system it does not recognise the pendrive please suggest the solution and email me on vaibhavngp@yahoo.co.in-   Guest
Kingston has discontinued its support for Windows 98 and therefore no longer posts their drivers for that OS.
You can try using generic drivers (but being generic is not 100% compatible to all).
For Windows 98, try here; For Windows 98SE, try here.
Additional information may be viewed here, here and here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Comments:
Feb 23, 2008
- Hi again,
Am I to assume that the drivers doesn't work? Or is it possible that your concern also includes that the USB are not showing in your Device Manager? Or perhaps your PC doesn't have any USB ports?
Contrary to your post "windows 98 and 98se. does,nt like mass-storage devices." flash drives do work in Windows 98(SE) and all it takes is correct setup and getting the appropriate drivers. And I do know since I still maintain a couple of 98s for clients and update most of their anti-virus using a flashdrive.
Perhaps it is you Sir who do not know, may I be of assistance and teach you how pls?
Hello WIN 98 and WIN 98SE wont support the USB Pen Drives Please re-install the latest OS like WIN XP/2K/2003 which automatically detects the mass storage drives. If you solve the problem its my win over the problem Thanking you
How to remove the write protection in drive on Volume/Devices/Hard disk/DC6 I need some help.. I...
(More)
How to remove the write protection in drive on Volume/Devices/Hard disk/DC6 I need some help.. I cannot write or move files on My Kingstone 4GB Data traveler. The message notification says it is write protected and ask to remove the write protection. Unfortunately, I don't know where to find the write protection or where to start to remove the write protection.
Same Problem!!! the Error is |X| Cannot Copy the file: Cannot Fine the Specified file Make Sure you...
(More)
Same Problem!!! the Error is |X| Cannot Copy the file: Cannot Fine the Specified file Make Sure you specify the correct path and the filename my USB devise having problem SKYMEDI USB drive 2GB and it cant be reformat the device is empty plz tell me if this device will not be used forever or you can do this problem.. plz help me on this error Thanks!!
I just got a generic 16gb flash drive and just about every media file i copy there gets corrupted....
(More)
I just got a generic 16gb flash drive and just about every media file i copy there gets corrupted. Altough it's not every time it's about 95%. Is there anything i can do to remedy this or does the problem lie with the drive itself? Thanks.
