Hello i have a fujisu seimans m9400 and i am trying to do a recovery but it asks for passwords on the user and administrotor but we have not set passwords is there a default pass and can you help me with it please
There is a utility that can be found by googling that will reset the SAMS password for all users. Can't recall its exact name, but I think it runs on Linux
Via Admin Account -
One of the most common methods to solve password issues is resetting them if you have lost or forgotten them. In the resolution option one of the common methods is resetting the password with the help of administrator account. In the system used n Fujitsu LIFEBOOK E780, you can create two login as guest and administrator. For this, users have to login via admin account and change the password.
Resetting password via reset password disc
Resetting the password can be performed not only via administrator account but also with the password reset disc. For this you might have to create one. Then user might have to type any password when asked then after some alert messages you might receive the 'Reset password' option. Click on the option. After this users of Fujitsu LIFEBOOK E780 are recommended to insert reset disc or flash drive. Select the respective drive that contains the reset media, type the new password and also add a password question that might help you to remember this password.
There are other options, such as choosing System Restore via Programs - Accessories - System Tools .. which would take your laptop to an earlier date, which could resolve problems.
But, if you want to know how a Factory Restore is done for your system (it's a long process), here it is:
1. Upon boot, select F8 until the menu "Advanced Boot
Options" appears. 2. Choose "Repair your Computer" (use Up/Down keys if necessary to find) and hit Enter. 3. Once Windows has loaded a few files, "SystemRecovery Options" will
appear. 4. Under "Select a language" and "Select a keyboard layout:" specify the
language and keyboard layout. As a rule, the language will be automatically
recognized by the system and is marked in grey. 5.Click on "Next". 6. Under
"User name:" enter the user name and the "Password". The user name will also
be available in the selection menu and can be called up by clicking on
the black triangle. If you have not assigned a password for the user
selected, leave the "Password" field empty. Then click on "OK". 7. In the
following "System Recovery Options" menu, select the option "Fujitsu Siemens
Computers Recovery" with the sub-item "Easy backupandrecovery of your
system". 8. In the next menu, select "Restore the as-delivered status" and
click on "Next". 9. In the menu "Restore factory default settings", choose
the option "From hard disk (recommended)" from "Select source" and confirm
with "Next". 10. The next message informs you that all data could be lost.
Once you have confirmed this message, your system is restored. On
completion of the restoration process, a confirmation message will
be displayed. 11. Select "Exit" to close the process. 12. In the
following "System Recovery Options" menu, select "Restart". 13. After the
restart, you must make some adjustments. To do this, follow the
onscreen instructions.
Dear User,
Good day, maybe you need to press the function key of your laptop plus(+) the split monitor key in your keyboard it is usually placed in F5 key.
Reinstall windows, or what you can also use is windows password recovery. You can download and burn on disc from another computer and boot up locked computer with this disc. Another thing you can do is download a program called "windows recovery" and it will erase everything on the hard drive and you will be able to reinstall windows and have brand new computer.
Hello, I can unlock ANYACER bios password (ASPIRE, EXTENSA, FERRARI,
ACER ONE MODELS). If anyone have questions feel free to visit
www.laptoprebirth.com or send an emailto [email protected] WE SUPPOR OTHER
BRANDS LIKE SONY HP COMPAQ TOSHIBA ASUS GATEWAY DELL FUJITSU SIEMENS SAMSUNG
If by reset you mean soft re-set then it is the same as most pc' s CTRL+ALT+DEL. if you are looking for a external reset button that model does not have it.
If you want to restore to factory default, Caution! Personal data could be lost during restoration of the factory default settings. Proceed as follows to restore the factory default settings: 1. Turn your machine on or: If the PC is already running, switch the machine off, wait for a moment and then switch it on again. 2. During the boot process, press the F8 key at very frequent intervals, until the menu "Advanced Boot Options" appears. Repeat this process if necessary in order to gain access to this menu. .com 5 3. The "Advanced Boot Options" menu will offer you the "Repair your Computer" function. If this is not the case, use the up/down keys () to select "Repair your Computer" and confirm with the Enter key. 4. Once Windows has loaded a few files, "System Recovery Options" will appear. Under "Select a language" and "Select a keyboard layout:" specify the language and keyboard layout. As a rule, the language will be automatically recognised by the system and is marked in grey. Click on "Next". 5. Under "User name:" enter the user name and the "Password". The user name will also be available in the selection menu and can be called up by clicking on the black triangle. If you have not assigned a password for the user selected, leave the "Password" field empty. Then click on "OK". 6. In the following "System Recovery Options" menu, select the option "Fujitsu Siemens Computers Recovery" with the sub-item "Easy backup and recovery of your system". 7. In the next menu, select "Restore the as-delivered status" and click on "Next". 8. In the menu "Restore factory default settings", choose the option "From hard disk (recommended)" from "Select source" and confirm with "Next". 9. The next message informs you that all data could be lost. Once you have confirmed this message, your system is restored. On completion of the restoration process, a confirmation message will be displayed. 10. Select "Exit" to close the process. 11. In the following "System Recovery Options" menu, select "Restart". 12. After the restart, you must make some adjustments. To do this, follow the onscreen instructions.
