Question about Nintendo Super NES Console
Super Nintendo Start/Select Button not working all the sudden
One day I went to turn on the Super Nintendo and all the buttons on the controller work except the start/select button?? It's like this on both controllers? Nothing has happened to them to damage them so I know it can't be the controller it has to be the console? I took apart the controllers just in case and they work fine all except the start button. I can do everything but start the games?? Any simple solutions?
  • Anonymous May 16, 2008
    the solution by
    Compurepair worked like a a charm.
    the only thing needed is a screwdriver.
    put your controller upside down (buttons facing the table).
    open the controller, get the controller cord out the S turn, and remove the printplate. make sure your L and R buttons stay in place.
    check the print for greasy areas, and clean those with a little alcohol.
    put your controller together, 5 screws and your done.
    took me as a noob 15 minutes for my first controller, 4 minutes for my second. 100% result.
  • Anonymous Jan 09, 2009
    Same problem no start or select followed directions and bam fixed Thanks a ton
    Genius:
  • 1,019 Answers
your problem will be with the mating surfaces of the switch contacts themselves.
i,ve cleaned several console hand-pads. to find that sweat and food debris mixed together, get under the contact pads.
this is the small piece of carbon ( mounted under the silicone rubber pad ) inside the controller.
these should be wiped with a cotton bud, swabbed in a small amount of lighter fluid ( or methylated spirits ) and wiped clean.
re-assemble controller.
check the cable for signs of wear, also the controller port mating surfaces should be shiny copper connections. if these are not mating with the controller, then no signal is being transmitted between the pad and input ports.
look carefully, if any pins are lower than others, take a fine electrical screwdriver or needle, and gently bend the pin upwards, so that they all align at the same height.
Failing this, you have faults on you controller port input sockets.
these can be replaced, as they,re ribbon cabled to the mainboard. this is a job if your electrically competant.
Hope this helps.
Mike @ Compurepair.
p.s if it was simple, everyone would be doing it :)
Posted on Feb 23, 2008
I had a super nintendo and it went missing and everything was in working order before it went missing, so i still had the controllers and the cords for it all just not the console. So I went and bought...
Well I think that the controller ports are messed up inside of the console that allow you to work the controllers is either broken or loose or it might be something wrong with the motherboard inside of the machine then.
Sep 05, 2011 | Nintendo Super NES Console
Control Problems I dont know if its my controller my snes or my games I only have two games Super Mario World and Donkey Kong Country. On Super Mario the only buttons that work are the B and Start...
I'd say it sounds like an issue with either the controller or the port on the system. My advice to you would be to try a different controller, and try switching ports on the console. The games should be fine, though.
Mar 16, 2011 | Nintendo Super NES Console
I just bought a super nintendo ''super famicom jr''. I turned the power button on and I didn't see anything on the screen. Am I supposed to put the game in first before I turn the power button on? I didn't...
Well yes you are supposed to put the game in before you turn on the system. another thing is that super nintendo doesn't make the same noises like most modern game systems do because those game systems require more electrical components. If the light is on its most likely working. If it still doesn't work it most likely has dust. you might want to blow in the game or the game console. Hope I could help.
Dec 15, 2009 | Nintendo Super NES Console
Extensively tested but unresponsive SNES controllers
Well it could be the controllers but its probably that one of the wires have gone bad in the super nintendo. Maybe try replacing. Just and idea though.
Mar 24, 2009 | Nintendo Super NES Console
Super Mario Galaxy not working
try to take it into game crazy and repair it
Mar 23, 2009 | Nintendo Super Mario Galaxy for Wii
Super mario slugger won't let us pitch
a lot of people have this problem if this doesn't work you need new battery's or your controller is broke.
check if the lights on the pad are flashing you need to sync the pad
to do this you hold the red button inside the battery casing and the
red button inside the SD slot casing and wait till the light stop flashing
and go to the light corresponding to your controller
that is it it should work and be synced for every game
Feb 20, 2009 | Nintendo Mario Super Sluggers for Wii
No start button
try this: hold A and B then turn ur ds on then when the ds logo appears hold start and select while still holding A and B then when the: this product is not licensed of endorced by nintendo: comes up release all buttons.. hope this works
Jan 24, 2009 | Nintendo DS Lite Console
Controller
I do not know about the controller turning off but the walking may be caused from holding over on the nunchuck while you plug it in, it happens with game cube controllers if you hold a button when plugging them in and for the game cube controller you can hold start, X, and Y for about 3 seconds to reset the controller and thatt fixes it, but I am not sure for the Wii remote. I suggest playing brawl with a gamecube controller
Mar 12, 2008 | Nintendo Wii Console
Snes controller
It is common for buttons on any video game controller to quit working and it is usually an easy fix.
Assuming the cord is in good condition the problem is internal. Turn the controller over with the buttons down and remove all of the screws on the back. Carefully lift off the back. You are now looking at the back of the circuit board. Look closely at how the cord is routed through the plastic pins as you will have to put it back in the same location. Remove the cord from the pins and carefully lift out the circuit board. Turn the circuit board over and locate the contacts for the buttons. There are four on the left side for the D-Pad, two in the middle for the Select/Start, and four on the right for the A,B,X, & Y. These contacts need to be cleaned. A hard eraser works best. Reassemble everything and it should work fine for quite some time.
Jan 19, 2008 | Nintendo Super NES Console
Nintendo Super NES Console Logo
1,203 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
