Question about Orion1934 19" TV
32inch orion bad picture
> my Orion TV recently had a little white line going accross the
top of it for about 2 weeks then i shut it off and now when its
turned on the picture is compressed down to a 100cm line in the middle
of the TV screen . is there a part i can buy to repair it its a
good TV and i like it besides I'm paralyzed and really can't afford a
new TV. so please help and thank you.
> GOD BLESS,
> bill English
> the # on the TV is TV2501a
> the # on the remote is 076nodw02
and where can i order the part thanks
  • 62 Answers
Hii...
I'm absolutly have no idea whit thos tv set ( Orion ) but...your problem looks like mall function at the vertical circuits....can you see the ic or transistor nearst the FBT ? or you can type all the ic number/type and the Chassis of the tv set olso the Transistor around the Fly Back Transformer ?!
I hope it's can help you..
Hear from you soon
Thank's
[Vrya] be_cek@yahoo.com
Posted on Feb 23, 2008
Orion Orion1934 19" TV When I
if you are conncting it over component cable check your cables in the right spots if rca *red yellow nad white) then the cables may be bad or the refresh rate needs to be changed make sure the dvd player is selecting the correct output you are using.
Mar 16, 2011 | Orion1934 19" TV
Black /white picture no change who make sansui please give phone number to call
Orion carries the Sansui line of TVs. See the website at Orion America, or check the web for Sansui TVs and seek the "contact us" on the home page.
Jan 06, 2011 | SansuiS2746 TV
The picture is closing from the top
needs service, resoldering the main board, changing of capacitors near the flyback transfomer area..in general it needs to be reserviced
Nov 16, 2009 | Orion1934 19" TV
I have white lines on the top of my tv. It is Orion, maybe 3 years old.
This is an easy repair if you've ever soldered and would not be too costly for a repair shop to do it for you. The problem is a bad Vertical Output IC (usually mounted on an aluminum heat sink with the part on it labeled LA78?? ) and 1 or 2 bad capacitors. Some times you can even fix the problem by re-soldering the contacts of the IC- To find the IC follow the 4 wires that come from the Yoke (which is a contained coil of wires slipped over the neck of the picture tube(s)) back to the board. 2 of the wires go to the horizontal o/p and 2 to the Vertical o/p the thinner gauge wires are for the vertical.
Sep 27, 2009 | Orion1934 19" TV
Orion tv without input/output plugs
from the looks of the picture you have one audio video input port on the front of the tv. The connectors are yellow and red or yellow and white. Yellow is video and red or white are audio. Find those same connectors on the back or your dvd player, hook it up to the tv and there you go. You'll have to go to game mode or input 2 on the tv to see the dvd player.
Jul 01, 2009 | Orion1934 19" TV
Orion tv only has 2 channels and it's hooked up to cable
go to menu,go to were it says cable and air,select cable. then go up to auto program do search, this should do what you want.
Jun 13, 2008 | Orion Televison & Video
Orion TV, Model STV2763A
This is usually caused by some of the electrolytic capacitors in the vertical deflection amplifier and in the blanking circuit areas. Sometimes it can be some of the other types of components going slightly off specs.
To test the capacitors, an ESR meter or the equivelent is required.
I would suggest sending the TV out to have an experienced TV service tech do this type of work for you. These types of problems can get very involved. There are also some serious safety issues when working on a TV set.
Jerry G.
May 10, 2008 | Orion STV2763 27" TV
Orion tv32RN10D Digital problems
factory reset hold volume button on tv down all the way while holding it down hold number 1 on your remote goes to stanby turn back on..
Jan 08, 2008 | Orion HDLCDVD225 22 in. LCD TV
Picture problems
Bad electrolytic cap(s) in vertical deflection section.
Nov 21, 2007 | Orion STV2763 27" TV
Orion 27" tv
hi your problem could be two different things , the first one is that it mught have a cold solder in the vertical or a bad capacitor in the same area.
Nov 02, 2006 | Orion STV2763 27" TV
Orion1934 19" TV Logo
147 people viewed this question
Top Orion Televison & Video Experts
wayne chamberlain
Jerry Greenberg
Jerry Greenberg
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
