Question about Toshiba A205-S4577 Notebook
Toshiba A205 not seeing 2 gigs installed
Installed 2 gb of ram and checked system data and the ram =1014. I removed and reinstalled the memory no change-ideas?
  • betafish Feb 24, 2008
    thought so- thanks
You have a bad brand ram.Contect your dealer
Posted on Feb 23, 2008
In call of duty ghost do i need to buy 1 whole 8 gig of memory
You need to have 6 gigs of free dynamic ram.(Not including that used by the operating system and any other applications you have.
The way that memory is organised in a computer these days is usually in pairs or DRAM (dynamic random access memory) sticks which are matched. This allows the CPU to withdraw data from both memory sticks in the same clock cycle (DDR double data rate) which improves the over all speed of the processing.
So legal combinations over 4 gigs which will use the dual channel feature on your motherboard will probably be.
2 x 4 gigs sticks = 8 Gig DRAM
2 x 8 gig sticks = 16 Gig DRAM
Below is the minimum specification requirement.
Note: MINIMUM Faster CPU better graphics card and More ram is better.
CPU: Intel Core 2 Duo E8200 2.66 GHZ / AMD Phenom X3 8750 2.4 GHZ or better CPU Speed: Info RAM: 6 GB OS: Windows 7 64-Bit / Windows 8 64-Bit Video Card: NVIDIA GeForce GTS 450 / ATI Radeon HD 5870 or better Sound Card: Yes Free Disk Space: 40 GB
Feb 24, 2015 | Activision Call of Duty: Ghosts Full...
How do I upgrade my bios for toshiba laptop ?
Why do you want to update the BIOS of your laptop? Be careful about updating your BIOS because it might cause your computer to crash.
Or are you trying to update the drivers in your computer?
If you are having some issues with its performance, then you need to update all the outdated drivers in your computer. I know that it's a total headache if you do the update manually but don't worry because there are Automatic PC Updater like RadarSync. It will scan and update all outdated drivers in your computer.
I hope this helps!
David
Feb 07, 2013 | Toshiba Satellite A205-S5879 Laptop
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Nov 03, 2010 | Dell Dimension B110 PC Desktop
I tried to install 1gig of ram into my toshiba and it won't start
reinstall memory (check specs if they exactly the same as old one before reinstalling) if wont work install old memory , if works you may have a bad 1 gig stick
Dec 29, 2009 | Toshiba Satellite M35X-S114 Notebook
I want to change the 2 x 512DDR ram by 2x 2GB DDR ram memories in my A205-S4577/Toshiba. Will it work?
hi,
it will work as your notebook is supporting maximum 4 gb RAM but please check that you are using 32 bit operating system or 64 bit one.
If it is 32 bit then the system will be showing 3.2 gb RAM only as this is the 32 bit os limitation.
Jun 03, 2009 | Toshiba Satellite A205-S4587 Notebook
Error message after installing memory ram upgrade.....
The memory appears to be the right kind.
Try installing just one 1GB module, and run the diagnostics (press F12 at boot time and select diagnostics).
Dec 20, 2008 | Dell Inspiron E1505 Notebook
Not seeing other stick of ram
MAYBE YOUR COMPUTER ISNT CAPABLE OF HANDLING MORE THAN 1 GB ram UPGRAPE LOOK AT THE SPECS ON THIS MODEL TO SEE WHAT MAX MEMORY IT WILL SUPPORT.
Jan 17, 2008 | Compaq D310 (287944-CTO-4) PC Desktop
Install 2 RAM modules of 1 GB
The other memory may be soldered in. Check your manual and see if it has any information on additional memory. If you only have on expansion slot you may have to buy larger memory chips. like instead of 2 chips 1 gig each you may have to purchase a 2 gig chip. Computer companies usually make the chip installation easy to get to on lap tops.
Jan 14, 2008 | HP Compaq nx6310 Notebook
Ram upgrade
In order to see how many MHz is your desktop, please right click on your "My computer" icon and select "Properties" from the menu.
It will open the system properties window. select the tab "general" and you will see how many MHz is your desktop.
If you have found this solution helpful please rate it as "solved", otherwise please ask here again.
Thank you :)
Oct 12, 2007 | Computers & Internet
Toshiba A205-S4577 Notebook Logo
60 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
