Question about Intel D845GVSR Motherboard
BOOTING ON MAINTANANCE MODE BUT NOT ON NORMAL MODE
I HAVE INTEL D845GVSR MB WITH CPU 2.0GHZ P4 ....WHEN I START THE COMPUTER NO DISPLAY AND NO SOUND ...I ALLREADY TEST MY RAM & CPU.....WHEN I SET MY BIOS JUMPER ON MAINTANANCE MODE COMPUTER DISPLAY IS ON...BUT WHEN BIOS JUMPER ON NORMAL MODE THEN FOUND NO DISPLAY & NO SOUND
  • Anonymous Feb 26, 2008
    HAVING SAME PROBLEM...WHEN SWITCH TO  JUMPER IN NORMAL MODE
    Scholar:
  • 148 Answers
Clear the bios by changing the jumpers
Posted on Feb 23, 2008
  • 65 Answers
Clear your bios, remove your all pci cards & then try.
Can i install windows seven on board D845GVSR
i have installed windows 7 in my motherboard D845GVSR. when the installation finished the display was very poor so i taught to to install xp again . before that i have opend the windows 7 media center .when opening the said that the display was not above 32 mb . .......... .press f2 in starting then search for an option like this "video configuration" and one more option in it like this "video space " starting from 16 mb to 256 mb . the previous mode is 32 mb . change it from 32 MB to 64 MB or higher and u have to save it and restart again the system and u have to change the screen revolution in the windows 7 and the system graphics hve become enabled .
regrads-Ruben
Jan 16, 2010 | Intel D845GVSR Motherboard
Trying to upgrade cpu.
Here's a direct link to the service manual of the NetVista 8303-21A:
http://download.lenovo.com/ibmdl/pub/pc/pccbbs/netvista_pdf/24p2969.pdf
On page 13 of this manual:
Microprocessor (varies by model type): Intel® Pentium® 4 processor with 256 KB or 512 KB of internal L2 cache memory and Intel NetBurst™ micro-architecture.
It seems that the computer's motherboard does not support Intel P4 processors with more than 512 KB of internal L2 cache. That's why your P4 2.8GHz/1M/533 Prescott processor did not work.
You will have to either buy another processor with 512 KB L2 cache, or replace your motherboard with one which supports the new processor.
Dec 19, 2009 | IBM NetVista PC Desktop
I have a problem with Intel D845GVSR Motherboard with 2.0 GHz processor. When I power the M/B, only the Motherboard LED is on, but no boot, no cpu fan running. No beep code also. I check the SMPS, RAM,...
Think this should be an issue with the power button, Remove the wires running from the power button to MB and try starting the system with shorting the 2 lead of the power button..
Mostly, it can be due to bad power supply or Ram
Rate this solution
RNJ VINODKUMAR
Sep 26, 2009 | Intel D845GVSR Motherboard
BIOS problem with D845GVSR
you don't want the cd to be master,You want to change boot order and make cd,first boot.
Jan 20, 2009 | Intel D845GVSR Motherboard
MY system is not read OS from CD drive
is the bios set to boot from the cd drive 1st?
No display
It is normal for a board to beep if there isn't any RAM in it. This is due to the POST process checking to see if everything is all right, and finding no ram.
to check the board, ll you can do, is make sure the CPU is compatible with the MB, also try putting an graphics in the machine. If it displays, great! Then you know your onboard graphics are not woking or disabled in CMOS. If it doesn't show anything, and you know that the RAM is not faulty, and the CPU is compatible, and you plugged out all CD-Roms/HDDs, then either your onboard graphics are faulty, or your motherboard is dead.
(You did test it with another screen didn't you?)
Good Hunting!
Jan 07, 2009 | Intel D845GVSR Motherboard
CPU incompatibil
Do you get to the boot screen if so press the key to enter BIOS and set BIOS to default then from there set up to suit CPU and memory
Also check the M/board battery is OK
Sep 22, 2008 | Intel D845GVSR Motherboard
Motherboard won't boot
u can go to ur mb bios nd check ur processor setting.may be 845gvsr not support intel crl processor.u can give load bios default from ur bios press F6 or F7,
Sep 19, 2008 | Intel D845GVSR Motherboard
3 beep sound-no booting
system is on but no display. yes i did heard sound 3 beep sound from the motherboards.
Aug 16, 2008 | Intel D845GVSR Motherboard
Intel motherboard 845gvs
intel 845 gvsr motherboard have two most problem
vrm circuit fail IC ADP3168 {between the cpu and core volt connector}
f7338 mosfet ic fail {between the memory slot and ide connector}
Feb 26, 2008 | Intel Motherboard
Intel D845GVSR Motherboard Logo
125 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
