Question about PC Chips M848ALU Motherboard
Motherboard diagram i have a pcchips m848a and need to know how to wire it
If you are looking for the pinout for the front panel which the downloaded manual does not show it is silkscreened on the printed circuit board right above the battery
Posted on Jul 09, 2008
    Sniper:
  • 67 Answers
The instructions are straight forward on page 13+ in the manual below
heres the driver|bios|manual link
http://www.pcchips.com.tw/PCCWebSite/Downloads/
ProductsDetail_Download.aspx?detailid=341&DetailName
=New&DetailDesc=&CategoryID=1&MenuID=6&LanID=2
the direct link to the manual
http://64.124.27.139/DLfile/manual/848Av50.pdf
Posted on Feb 23, 2008
Update for SiS 2615 Display Adapter to load windows XP pro
The PC Chips MB PCCHIPS SiS746FX M848A V5.0 462 motherboard does not have onboard video, correct? So if you can obtain the make and model of your video card, you can then find the Windows XP drivers online for download. Then you would be able to provide said drivers when the "system asks you to update SiS 2615 Display Adapter driver"
*Another quick fix would be to use a different VGA card, if you have one available?
*Now, I have never been prompted to update display driver before or during a windows installation or update. So that step I would require a little more detail on. I have only been prompted for mass storage drivers (as seen in screenshot).
Apr 19, 2010 | PC Chips MB PCCHIPS SiS746FX M848A V5.0...
M848a v 5.0 unable to get front usb connection after all software installed. double checked connections
you need the wire diagram of case to plug in the right way you can fry the board if not right jim
Feb 17, 2010 | Computers & Internet
I need a wiring diagram fora M848A motherboard
Hey compu_suppor,
Good Luck finding a schmatic of the board. I'd contact PCChips directly and see if they even published one. HERE's a least the manual wih their info you contact them.
Good Luck
Mark
Oct 17, 2009 | PC Chips M848ALU Motherboard
CASE WIRES TO PANEL1 CONNECTIONS
The hdd red wire gooes to pin #1 the hdd white wire goes to pin #3 the power sw orange wire goes to pin #6 the power sw white wire goes to pin #8 The reset sw blue wire goes to pin #7 the reset sw white wire goes to pin #5 the power led green wire goes to pin #2 the power led white wire goes to pin #4.
Now the layout of the pins is the long row (5) pins are the odd number pins 9 being the odd one and 1 is the other end of the row. 2 through 8 start at the pin accross from 1 : : : : . I hope this helps you.
Aug 22, 2009 | PC Chips MB PCCHIPS SiS746FX M848A V5.0...
Hi i have a problem with panel1 on M848A v5.0 motherboard i cnt seem to work out how to connect the case properly it looks like this ()()()() ()()()()() i have the power switch, reset switch, hdd led and...
OK, this is for all the idiots who reply and offer NOTHING. You need more info, model and ver? HE ALREADY GAVE ALL THAT INFO.
Type "M848A v5" in google and you will see it is a PCChips mobo AND the manual is here:
http://download.ecsusa.com/dlfilepcc/manual/848Av50.pdf
BUT the manual DOES NOT HAVE THE PIN-OUT, so the manual is worthless...
Here is the pin-out:
(2)(4)(6)(8)
(1)(3)(5)(7)(9)
...and thanks to guntotenmadm
Aug 28, 2009 - The pin layout on the MB are color coded. There is green, orange, pink, and blue. I'll start with the green pins 2 and 4 these are for the power led wires, bottom pin #2 is the + pin (your green wire). Pin #4 is - (your white wire). Now the orange pins, pins 1 and 3 these are for the HDD led. The bottom pin #1 is the HDD + pin (your red wire). Pin #3 is the HDD - (your white wire). Now the pink pins, 6 and 8 these are for the power switch. Pin #6 is the + pin (your orange wire). Pin #8 is the - pin (your white wire). Now the blue pins, 5 and 7 these are for the reset switch. Pin #5 is the - (your white wire). Pin #7 is the + (your blue wire)."""
May 18, 2009 | PC Chips MB PCCHIPS SiS746FX M848A V5.0...
PCChips M848A Motherboard
Ok well the simplest answer is to get ahold of an old pci (not pcie) video card and plug her in. If this doesn't get you video I don't know what will. If you're not getting vid with the pcie slot it could be disabled (idiotic I know) in your bios.
Aug 29, 2008 | Soltek SL-PT880E-RL Motherboard
Cannot get motherboard to boot from hard drive
Have you checked the Bios to see if its actually recognising the hard drive?
Turn on the computer and I think on your bios it should be the f2 key to get into the bios, if its not detecting the hard drive you may just have a jumper on the drive set wrong
Let me know if I can be of further assistance
Aug 22, 2008 | PC Chips MB PCCHIPS SiS746FX M848A V5.0...
Jack call-outs and drivers
http://www.pcchips.com.tw/PCCWeb/Products/ProductsDetail.aspx?MenuID=24&LanID=0&DetailID=251
hope that fixes it for you :)
Jan 06, 2008 | PC Chips MB PCCHIPS SiS746FX M848A V5.0...
PC Chips M848ALU Motherboard Logo
465 people viewed this question
Top PC Chips Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
